icubob(at)newnorth.net Guest
Posted: Thu Feb 09, 2006 3:33 pm Post subject: antennas |
hi all,
I have several antennas to install. My elt requires a ground plane. Tim at b and c was very helpful with my questions but i question leads to 5 more. Is there any way around a ground plane for the elt? If not, any suggestions on how to make it in my wood/cloth fuselage? At first i thought numerous strips of thin copper way the way to go but that looks like just more fasteners. Can a very thin sheet be laid down in the fuse. bottom? It wouldnt exactly be flat with all the woodworking to go around.
Also, my dipole comm must be vertical. No more than 45 deg slant. is 30 deg vastly better than 45 deg and is 15 deg vastly better than 30 deg. Are these slanted antennas going to noticeably going to affect transmission/ reception that much anyway?
Anyone want to volunteer a phone number to me off list? i have more questions every time i get one answered.
Thanks in advance, bob noffs
nuckollsr(at)cox.net Guest
Posted: Thu Feb 09, 2006 3:46 pm Post subject: antennas |
At 05:30 PM 2/9/2006 -0600, you wrote:
Quote: |
hi all,
If it's wood and fabric, I'd go with a vertical dipole wrapped
around the inside surface of the fuselage. Perhaps on side opposite
your comm dipole cited below and separated some fore/aft as well . . .
Quote: | Also, my dipole comm must be vertical. No more than 45 deg slant. is 30
No . . . the lion's share of antenna performance happens
in the first 25% of length each side of center (about 5")
meaning that things you do with the last 15" per side are
not terribly critical. Get as much of the center section for
both antennas as vertical as practical, then wrap the ends
They'll drop in center frequency as you "fold" them so you
MIGHT want to check them with an SWR/Antenna analyzer and
trim them for optimum.
Quote: | Anyone want to volunteer a phone number to me off list? i have more
Let's do it on the list. If your questions are worth
asking, then they're worth sharing too.
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Thu Feb 09, 2006 4:30 pm Post subject: antennas |
bob noffs wrote:
Quote: | Is there any way around a ground plane for the elt?
No.
Quote: | If not, any suggestions on how to make it in my wood/cloth fuselage?
Most anything will do. You want some strips of copper or wire that are
the same length as the ELT antenna, i.e. 1/4 wave at 121.5 MHz (about
25" or so). A flat piece of metal 25" in radius or larger would work.
And it may be oddly shaped.
Quote: | Can a very thin sheet be laid down in the fuse. bottom?
Certainly. That would be fine.
Quote: | It wouldnt exactly be flat with all the woodworking to go around.
That doesn't matter.
Quote: | Also, my dipole comm must be vertical. No more than 45 deg slant. is 30 deg vastly better than 45 deg and is 15 deg vastly better than 30
deg.
The closer you are to vertical, the better it will work but anything
will work after a fashion, even horizontal. Just try to get it as
vertical as possible.
Quote: | Are these slanted antennas going to noticeably going to affect transmission/ reception that much anyway?
Odds are, no, you won't notice the difference.
Quote: | Anyone want to volunteer a phone number to me off list? i have more questions every time i get one answered.
If I have time I would answer your questions.
Brian Lloyd 361 Catterline Way
brian-yak at lloyd dot com Folsom, CA 95630
- Antoine de Saint-Exupery
_________________ Brian Lloyd
- Antoine de Saint-Exupery |
Posted: Thu Feb 09, 2006 6:11 pm Post subject: antennas |
Guess I forgot to ask if you had a dual freq ELT . . . I guess all the
new ones are. In this case, the ground plane under a stock antenna is
necessary. But since it's a dual freq, one might argue that two sets of
radials would be good . . . one set tuned for 121.5 (24") and another
set optimized for 406 (7.3"). Hmmm . . . maybe a 7.3" radius piece of
copper foil with a few 20" legs soldered to the edge. The single dipole
I suggested would not be suited for dual frequency use (although one
COULD be crafted . . . it would probably be more trouble than it's worth).
Quote: |
hi all,
BigD(at)DaveMorris.com Guest
Posted: Thu Feb 09, 2006 7:56 pm Post subject: antennas |
In theory, the amount of loss varies as the cosine of the angle difference
between the transmitting and receiving antennas. At a 45 degree angle, you
lose 3dB, which is somewhat noticeable, because it is actually 1/2 of the
power lost. At 90 degrees, it is over 20dB loss, which is substantial.
In practice, the signals bounce around and may not arrive at your antenna
perfectly vertically polarized to begin with, but it doesn't hurt to make
it as close to vertical as possible. The problems will mainly show up when
you're a long way away from the ground station. When you're close, it
won't make much difference.
Dave Morris
Posted: Fri Feb 10, 2006 4:12 am Post subject: antennas |
hi all,
i have gotten quite a bit of info from the responses to my questions. i now am confident i can mount my comm antenna and transponder and they will work. the elt with a ground plane still has me stalled though. will have more questions about that , just wanted to let everyone know how helpful the responses were. gotta go make donuts now.
bob noffs
brian
Posted: Fri Feb 10, 2006 6:59 am Post subject: antennas |
Robert L. Nuckolls, III wrote:
new ones are.
