Start up oil pressure, Jabiru
DanM
PostPosted: Mon Jun 18, 2007 1:01 pm    Post subject: Start up oil pressure, Jabiru Reply with quote
Anybody out there now what the new engine (cold) 1st start oil pressure
should be?. When I crank the engine, but not starting it, the oil pressure climbs to 75- 80 psi. Seems kinda high to me, any thoughts?
Dan Mc Intyre
Kitfox IV
Jabiru 2200 SN 1311 , 59.7 hours
Sensenich 62x46
N443DM
Michel
PostPosted: Mon Jun 18, 2007 1:52 pm    Post subject: Start up oil pressure, Jabiru Reply with quote
pressure
When I fly, the oil pressure is about 45 psi, Dan. When I start the
engine and it's cold, it may climb as much as 75-80 psi when the engine
is cold but, honestly, I don't know what it shows when I crank without
starting because ... my Jabiru 2200 always starts at the first turn. Is
your engine new has has never started? Do you have an oil cooler?
Without the cooler you will see more variation in pressure than with
it.
Michel Verheughe
Norway
Kitfox 3 - Jabiru 2200
smokey_bear_40220(at)yaho
PostPosted: Tue Jun 19, 2007 6:43 am    Post subject: Start up oil pressure, Jabiru Reply with quote
Dan,
This also depends upon what viscosity oil you use and
if you have a pressure relief port. Don't know if the
2200 has one....
My pressure can get as high as 90 psi cold if I use
straight 50 weight oil. A multi weight oil can reduce
the cold pressure, if it is acceptable for the 2200.
Michel, what weight oil do you use in Norway?
Kurt Schrader
S-5/NSI turbo
CAP 140 prop
Florida and Panama
Finding fabulous fares is fun.
Let Yahoo! FareChase search your favorite travel sites to find flight and hotel bargains.
http://farechase.yahoo.com/promo-generic-14795097
DanM
PostPosted: Tue Jun 19, 2007 7:15 am    Post subject: Re: Start up oil pressure, Jabiru Reply with quote
Michael & Kurt
Thanks for the information, My Jabiru 2200 is new, but a few years old. I've not started the engine yet, just cranked it with the starter to
check things out. I plan to actualy start the engine in two week. The engine has a relief valve as well as a oil cooler. I'm using Shell
mineral for the engine break in period. Seems from you guys are saying is the cold oil pressure is ok. I'll find out for sure when I actualy
start the engine. I don't want to fry my nice new engine.
 Filesize:  382.7 KB
 Viewed:  547 Time(s)
Dan Mc Intyre
Kitfox IV
Sensenich 62x46
N443DM
Michel
PostPosted: Tue Jun 19, 2007 7:18 am    Post subject: Start up oil pressure, Jabiru Reply with quote
From: kurt schrader [smokey_bear_40220(at)yahoo.com]
Well, after living in Spain for some years, my favourite is, of course, olive oil but ... oh, you mean, the engine? AeroShell 15W50, Sir! Works well winter as summer!
Michel Verheughe
Norway
Michel
PostPosted: Tue Jun 19, 2007 10:40 pm    Post subject: Start up oil pressure, Jabiru Reply with quote
I understand, Dan. But if your engine was stored all these years with
the preserving oil from the factory, it shouldn't be a problem and it
should fire the first time as mine did: on the first spin of the
starter. About the oil pressure you have, anyway, to put on your check
list that it is the first item to check when the engine is starter. No
pressure would require an immediate engine stop. As it will always be
cooler than operating temperature, the oil will be thicker and pressure
higher at engine start. It may take several minutes before it starts
going down. On my engine it won't get over the operating 80°C when
taxiing. I need to take off to see the "normal" oil temperature and
pressure.
Michel Verheughe
Norway
