bicyclop(at)pacbell.net Guest
Posted: Wed Jun 13, 2007 8:35 pm Post subject: Regulator trouble? |
Howdy,
The other day, the low volt light started flashing and I found the field
breaker popped. This is an LR3C with the notorious Van's 35 amp
alternator. I reset the breaker and about 5 minutes later, it popped
again. The voltage had been running about 14.6 which seemed a little
much so I reset it and turned on some lights. The voltage ran about 13.9
to 14 and the breaker didn't pop for quite a while. About the time I
thought that it was cool, the low volt light came on again, but this
time the breaker wasn't out. I turned off the master and flew another
hour and a half, including a stop for gas, and landed at Aurora. I found
a bit of hangar space and pulled the alternator. It had a lot of end
play and tested bad at the local auto parts place. I bought another one
at Van's - they tried to talk me out of it, but I didn't want to rewire
the airplane for the internally regulated unit a long way from home.
Hey, I would have happily spent the extra for the B&C alternator, but I
was in Aurora not Wichita.
It charges just fine, in fact it'll hold voltage at idle with lights on
which is more than the old one would do. It is also running at about
14.5 or .6 and the breaker has popped 3 times so far. The breaker resets
and the alternator runs fine for a while, but I'm wondering if I'll blow
up the new alternator, too. Do you think that the regulator is a bit
wonky? Is the voltage too high? Am I frying my battery? Is the
overvoltage module overactive?
Pax,
Ed Holyoke
nuckollsr(at)cox.net Guest
Posted: Thu Jun 14, 2007 6:09 am Post subject: Regulator trouble? |
At 09:31 PM 6/13/2007 -0800, you wrote:
Howdy,
again. The voltage had been running about 14.6 which seemed a little much
so I reset it and turned on some lights. The voltage ran about 13.9 to 14
and the breaker didn't pop for quite a while. About the time I thought
that it was cool, the low volt light came on again, but this time the
breaker wasn't out. I turned off the master and flew another hour and a
half, including a stop for gas, and landed at Aurora. I found a bit of
hangar space and pulled the alternator. It had a lot of end play and
tested bad at the local auto parts place. I bought another one at Van's -
they tried to talk me out of it, but I didn't want to rewire the airplane
for the internally regulated unit a long way from home. Hey, I would have
happily spent the extra for the B&C alternator, but I was in Aurora not
Wichita.
which is more than the old one would do. It is also running at about 14.5
You need to conduct and investigation of system performance
as outlined in note 8 of
http://aeroelectric.com/articles/Rev11/AppZ_R11J.pdf
and take some readings. In fact, get an el-cheapo analog
voltmeter for observing field voltage. It's more important
to know how stable it is than to know the exact voltage reading.
| Quote: | The breaker resets and the alternator runs fine for a while, but I'm
wondering if I'll blow up the new alternator, too.
No, I cannot think of any abuse (other than lack of cooling)
that you could heap on an externally regulated alternator
from outside that would place it at risk for premature failure.
| Quote: | Do you think that the regulator is a bit wonky? Is the voltage too high?
Am I frying my battery? Is the overvoltage module overactive?
About 150 years ago Lord Kelvin admonished us, ""If
you can not measure it, you can not improve it." To
craft considered answers to your questions, we'll need
some numbers and some observations of behavior. I'll
suggest that you craft the field voltage monitoring
feature suggested in Figure Z-23.
We need to know what the field voltage is in cruise
RPM with minimum loads and with everything turned on.
Also make note of voltage fluctuations during what
should be a steady state condition (turn strobes on/off
to see how much they added to any wiggles you observe).
In particular, we'd like to capture field voltage
behaviors leading up to a trip of the OV protection
system.
I know this can be tedious and difficult. This is
why I own data acquisition systems that monitor and
record real time values. If I had cash for all the
Jet-A I've burned up waiting to capture a transient
event in a sneaky failure I could pay off my mortgage.
You're not frying anything. The bus voltage is
not too high. It's unlikely that the OV protection
system has become hyper-active with age. You don't
say how long this regulator has been in service.
Posted: Thu Jun 14, 2007 10:53 am Post subject: Regulator trouble? |
The regulator has been in service for about 900 hrs. It's been through
at least 2 or 3 Van's alternators in that time, though I don't have good
records on that. I'll swing by radio shack and check back at a later
date with field voltage info.
