PatrickW
Joined: 27 Oct 2006 Posts: 380 Location: Fort Worth, Texas
Posted: Wed May 23, 2007 9:41 am Post subject: More Press Coverage on G-YOXI |
http://www.wakefieldtoday.co.uk/news?articleid=2887236
Quotes:
“The accident was not survivable. The aircraft structure failed as a result of excess loads being applied; the breakage appears to have occurred at the most vulnerable point of the wing."
“The evidence is incomplete, but the aircraft was probably operating at, or close to, its weight and balance limits.”
"In May 2005 he bought the light aircraft, the Zenair G-YOXI as a quick build kit from Czech Aircraft Works."
"Half of the plane, including the wings and the fuselage, had been pre-constructed in the factory."
Just sharing some information with fellow builders in our group here. Forgive me for beating this horse or kicking up a hornet's nest.
I am currently working on my 601's wings, and remain confident in the design when operated withing normal parameters.
Didn't Zenith cut their ties to CZAW a while back...?
Patrick
601XL/Corvair
Gig Giacona
Posted: Wed May 23, 2007 10:15 am Post subject: Re: More Press Coverage on G-YOXI |
And the most important part...
| Quote: | | They had pulled up sharply as they approached some power cables, causing the wing spar to snap. |
601XL Under Construction
321PT
Posted: Thu May 24, 2007 6:19 am Post subject: More Press Coverage on G-YOXI |
Zenith and Czech Aircraft Works have parted company... seemed to be a mutual deal, since CZAW was designing and producing there own planes.
http://www.airplane.cz/zenair.htm
CH 701, 321PT, Czech built
Posted: Sun May 27, 2007 3:58 am Post subject: More Press Coverage on G-YOXI |
At 10:41 AM 5/23/2007, you wrote:
| Quote: | Didn't Zenith cut their ties to CZAW a while back...?
Yes, but . . . I wouldn't have chosen that way to describe the
break-up. CZAW stopped making Zodiacs around the same time as they
introduced their own line of airplanes including one similar in
outward appearance to the Zodiac. They also introduced the Parrot and Mermaid.
Paul
XL fuselage
