Posted: Sun Jun 03, 2007 2:22 pm Post subject: What to get with the wing kit recommendations |
I looked in the archives and couldn't quite find what I should order with the wings. I also looked at Tim's site and maybe missed this somewhere.
-Should I buy the strobes and positions lights now while building the wings?
-Should I get the options Van's offers? Float fuel sender units, landing lights?
- Should I get anything else?
I would also like recommendations of places to get things and part numbers/ links, etc... I know Deems rated the LED lights he got very highly, he also has a link for it, however that site also says to buy the power unit and position lights elsewhere. William Curtis has a link to Strobes n more and I saw a kit for $159..
In summary I am looking for what people bought, the place and part number and when they actually put them in the wings.
Thanks!
Pascal
ScooterF15
Posted: Sun Jun 03, 2007 2:38 pm Post subject: What to get with the wing kit recommendations |
I purchased everything from Van's with the wing kit: Aileron trim kit, Float senders, landing lights, strobe light kits, flap positioning system. They are all acceptable in my opinion and I am happy with them. Other options might be more attractive for various reasons, but I have no specific complaints.
I installed the flap positioning system while I still had my fuselage in my garage. The float senders and aileron trim need to be installed before hanging the wings; but the landing lights and wing strobes were just about the last thing I installed prior to DAR inspection (so you have plenty of time to figure that out).
You might want to consider if you want a heated pitot (I used the Falcon heated pitot and Gretz aero mount, both from Aircraft Spruce), and start thinking how the installation will work out before you get to that point in wing construction.
Jim
40134
In a message dated 6/3/2007 6:24:27 P.M. Eastern Daylight Time, rv10builder(at)verizon.net writes:
| Quote: | I looked in the archives and couldn't quite find what I should order with the wings. I also looked at Tim's site and maybe missed this somewhere.
Thanks!
Pascal
Jim "Scooter" McGrew
http://www.mit.edu/~jsmcgrew
See what's free at AOL.com.
rv10(at)sinkrate.com Guest
Posted: Sun Jun 03, 2007 3:39 pm Post subject: What to get with the wing kit recommendations |
Pascal,
Here is what I purchased while working on the wings.
From Van’s - Aileron trim
- Flap position system (don’t need until way later in the fuse kit)
- Fuel sending units
- Conduit
- Whelen taillight w/strobe
- ELT/Strobe Power Supply mounting kit
- Strobe wiring kit
- Qty 2 HID Duckworks landing lights
From Others - LED Nav & Strobe lights from Jeff (same as Deems)
- XPAK604X strobe power supply from Strobes N More. The mounting holes line up perfectly w/Van’s ELT/Strobe mounting kit.
- Gretz pitot mount from gretzaero (haven’t yet ordered my pitot still trying to decide which one).
None of the stuff really would be required to have with the wing kit if you didn’t rivet the bottom skins and waited to close up the fuel tanks you could add everything listed above at any time. That said though I would recommend fitting the gretz when you are fitting the bottom skins. The leading edge landing lights I thought would have been much tougher with the leading edges installed. If you plan on running conduit through the wing you want to oversize the holes in the ribs to fit the conduit where Van’s tells you to use the snap in bushings. Although possible to do while riveted in place it is much easier when the ribs are not attached to any structure. I drilled the inner rib holes slightly larger than the outside two ribs as this made it easier to thread the conduit through but still held tight on the ends. I didn’t write down the sizes I used so having the conduit early to gauge the hole sizes would be a plus.
I’m still on the fence regarding AOA but you might consider that with your wing kit if you plan on it. I already installed the stall warning mechanism from Van’s but if I were to get an AOA system I doubt I would use Van’s supplied stall warning kit.
Ben Westfall
#40579 Fuse Kit - Firewall
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Pascal
Sent: Sunday, June 03, 2007 3:22 PM
Subject: What to get with the wing kit recommendations
Thanks!
Pascal
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 01234
LarryRosen
Posted: Sun Jun 03, 2007 5:09 pm Post subject: What to get with the wing kit recommendations |
Don't forget the proseal It is the only thing you will need to
start. All the rest can wait.
The other items that others have mentioned will be needed more towards
the end of the wing build
Conduit (if you are going that route)
Gretz pitot mount (for a heated pitot tube)
Aileron trim
and then the lighting choices.
For landing lights I chose the the LoPresti boom beams that they
announced this year at S&F (the still do not have them listed on there
web site <http://www.speedmods.com>)
And for strobes and Nav lights I have the Whelen A650 style purchased
from vans. Whelen should be out with a 12 volt LED version with the
same form factor at OSH. I was told that the pricing will be very
similar to the A650. We could only hope.
Nav antennas in the wing tips (get them from Stein)
Marker beacon antenna, just a stripped piece of coax, in one of the tips
somewhere.
wings?
landing lights?
Thanks!
Pascal
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
dmaib@me.com
Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
Posted: Sun Jun 03, 2007 5:28 pm Post subject: What to get with the wing kit recommendations |
On Jun 3, 2007, at 8:07 PM, Larry Rosen wrote:
For landing lights I chose the the LoPresti boom beams that they announced this year at S&F (the still do not have them listed on there web site
Larry, I signed up for the LoPresti boom beams at SNF too. I have not received them yet and my credit card has not been charged. I emailed them last week and asked what the status is, but have not gotten an answer. Do you have any information?
David Maib
40559
Wings
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
DAVELEIKAM(at)wi.rr.com Guest
Posted: Sun Jun 03, 2007 7:25 pm Post subject: What to get with the wing kit recommendations |
I got all my lights from http://www.creativair.com/. HID landing lights, LED nav lights, wingtip strobes and power supply. Taillight/strobe from Vans. The HIDs, navs and wingtip strobes all fit under the wingtip lens. I will be installing them soon. No cutting the wing.
Dave Leikam
40496
QB wings
LarryRosen
Posted: Mon Jun 04, 2007 2:21 pm Post subject: What to get with the wing kit recommendations |
I just got of the phone with speed mods and they just got engineering
approval for a modification that tweaked the reflectors and they should
start shipping kits this week.
Larry Rosen
#356
David Maib wrote:
web site
David Maib
40559
Wings
#40356
N205EN (reserved)
<http> |
dmaib@me.com
Posted: Mon Jun 04, 2007 8:00 pm Post subject: What to get with the wing kit recommendations |
Thanks for the information Larry.
David Maib
40559
On Jun 4, 2007, at 5:20 PM, Larry Rosen wrote:
engineering approval for a modification that tweaked the reflectors
and they should start shipping kits this week.
Larry Rosen
#356
> there web site
> David Maib
> 40559
> Wings
RV-10 #40559