Ed
<nuckollsr(at)cox.net>
> Howdy,
> field breaker popped. This is an LR3C with the notorious Van's 35 amp
> 13.9 to 14 and the breaker didn't pop for quite a while. About the
> time I thought that it was cool, the low volt light came on again,
> but this time the breaker wasn't out. I turned off the master and
> flew another hour and a half, including a stop for gas, and landed at
> Aurora. I found a bit of hangar space and pulled the alternator. It
> had a lot of end play and tested bad at the local auto parts place. I
> bought another one at Van's - they tried to talk me out of it, but I
> didn't want to rewire the airplane for the internally regulated unit
> a long way from home. Hey, I would have happily spent the extra for
> the B&C alternator, but I was in Aurora not Wichita.
> on which is more than the old one would do. It is also running at
> about 14.5 or .6 and the breaker has popped 3 times so far.
> high? Am I frying my battery? Is the overvoltage module overactive?
system.
Posted: Sun Jun 17, 2007 6:12 pm Post subject: Regulator trouble? |
I've got more info now, but I'm not sure what it means. I wired up a
jack as per Bob's suggestion and can read field voltage on the VOM in
flight. I also changed the setpoint on the regulator by about 1 turn on
the adjustment screw. The downloaded installation instructions said that
should be about 2 tenths of a volt. It had been running about 14.6. The
regulator turns out to be an LR3B-14 not the C model I reported
previously. I don't know how much difference that makes.
When started, the voltage ran right at 14.4, exactly as expected after
the adjustment. The field was about 3.5 to 4.5 volts at idle. I'm using
a digital VOM because it's what I have, so it jumps around a bit. With
strobe, landing/taxi and position lights on and at idle, the buss came
down to about 14.1 and the field rose to about 7 or 8 volts. Load was
around 17 amps by my meter.
In flight the numbers were pretty similar except that the buss never
fell much below 14.4 no matter what I did with the lights. The field ran
somewhere in the 4ish range with no lights and around 8 with. After
about 30 minutes of flying, the buss was at 14.5. When I taxied in, it
was 14.7 at idle which I don't understand at all. The field breaker did
not blow today.
I'm in watch and wait mode for now.
Pax,
Ed Holyoke
Ed wrote:
good records on that. I'll swing by radio shack and check back at a
later date with field voltage info.
Ed
>> Howdy,
>> amp alternator. I reset the breaker and about 5 minutes later, it
>> popped again. The voltage had been running about 14.6 which seemed a
>> little much so I reset it and turned on some lights. The voltage ran
>> about 13.9 to 14 and the breaker didn't pop for quite a while. About
>> the time I thought that it was cool, the low volt light came on
>> again, but this time the breaker wasn't out. I turned off the master
>> and flew another hour and a half, including a stop for gas, and
>> landed at Aurora. I found a bit of hangar space and pulled the
>> alternator. It had a lot of end play and tested bad at the local
>> auto parts place. I bought another one at Van's - they tried to talk
>> me out of it, but I didn't want to rewire the airplane for the
>> not Wichita.
>> I'm wondering if I'll blow up the new alternator, too.
> system.
> Bob . . .
pruemotorgliders(at)cox.n Guest
Posted: Sun Jun 17, 2007 7:20 pm Post subject: Regulator trouble? |
Gee Ed, I have no idea. The only thought I have is to check in with
B&C regarding the difference between Mod B and C. That and a
description of your history may lead to a understanding.
Hopefully the AeroElectric list will have some ideas
Jerry
On Jun 17, 2007, at 20:09, Ed wrote:
on the adjustment screw. The downloaded installation instructions said
that should be about 2 tenths of a volt. It had been running about
14.6. The regulator turns out to be an LR3B-14 not the C model I
reported previously. I don't know how much difference that makes.
using a digital VOM because it's what I have, so it jumps around a
bit. With strobe, landing/taxi and position lights on and at idle, the
buss came down to about 14.1 and the field rose to about 7 or 8 volts.
Load was around 17 amps by my meter.
ran somewhere in the 4ish range with no lights and around 8 with.
After about 30 minutes of flying, the buss was at 14.5. When I taxied
in, it was 14.7 at idle which I don't understand at all. The field
breaker did not blow today.
