Tab on Rudder
mdps_mc(at)swoca.net
PostPosted: Thu Jun 14, 2007 9:04 am    Post subject: Tab on Rudder Reply with quote
I have to use alot of right rudder on my model IV. This became an issue after I installed the Jabiru 2200. This isn't a big problem but I would like to fix it. If I want to place a tab on my rudder which side should it go on? Could I use a small piece of bent lexan for the tab? I think I know the answer but sometimes things are counterintuitive.
Mike Chaney
1996 Kitfox
Model IV
Jabiru 2200
kerrjohna(at)comcast.net
PostPosted: Thu Jun 14, 2007 9:44 am    Post subject: Tab on Rudder Reply with quote
I placed mine on the left side of the rudder so that it would push rather than pull the rudder to the right. I would suggest you consider using aluminum so that you can tweek it to have the ball centered at your normal cruise speed, in the case of N195KF it is bent for equilibrium at 92 kts. It is located at the bottom curve of the trailing edge so that advantage can be taken of the leverage provided in riviting to the bottom portion of the tubing. (Not three rivits in a straight line). You could similarly mount it at the top curve thereby avoiding any wind shadow created by the fuselage. I have also seen a stronger spring/shorter connection used on the right rudder pedal to address the issue. The tab is more effective I believe at varying speeds and easier to tweek in order to get it right.
John Kerr
N195KF
Classic IV,912UL
[quote]-------------- Original message --------------
Mike Chaney
1996 Kitfox
Model IV
Jabiru 2200
Guy Buchanan
PostPosted: Thu Jun 14, 2007 11:10 am    Post subject: Tab on Rudder Reply with quote
To get right rudder use left tab. A harder question is how much. You could use Lexan, but the reason most use aluminum is that it's easy to bend to get the right amount of trim. You could first do the aluminum tab, get the size and angle right, then make one out of Lexan.
Guy Buchanan
San Diego, CA
K-IV 1200 / 582-C / Warp / 100% done, thanks mostly to Bob Ducar. [quote][b]
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
kitfox(at)ida.net
PostPosted: Thu Jun 14, 2007 12:09 pm    Post subject: Tab on Rudder Reply with quote
I did about the same thing as John Kerr. I used a fairly long piece 6" long and 3" from the trailing edge. The front of it extends out over the lower horizontal tube a couple of inches. This takes out the twisting on the rear vertical tube. I then glued and rivited it in place. It will fly feet off at a fairly broad speed range.
Albert Smith
5TD, NSI turbo and Cap 3 blade
smokey_bear_40220(at)yaho
PostPosted: Thu Jun 14, 2007 12:28 pm    Post subject: Tab on Rudder Reply with quote
Hi Mike,
It is possible that your new engine is mounted to pull
just a bit left. It doesn't take much to make it pull
a lot. You might consider shimming it at the mounts
to have it pull more right. This means that your
cowling might not line up as exact though. Not a big
deal with the round cowl, but the other one will show
the change. I adjusted mine by about 3/16th inch and
it made a big difference.
Kurt S.
S-5?NSI turbo
Florida and Panama
2200.......
Mike Chaney
1996 Kitfox
Model IV
Jabiru 2200
Take the Internet to Go: Yahoo!Go puts the Internet in your pocket: mail, news, photos & more.
http://mobile.yahoo.com/go?refer=1GNXIC
msm_9949(at)yahoo.com
PostPosted: Thu Jun 14, 2007 3:56 pm    Post subject: Tab on Rudder Reply with quote
How about a photo John?
My model 2 yaws right at cruise (70 mph). Left foot gets tired. Otherwise, she flies hands-off.
kerrjohna(at)comcast.net wrote:
[quote] I placed mine on the left side of the rudder so that it would push rather than pull the rudder to the right. I would suggest you consider using aluminum so that you can tweek it to have the ball centered at your normal cruise speed, in the case of N195KF it is bent for equilibrium at 92 kts. It is located at the bottom curve of the trailing edge so that advantage can be taken of the leverage provided in riviting to the bottom portion of the tubing. (Not three rivits in a straight line). You could similarly mount it at the top curve thereby avoiding any wind shadow created by the fuselage. I have also seen a stronger spring/shorter connection used on the right rudder pedal to address the issue. The tab is more effective I believe at varying speeds and easier to tweek in order to get it right.
John Kerr
N195KF
Classic IV,912UL
I have to use alot of right rudder on my model IV. This became an issue after I installed the Jabiru 2200. This isn't a big problem but I would like to fix it. If I want to place a tab on my rudder which side should it go on? Could I use a small piece of bent lexan for the tab? I think I know the answer but sometimes things are Fussy? Opinionated? Impossible to please? Perfect. [url=http://us.rd.yahoo.com/evt=48516/*http://surveylink.yahoo.com/gmrs/yahoo_panel_invite.asp?a=7 ]Join Yahoo!'s user panel[/url] and lay it on us. [quote][b]
Float Flyr
PostPosted: Fri Jun 15, 2007 12:54 pm    Post subject: Tab on Rudder Reply with quote
Attach either side of the rudder and bend the trailing edge slightly to the left.... I know it sounds like leaning into a left hook but that's it. Start with a slight bend and increase until you are comfortable with the results. If you fly low and slow you may need more tab input (bend) if you fly at the upper end of the envelope than you will use less.
[img]cid:753555020(at)15062007-0A1F[/img]
Noel Loveys, RPP, AME intern
Campbellton, Newfoundland,
Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
 Filesize:  19.77 KB
 Viewed:  297 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
