Posted: Tue Jun 12, 2007 4:45 am Post subject: Vent cutting |
anyone recommend a certain fly cutter to punch the hole in the canopy for the 3 1/2 vents? I am sweating that procedure.
Juan
rstone4(at)hot.rr.com Guest
Posted: Tue Jun 12, 2007 6:33 am Post subject: Vent cutting |
Juan,
On plexiglass a fine tooth hole saw might be a better tool to use if
you can find one with fine teeth that is the right size. I have ordered two
or I should say a pair of plastic vents from Aircraft Spruce that are
designed to go on the side of the canopy that will direct cool air to the
upper areas of the cockpit and I plan to use a hole saw to cut the required
hole in the canopy side. I will post the results with pictures on this
forum when the job is done.
Tracy Stone
Posted: Tue Jun 12, 2007 6:51 am Post subject: Vent cutting |
Hi Juan,
If it is similar to drilling through plexiglass I would recommend
using a hole saw and running it backwards. That way you burn through
the plastic and won't make cracks. Before using the saw, drill a
hole for the center using standard plastic drill or other zero rake
drill bit. If necessary, run it backwards too.
Paul
XL fuselage
At 05:44 AM 6/12/2007, you wrote:
Juan
Posted: Tue Jun 12, 2007 10:40 am Post subject: Vent cutting |
got it run it backwards, thanx.
juan
Posted: Tue Jun 12, 2007 10:41 am Post subject: Vent cutting |
that would be great. thanx
Posted: Tue Jun 12, 2007 3:31 pm Post subject: Vent cutting |
Well guys I ran into a litle trouble. When I used a hole saw or a fly
cutter on a piece of scrap plexiglass I found the center hole starts to
elongate and this causes the cutting edge of either tool to wander. I saw a
post where one member/builder used a flycutter and turned it by hand. I
will try this method next and report to the group as to how the cut turned
out. I have a feeling that the hand turning will work out. Since my dad,
Bob is retired, he will do the work since he has a lot more time than I do.
Tracy Stone
rickpitcher
Posted: Tue Jun 12, 2007 3:49 pm Post subject: Vent cutting |
If the problem is caused by the flutes of the pilot drill shaving the sides
of the pilot hole you migh try replacing the pilot drill with a 1/4" bolt.
Loosen the allen screw in the holesaw or flycutter and remove the drill bit.
Replace the drill bit with a 1/4" bolt.
grs-pms(at)comcast.net Guest
Posted: Tue Jun 12, 2007 3:58 pm Post subject: Vent cutting |
When using a hole saw or fly cutter on plexiglass, try replacing the drill bit in the center with a piece of drill rod of the same diameter. That should keep the center hole from elongating if you keep the drill speed slow.
George