Pax,
Ed Holyoke
> through at least 2 or 3 Van's alternators in that time, though I
> don't have good records on that. I'll swing by radio shack and check
> back at a later date with field voltage info.
> Thanks,
> Ed
>>> Howdy,
>>> a little much so I reset it and turned on some lights. The voltage
>>> ran about 13.9 to 14 and the breaker didn't pop for quite a while.
>>> About the time I thought that it was cool, the low volt light came
>>> on again, but this time the breaker wasn't out. I turned off the
>>> master and flew another hour and a half, including a stop for gas,
>>> and landed at Aurora. I found a bit of hangar space and pulled the
>>> talk me out of it, but I didn't want to rewire the airplane for the
>>> not Wichita.
>>> lights on which is more than the old one would do. It is also
>>> running at about 14.5 or .6 and the breaker has popped 3 times so
>>> far.
>> system.
>> Bob . . .
Posted: Mon Jun 18, 2007 6:10 am Post subject: Regulator trouble? |
At 07:09 PM 6/17/2007 -0800, you wrote:
I've got more info now, but I'm not sure what it means. I wired up a jack
as per Bob's suggestion and can read field voltage on the VOM in flight. I
also changed the setpoint on the regulator by about 1 turn on the
When started, the voltage ran right at 14.4, exactly as expected after the
adjustment. The field was about 3.5 to 4.5 volts at idle. I'm using a
In flight the numbers were pretty similar except that the buss never fell
somewhere in the 4ish range with no lights and around 8 with. After about
30 minutes of flying, the buss was at 14.5. When I taxied in, it was 14.7
at idle which I don't understand at all. The field breaker did not blow today.
Excellent data! . . . and pretty much as expected. Let's review
the significance:
First, there are no differences between the B & C revisions of this
regulator that would affect the phenomenon under investigation.
(1) "With strobe, landing/taxi and position lights on and at idle,
the buss came down to about 14.1 and the field rose to about
7 or 8 volts."
(a) The maximum possible range for field voltages is 0 to bus
voltage . . . or a little below bus voltage because the
pass transistor doesn't turn on with zero-volt drop. We
would NEVER expect to see field voltage at ZERO during
any set of normal operating conditions . . . ZERO field
is ZERO output. The only time we would expect to see zero
output is if something was broke.
(b) The slight drop with load is within expectations.
(c) The field voltage reading of 7-8 volts at idle tells us
that your alternator's output is about half used up for
this RPM and load conditions. As we noted above, the field
cannot rise to more than about 14 volts and under the test
conditions cited, you were already half way there.
(2) "Load was around 17 amps by my meter."
(a) Is this an alternator loadmeter? In other words, the 17A
reading is the alternator output current for the conditions
cited?
(3) "In flight the numbers were pretty similar except that the
buss never fell much below 14.4 no matter what I did with
the lights."
(a) Every regulator designer is pleased to hear this. The
goal is to craft electronics that maintains the bus at the
established set-point irrespective of load. So, for field
voltages greater than zero and less than bus voltage, we would
expect the bus voltage to stay put under any load that does
not cause the field voltage to max out.
(4) "The field ran somewhere in the 4ish range with no lights
and around 8 with."
(a) What size alternator is this? I think you mentioned a
35A machine? Again, the reading of about 8 volts with loads
on (and assuming the same 17A of output) that the alternator's
output is about 1/2 used up.
If this were my research project, I'd throw a little 200 samples
per second data acquisition system (Snipe trap) on the field, bus
volts and bus amps. Then I'd go fly the airplane and attempt to
induce a trip by manipulation of controls for electrical system loads.
Okay, your snipe catching sack is in hand and your flashlight
(field volts indicator) is charged up. What we would hope to
capture is what the field voltage is doing just prior and/or
during a trip event. On the next flight, you'll want to "fiddle
with the switches and things" while observing field voltage and
see if you can induce a trip.
The readings you've cited are strong indications that the system
is/was performing as-designed during the period of your observations.
mprather(at)spro.net Guest
Posted: Mon Jun 18, 2007 7:41 am Post subject: Regulator trouble? |
If trying to induce a trip, maybe it would make sense to run the test
early in the morning when the OAT is low so as to help the alternator put
out maximum snort? Does this regulator bump the voltage set point in
response to low temperature (temperature compensated)?
