proper timing procedure for an M14PF with M9F mags
isaligman(at)saligman.com
PostPosted: Fri Jun 08, 2007 7:02 am    Post subject: proper timing procedure for an M14PF with M9F mags Reply with quote
Does anybody have the proper timing procedure for an M14PF with M9F mags?
Ira Saligman
o 610 940 0420
c 610 324 5500
f 215 243 7699
isaligman(at)Saligman.com (isaligman(at)Saligman.com)
dsavarese(at)elmore.rr.co
PostPosted: Fri Jun 08, 2007 9:23 am    Post subject: proper timing procedure for an M14PF with M9F mags Reply with quote
Yes. The attached was published by George Coy of Gesoco several years ago. It is excellent.
Dennis
M14_TIMING_WITH_M9-35M_MAGS.DOC
 Filename:  M14_TIMING_WITH_M9-35M_MAGS.DOC
 Filesize:  21 KB
 Downloaded:  375 Time(s)
M_9_IGNITION_LETTER.PDF
 Filename:  M_9_IGNITION_LETTER.PDF
 Filesize:  122.26 KB
 Downloaded:  3645 Time(s)
jan.mevis(at)informavia.b
PostPosted: Fri Jun 08, 2007 1:28 pm    Post subject: proper timing procedure for an M14PF with M9F mags Reply with quote
Magnificent. Thanks a lot!
Jan
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of A. Dennis Savarese
Sent: vrijdag 8 juni 2007 19:22
To: yak-list(at)matronics.com
Subject: Re: proper timing procedure for an M14PF with M9F mags
Dennis
