dosmythe(at)cox.net Guest
Posted: Sun May 27, 2007 10:35 am Post subject: 582 Engine Tick |
Oh well, I had a feeling something would come back on me. Last week, when the new buyer and I were test flying the engine gave out a few Tick sounds like a fouled plug. I changed the plugs before delivery today and he made a successful 100 mile flight with no problems. When he descended from 4500' at his location the Tick's started to come back. Assuming this is another fouled plug, what could be causing this on such a short time? I've never experienced this situation except for one other time when it was for sure a fouled plug. Any ideas?
Don Smythe
Classic IV w/582 (sold)
Newport News, Va.
Posted: Sun May 27, 2007 1:33 pm Post subject: 582 Engine Tick |
Don,
You are supposed to have today off! Congrats on .....
no, I can't say it. Still sorry your plane is gone.
Selfish, I know.
Normally a rich running or oil burning engine fouls
the plugs, but on 2 cycles, other ignition problems
are more common than on 4 cycle engines. I think that
since you have oil in the gas, the 2 cycle engine are
designed to be better able to handle some fouling and
that leaves the other ignition problems a bit more
likely, by percentage, than on a 4 cycle. At least
that has been my experience.
Plug gap? Plug color? All OK?
So have him check the timing and spark plug wires too.
Make sure a good connection is there and no arcing
from a wire to some ground. If he has a timing light,
check each plug wire when it is running to see where
the miss is. A little harder to check for weak
ingition, but that may do it too.
The usual suspects I am afraid. But you and I may be
the only ones here, so thought I would at least say
"Hello"
Kurt S.
S-5/NSI turbo
--- Don Smythe <dosmythe(at)cox.net> wrote:
| Quote: | Oh well, I had a feeling something would come back
ideas?
Don Smythe
Newport News, Va.
Check out fitting gifts for grads at Yahoo! Search
http://search.yahoo.com/search?fr=oni_on_mail&p=graduation+gifts&cs=bz
Tom Jones
Joined: 12 Mar 2006 Posts: 752 Location: Ellensburg, WA
Posted: Sun May 27, 2007 2:31 pm Post subject: Re: 582 Engine Tick |
Don, my engine is a 503 Rotax but has the same carbs as yours. When I reduce throttle to the mid range the needle controls the mixture. I have the arctic sparrow adjustable needles and richen a turn or two to keep the EGT's down when I descend with the throttle in the mid range. When it starts to get a little too rich the engine "ticks" (four strokes).
It took me a while to figure out what was causing this sound. It could be a rich mid range (needle adjustment) in his carbs???
_________________ Tom Jones
Classic IV
Ellensburg, WA |
Lynn Matteson
Posted: Sun May 27, 2007 4:02 pm Post subject: 582 Engine Tick |
Could this ticking sound be the sound of the exhaust pipes cooling
off due to the rich mixture?
Lynn Matteson
flying w/293+ hrs
On May 27, 2007, at 6:31 PM, Tom Jones wrote:
Tom Jones
Classic IV, Phase one
503, Warp
Ellensburg, WA
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Tom Jones
Posted: Sun May 27, 2007 5:14 pm Post subject: Re: 582 Engine Tick |
| Quote: | Could this ticking sound be the sound of the exhaust pipes cooling
off due to the rich mixture? |
The "Ticking" I was referring to is the very eary stages of a 2 cycle engine beginning to 4 cycle because it is too rich...I think. It is not missing every other stroke yet but once every second or two, or three I confirmed by leaning the needles one turn and the "Ticking" stopped. This was during my first two flights so any unususal sounds caught my immediate attention.
Classic IV
Ellensburg, WA |
Posted: Sun May 27, 2007 5:27 pm Post subject: 582 Engine Tick |
Tom,
I will work toward this direction of thought. I'll also rephrase the
"Ticking". The tick is in conjunctions with an engine miss. It was very
intermittent and not present on the ground at idle or taxi. Rather than a
tick it was a slight bump like an engine miss. A bit hard to explain.
Today it occurred during his long decent from over 4000' I assume he was
throttled back but the mixture was probably on the rich side.
Don Smythe
Newport News, Va.
Tom Jones
Posted: Sun May 27, 2007 5:44 pm Post subject: Re: 582 Engine Tick |
| Quote: | | it was a slight bump like an engine miss. |
This describes the sound I referr to exactly.
Classic IV
Ellensburg, WA |
Malcolmbru(at)aol.com Guest
Posted: Sun May 27, 2007 7:05 pm Post subject: 582 Engine Tick |
I called Jerry at Green sky about something very similar and he described it to me this way. Don't worry about it. between the way the muffler is chopped ,the motor mounts , jetting, it just sets up a vibration at a certain RPM that makes it feel that way. sometimes I think I feel like the rutter is being hit buy something . I just don't fly it in that configuration.the cdi ignition ether works or it don't. ether way you need to cut the cord with this guy man. it is his plane now let him join the list and make the call's. mal
See what's free at AOL.com.
dwight purdy
Don
I try to never pull the power clear back till short short final. This way
I can keep the egt above 1000 to 1100 till then. Is this new owner
experienced with two stroke flying? Were you burning 100LL?
Dwight Purdy
503 model ll
Marion IN
At 09:27 PM 5/27/2007 -0400, you wrote:
Tom,
a tick it was a slight bump like an engine miss. A bit hard to explain.
Don Smythe
Newport News, Va.
_________________ dwight
model II |
thesupe(at)hotmail.com Guest
Posted: Sun May 27, 2007 7:30 pm Post subject: 582 Engine Tick |
What were the EGT temps when it was makeing the tick? My guess is that they
were on the low side. It sounds to me like the midrange is to rich. I'm
not an expert but I have been flying these two strokes for about 7 years in
various different UL/airplanes and have heard the same noise (miss) when I
got to rich. Just my two cents worth. Thanks
Jim Chuk
Avid MK IV, Avid B
both 582
[quote]From: "Don Smythe" <dosmythe(at)cox.net>
Subject: Re: Re: 582 Engine Tick
Date: Sun, 27 May 2007 21:27:18 -0400
Tom,
Don Smythe
Newport News, Va.
RRTRACK(at)aol.com Guest
Posted: Mon May 28, 2007 5:05 am Post subject: 582 Engine Tick |
The spark plug caps can go bad. And there has been warnings about using resistor caps with resistor plugs.
Mark
Hartford, Wisconsin
Kitfox 5 Vixen 912 UL
(hundreds of hours behind a 582)
rjdaugh
Posted: Mon May 28, 2007 2:50 pm Post subject: 582 Engine Tick |
Tom said;
"It took me a while to figure out what was causing this sound. It could be
a rich mid range (needle adjustment) in his carbs???"
I don't understand the sound, but what altitude is your plane at now Don?
Is that why it is rich?
Randy
_________________ Randy
Kitfox 5/7 912S
Black Hills, South Dakota |
Posted: Mon May 28, 2007 5:09 pm Post subject: 582 Engine Tick |
This isn't necessarily a sound. It isn't necessarily a feeling. Have you
ever gone down the highway in you car and have the engine miss? It's all a
bit of a sound, jerk, feeling, noise????. In other words, how on earth do
you describe an engine miss????
The altitude is at the same altitude it was when it left my home field
+/- 100'
Don Smythe
Newport News, Va.