Matt-
> I
> the
> today.
the significance:
7 or 8 volts."
cited?
the lights."
and around 8 with."
loads.
klehman(at)albedo.net Guest
Posted: Mon Jun 18, 2007 8:25 am Post subject: Regulator trouble? |
I have a slightly different take on this as it seems there might already
be some clues here.
Shouldn't the field voltage go above 8 volts when the alternator is
loaded on the ground. If it is putting out less that 14.4 volts at low
rpm - why isn't the field voltage up around 12 or 13? High resistance
somewhere in the field?
Next I'd want to know why 14.7 volts while taxiing in. Is the regulator
voltage going up when it is hot? Does it not throttle back far enough
under light load? Is there a connection that is high resistance when
hot such that the regulator is sensing 14.4 but putting out 14.7
upstream where the voltmeter is located? Or is it an inaccurate voltmeter?
If the connections have already been checked, I'd be tempted to
temporarilly wire in a cheap regulator and see what happens.
Ken
> said that should be about 2 tenths of a volt. It had been running
> about 14.6. The regulator turns out to be an LR3B-14 not the C model
> I reported previously. I don't know how much difference that makes.
> after the adjustment. The field was about 3.5 to 4.5 volts at idle.
> I'm using a digital VOM because it's what I have, so it jumps around
> a bit. With strobe, landing/taxi and position lights on and at idle,
> the buss came down to about 14.1 and the field rose to about 7 or 8
> volts. Load was around 17 amps by my meter.
the significance:
7 or 8 volts."
cited?
the lights."
and around 8 with."
loads.
Posted: Mon Jun 18, 2007 5:24 pm Post subject: Regulator trouble? |
At 09:33 AM 6/18/2007 -0600, you wrote:
The regulator is not compensated for battery ambient. It
is compensated for a close to zero temperature coefficient
as practical.
Ed also noted that the system tripped several times while
in cruising flight so it seems a low-order probability
that a first start of the day "cold test" would be any
more revealing.
Actually, given the numbers that Ed has cited, I'm
pretty much convinced that "catching" his Snipe is
going to be pretty tough with just a digital voltmeter.
The best we might hope for is that the field voltage
becomes jittery just before a nuisance trip when it
had been stable earlier.
Ed, you might consider getting an el-cheapo analog
meter from Radio Shack. See:
http://tinyurl.com/29yk5d
This instrument has a 15 volt DC range that is ideal
for this investigation. Right now, we're going to be
more interested in dynamics (steady vs. twitchy) as
opposed to knowing the actual reading.
In the mean time, my software guru is looking into
how hard it would be to do a quick turn on a little
4-channel, data acquisition system that would run off
a laptop. Ed, do you have a laptop computer you could
press into the service of Snipe Catching?
aadamson(at)highrf.com Guest
Posted: Mon Jun 18, 2007 5:47 pm Post subject: Regulator trouble? |
Bob, not sure they get much cheaper than this
http://www.dataq.com/products/startkit/di194rs.htm
They also have them for USB, but not sure of the cost... Also 12Bit version
are available.
Alan
Posted: Mon Jun 18, 2007 7:17 pm Post subject: Regulator trouble? |
At 12:18 PM 6/18/2007 -0400, you wrote:
be some clues here.
Shouldn't the field voltage go above 8 volts when the alternator is loaded
on the ground. If it is putting out less that 14.4 volts at low rpm - why
isn't the field voltage up around 12 or 13? High resistance somewhere in
the field?
The voltage will go that high only if one approaches the alternator's
maximum available output current for that RPM. In this case, he cites
a 17A load and ramp idle RPM.
| Quote: | Next I'd want to know why 14.7 volts while taxiing in. Is the regulator
under light load? Is there a connection that is high resistance when hot
such that the regulator is sensing 14.4 but putting out 14.7 upstream
There's a ton of variables which can stack up to push the setpoint
around a bit . . . what we're interested in finding is an instability
that accounts for the nuisance trip of an OV protection system set to
operate at 16.2 volts or so.
| Quote: | If the connections have already been checked, I'd be tempted to
A cheap regulator wouldn't have the ov protection built in. It
WOULD be a useful experiment to temporarily wire in a substitute
regulator and a separate OV sensor. I think I've got some hardware
laying around we can send him if we don't see something really
profound . . . or he's unable to observe a field and bus voltage
surge associated with the nuisance trip.
