johnd(at)data-tech.com Guest
Posted: Thu May 31, 2007 9:16 am Post subject: Flap Actuator Mount question |
Hi,
I have a 601XL quickbuild which has come with a newer Flap actuator than
the mount (6B19-10) was designed for, in particular the width of the
tabs on the mount through which the actuator itself bolts is much bigger
than the new actuator needs.
Can I use the current mount (which is already in place) and use spacers
on the longer bolt between the edges of the flap actuator and the mount
to keep it from moving horizontally or should I really replace the mount
with the proper one. Oddly enough the kit did come with the proper one
loose but the one thats installed has the wider spacing.
Thoughts ?
John Davis
Burnsville, NC
601XL QB - Jab 3300
DaveG601XL
Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
Posted: Thu May 31, 2007 11:01 am Post subject: Re: Flap Actuator Mount question |
Personally it would not bother me a bit if the space you needed to take up was only a few washers worth. Ask your Tech Counselor or ZAC. I have the new actuator and bracket so I don't know how wide the original was.
Good Luck.
_________________ David Gallagher
Cincinnati, OH area |
dredmoody(at)cox.net Guest
Posted: Thu May 31, 2007 4:45 pm Post subject: Flap Actuator Mount question |
My guess is that you should use the loose proper fitting one. Have you contacted the factory about it yet?
Dred
---- John Davis <johnd(at)data-tech.com> wrote:
Hi,
Thoughts ?
John Davis
Burnsville, NC
601XL QB - Jab 3300
