engine mounts
jonboede(at)hotmail.com
PostPosted: Thu Jun 07, 2007 6:18 am    Post subject: engine mounts Reply with quote
I've noticed that the rubber in many of my engine mounts is getting pretty
ratty, so I'm up for changing it out.
Anybody have any experiencing doing this? We thought we'd just get a strap
and lift the engine a bit and replace the ones we can get to easily, but I
have that sneaking suspicion I get right before things don't go so well.
Smile
Jon
dsavarese(at)elmore.rr.co
PostPosted: Thu Jun 07, 2007 7:48 am    Post subject: engine mounts Reply with quote
Besides lifting the engine slightly to relieve the weight from the engine
mount rubbers, I'd suggest removing the generator and the magnetos. It will
make the job significantly easier. Before you remove the mags, remove any
grease or oil around the base of the mag where it mates with the accessory
case. Then using a Sharpie pen make 3 vertical marks between the base of
the magneto and the case about 1/4" to 3/8" apart. The marks will enable
you to reinstall the magnetos in precisely the same location and not have to
retime the magnetos. Replace one rubber mount at a time. The attached
document should help with how tight the plates, nuts and washers should be.
Dennis
DAMPERS_INSTALLING_MODEL_.PDF
 Filename:  DAMPERS_INSTALLING_MODEL_.PDF
 Filesize:  29.14 KB
 Downloaded:  238 Time(s)
PostPosted: Thu Jun 07, 2007 8:28 am    Post subject: engine mounts Reply with quote
Super-helpful, Dennis... THANKS!!
[quote]From: "A. Dennis Savarese" <dsavarese(at)elmore.rr.com>
Reply-To: yak-list(at)matronics.com
To: <yak-list(at)matronics.com>
Subject: Re: engine mounts
Date: Thu, 7 Jun 2007 10:45:20 -0500
will make the job significantly easier. Before you remove the mags, remove
any grease or oil around the base of the mag where it mates with the
accessory case. Then using a Sharpie pen make 3 vertical marks between the
base of the magneto and the case about 1/4" to 3/8" apart. The marks will
enable you to reinstall the magnetos in precisely the same location and not
have to retime the magnetos. Replace one rubber mount at a time. The
attached document should help with how tight the plates, nuts and washers
should be.
Dennis
