gmcjetpilot(at)yahoo.com Guest
Posted: Thu Feb 09, 2006 8:59 am Post subject: RV fuel per hour and heat (Low power cruise) |
As long as the engine is in normal limits as Lycoming recommends. Off the top of my head 280 CHT, Oil Temp 190/180 min. There is not truth to doing damage as long as you get it hot enough. Sure you need to check it makes full power, but that happens every takeoff. I am not a fan of babying it on take-off but that would be the next step in fuel saving. Do you need 2000 fpm climb?
Check Lycomings key reprints. They address this.
http://www.lycoming.textron.com/main.jsp?bodyPage=support/publications/keyReprints/operation/lowPowerLowRPM.html
Here is the other operational articles that has good info on power settings.
http://www.lycoming.textron.com/main.jsp?bodyPage=/support/publications/keyReprints/operation.html
So what do you all think about de-rated takeoffs? I guess if the runway is long and there are no obstacles, but I tend to want to get as high as fast as possible. ON the other hand a Cessna C150 is crawling up at 500 fpm all the time.
George
Hi Jerry,
I usually run my O-320 powered RV6 at 2250 rpm with a Sensenich 79"
prop and get great economy as well as good speed -
like around 6 US gals per hour at 135 kts.. I too have been told to be
aware of burning up the engine, most notably the exhaust valves, as
well as glazing the bores. I don't really see how, as my CHT's are all around
310-315 deg F, and the engine is producing approx 55% power. I know we
didn't build our RVs to go slow, but it is relative, and the fuel
savings are nice. Cheers Martin in Oz
Brings words and photos together (easily) with
ronlee(at)pcisys.net Guest
Posted: Thu Feb 09, 2006 9:55 am Post subject: RV fuel per hour and heat (Low power cruise) |
| Quote: | Do you need 2000 fpm climb?
Why not? Your first article discussed ways to save fuel. One way
is to cut flying. I don't intend to fly 300 hours this year. But I will
cruise at normal speeds when I do. And I buy gas where it is
cheaper.
I agree. Get up to cruising altitude. Full Throttle for a few minutes
is not going to cost that much gas. Personally, if you are worried
about that amount either sell the plane or cut back a few hours.
It is like buying a Yugo to save gas. Not me. I prefer large pieces
of metal around me when I drive and if I have to pay more for gas,
so be it. Safety is the higher priority.
Ron Lee
bicyclop(at)pacbell.net Guest
Posted: Thu Feb 09, 2006 10:45 am Post subject: RV fuel per hour and heat (Low power cruise) |
| Quote: | So what do you all think about de-rated takeoffs? I guess if the
George
George,
De-rated takeoffs at low elevations are probably a bad idea because the
carburetor (and I think fuel injection systems also) run richer at full
throttle than when slightly retarded to increase the detonation margin.
You run the risk of operating too lean and closer to the detonation
margin when at higher than 75% power and low fuel flow. If you were to
use a power setting below 75%, perhaps that would be a non issue.
At higher altitude airports, your takeoff power is automatically
de-rated by lower air pressure and you may have to lean to achieve
maximum available power. Because you're operating below 75% at anything
above around 7500' density altitude (and normally aspirated), it's
harder to make it detonate by leaning.
I like the idea of maximum terrain clearance as soon as possible for
purposes of having more time in case of power failure. This calls for
full available power for takeoff and initial climb. Power can be reduced
when you feel you're high enough to have viable engine out options. YMMV
Pax,
Ed Holyoke
