Are Kitfox I-III and Avid HH ribs interchangeable?
dholly
PostPosted: Mon Jun 18, 2007 7:50 am    Post subject: Are Kitfox I-III and Avid HH ribs interchangeable? Reply with quote
You, like I, may have heard or read that Kitfox I-III and Avid HH use the same airfoil and wing ribs, therefore, are exact duplicates of each other. Thanks to a local KF-II builder, I had the opportunity to do a hands-on comparison of both ribs. Pics show results.
Note: in photos, KF-II rib is a new replacement which matched original perfectly; Avid HH rib has blue tape on capstrip.
KF-II rib (top) and Avid HH rib (lower)
 Filesize:  471.54 KB
 Viewed:  409 Time(s)
Undercamber difference is quite measureable.
 Filesize:  433.78 KB
 Viewed:  394 Time(s)
Lower curve of Avid HH incorporates more undercamber.
 Filesize:  353.01 KB
 Viewed:  401 Time(s)
Top curves the same, KF-II rib slightly wider.
 Filesize:  357.84 KB
 Viewed:  391 Time(s)
