nuckollsr(at)cox.net Guest
Posted: Thu Jun 21, 2007 4:44 pm Post subject: Question about Aux battery contactor on Z30 |
At 03:56 PM 6/21/2007 -0600, you wrote:
| Quote: | Hi,
On drawing Z30 there is a auxiliary battery contactor. If the auxiliary
battery is not being used for cracking the engine could this contactor be
replaced with a diode similar to the endurance buss diode and still allow
charging of the aux battery? The reasoning behind this question is it
would lower the component count and simplify the isolation of the
auxiliary battery.
If the aux battery is never intended to drive the bus and
only support its battery bus, then
(1) a smaller power relay can be used like the S704-1
automotive plastic relay which offers a voltage drop
on hte order of tens of millivolts. See:
http://tinyurl.com/2sno9m
(2) Or you could use a power diode. Silicon junction
devices have about .6 volts of drop in the conducting mode
See http://www.vishay.com/docs/88612/gbpc12.pdf
(3) a schottky device would bring this down to .4 volts.
See http://www.vishay.com/docs/93275/9327520c.pdf
Folks have found all three techniques useful.
planesmith(at)hotmail.com Guest
Posted: Thu Jun 21, 2007 6:54 pm Post subject: Question about Aux battery contactor on Z30 |
Thank you for the quick response and the multiply options. In building an airplane, so far, the electrical is by far the most intriguing to me.
Thanks again,
Vern Smith
| Quote: | Date: Thu, 21 Jun 2007 19:41:52 -0600
Subject: Re: Question about Aux battery contactor on Z30
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
>Hi,
>auxiliary battery.
>Thanks,
Folks have found all three techniq========================>
Live Earth is coming. Learn more about the hottest summer event - only on MSN. Check it out! [quote][b]