The old ones are too. They operate at 121.5 MHz and 243 MHz.
And a tuned 1/4 wave counterpoise (radials) for 121.5 MHz is totally
useless at 243 MHz. Good point about having two sets of radials.
bakerocb
Posted: Fri Feb 10, 2006 7:28 am Post subject: antennas |
Responding to an AeroElectric-List message previously posted by: "bob noffs"
<icubob(at)newnorth.net>
2/10/2006
Hello Bob, Dare I post some heresy? Will the gummint sic its watch dogs on
me? Will the electromagnetic radiation purists on the list rise up in total
fury to slap me down? Well, I'll take a chance.
Suppose that the gummint, in its infinite wisdom, mandated that every
aircraft carry 3 pounds of butter and a container of maple syrup just in
case the survival situation after crashing resulted in a supply of pancakes
as the available food supply. Would you insist on carrying genuine maple
syrup or would an imitation be good enough for you?
Maybe an ELT is a little more useful than butter and maple syrup in a crash
situation, but I sure as hell wouldn't place my entire faith in being found
and rescued in one of the garden variety ELT's that we are mandated to
carry. My point is that obsessing over antenna ground plane details is
wasted time.
Nobody knows exactly what attitude their aircraft will be in when it
finishes crashing. The ELT antenna could end up pointing directly down at,
and a few inches from, the surface of the earth. How much difference would a
perfect ground plane, if one could construct one, make in that situation?
Here is my thinking:
1) To be legal, buy one of the garden variety ELT's that we are mandated to
carry. Install it securely in the proper location in the proper attitude
with regard to its deceleration sensor. Fasten on the wire antenna that came
with the ELT and don't obsess over ground planes or what the antenna's
attitude will be when you finish crashing. Go fly.
2) If you want to take some truly effective steps for rescue after crashing
you can, and probably should to the degree that you are concerned and
considering routes of flight, do some or all of the following.
2A) Always carry a hand held VHF comm radio with a battery supply that you
KNOW to be capable of extended operation.
2B) Always carry a cell phone with a battery supply that you KNOW to be
2C) Purchase and carry a PLB http://www.equipped.com/faq_plb/default.asp
2D) Carry a tough plastic container of water -- size your choice. My
experience with even short time rescued people is that they experienced an
almost mentally debilitating thirst shortly after crashing.
2E) Carry a knife of enough size and sturdiness to punch through / crack
your plastic windows and canopy.
I am sure that other posters will add their favorite / essential crash
survival items, but obsessing over these items falls into the same category
of time wasting like obsessing over ground planes. Take what you deem to be
reasonable precautions to be rescued after a survivable crash and then
proceed to fly worry and guilt free (and legal).
OC
PS: If you have the bank account to afford one of the new 406 Mhz ELT's, go
for it.
<< hi all, I have several antennas to install. My elt requires a ground
plane. Tim at b and
there
thin
all the woodworking to go around.....skip.....Thanks in advance, bob noffs>>
BobsV35B(at)aol.com Guest
Posted: Fri Feb 10, 2006 7:41 am Post subject: antennas |
Good Morning OC,
I know the rules say no "me too" messages, but you have presented the same
arguments that I would like to present, but was afraid to send due to the
flaming I would get had I done so!
Very well done.
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
Brookeridge Air Park LL22
Downers Grove, IL 60516
630 985-8503
In a message dated 2/10/2006 9:31:26 A.M. Central Standard Time,
bakerocb(at)cox.net writes:
2/10/2006
wasted time.
OC
pwmac(at)sisna.com Guest
Posted: Fri Feb 10, 2006 9:06 am Post subject: antennas |
Curious why you did not mention a sat phone? They save lives all the time
all that is needed is a list of appropriate phone numbers. Cost is coming
down all the time and even used hand sets are available. Save your self
instead of depending on the system.
Regards, Paul
2/10/2006
wasted time.
OC
for it.
plane. Tim at b and
there
thin
n395v
Posted: Sat Feb 11, 2006 6:26 am Post subject: Re: antennas |
absolutely marvelous info filled discussion. Read the whole thread this am and learned a lot.
_________________ Milt |
jmfpublic(at)comcast.net Guest
Posted: Sat Feb 11, 2006 10:04 pm Post subject: antennas |
The problem of the ELT anntenna in a wood and fabric plane, or a composite one, is discussed in Jim Weir's RST anntenna book. He suggests two dipoles, driven by the same coax, and that is what I plan to do. The ground plane is best suited for an aluminum plane. The configuration looks like the letter X with one pair of legs about 1/3 of the other. I don't recall the exact dimenions, something on the order of 7 inches and 21 inches. Jim Weir suggests copper tape, but I prefer 0.032 or 0.016 thick brass as being much easier to handle and solder. This is available in the hardware store in widths of 1/4, 1/2, 3/4, and 1 inch. Best to tune this with an antenna analyser, of course.
Jim Foerster, J400, wiring
Posted: Sun Feb 12, 2006 8:46 pm Post subject: antennas |
At 10:02 PM 2/11/2006 -0800, you wrote:
Quote: |
<jmfpublic(at)comcast.net>
That would work too. Thanks for tossing that into the pile!
