N14AV history
barry.collman(at)air-brit
PostPosted: Thu Jun 14, 2007 7:41 am    Post subject: N14AV history Reply with quote
Hi David,
An .xls file is attached, showing the history of s/n 914-22.
The data has been gleaned from paperwork filed at the FAA and factory records held by Twin Commander.
If there's anything, anything at all, that you can add, or correct, then please do let me know.
One question, when the RC-10 camera was installed, was it accomplished under an STC? I presume it wasn't quoted on the Form 337.
Very Best Regards,
Barry
00914.xls
 Filename:  00914.xls
 Filesize:  21 KB
 Downloaded:  428 Time(s)
kamala(at)MSN.COM
PostPosted: Thu Jun 14, 2007 9:03 am    Post subject: N14AV history Reply with quote
FYI, anyone looking for a factory camera port, gary(at) commander aero has the one we removed from 2001M. mason
[quote] From: barry.collman(at)air-britain.co.uk
Subject: N14AV history
Date: Thu, 14 Jun 2007 16:40:01 +0100
Hi David,
Very Best Regards,
Barry
PostPosted: Thu Jun 14, 2007 9:14 am    Post subject: N14AV history Reply with quote
Hi Mason,
That's interesting, as I didn't know that 680F(P) s/n 1208-109 had a camera installation!
If you can help with all, or any, of the following, I'll be most grateful:
1. When was it installed?
2. What STC was used (or Factory Drawing)?
3. What Make & Model Camera was it?
I didn't find anything on this in Factory records (Warranty File) or the papers filed at the FAA.
Very Best Regards,
Barry
dowens(at)aerialviewpoint
PostPosted: Thu Jun 14, 2007 1:30 pm    Post subject: N14AV history Reply with quote
Downtown Airpark did the install...
David Owens
Aerial Viewpoint
N14AV
AC-500A-Colemill
kamala(at)MSN.COM
PostPosted: Thu Jun 14, 2007 1:40 pm    Post subject: N14AV history Reply with quote
bc, the camera system was seemingly unknown to everyone. it was installed at the factory when built. we discovered the structure while installing the new auto pilot system. we removed all of the structure and i gave it to commander aero for there help. there was no opening or camera mounted. by the way i still have not received the history from you on 2001M. possibly this fall. look forward to seeing you . mason
Subject: Re: N14AV history
Date: Thu, 14 Jun 2007 18:13:19 +0100
.ExternalClass P {padding-right:0px;padding-left:0px;padding-bottom:0px;padding-top:0px;} .ExternalClass {font-size:10pt;font-family:Tahoma;} Hi Mason,
Very Best Regards,
Barry
