eskflyer
Posted: Fri May 25, 2007 12:02 am Post subject: WANTED 8 inch WHEELS and HUBS |
I am looking for the 8 inch wheels and hubs for the kitfox . I have a almost new 3 blade 68" GSC with spiiner polished and back plate and new prop bolts for trade . or let me know your price if you have these .
John Perry
eskflyer[AT]yahoo.com
580-695-8778
ksridsdale(at)mipowerpara Guest
Posted: Fri May 25, 2007 12:40 am Post subject: WANTED 8 inch WHEELS and HUBS |
John,
We have the 8" wheels with brakes I have attached
photos of the wheel and brake developed for use with
the King Fox 21x12x8 inch tires. This wheel is 6
inches wide between the flanges and can be run
tubeless. The model number is MHE8B-600. It uses and
external caliper brake that is rated at 2200 in-lb at
450 psi. It uses 1.25 inch tapered roller bearings
and each wheel is rated at 750 lb static load with a 3
G overload ultimate load. We will have more details
on it posted on our website in the near future. The
cost is $600.00 plus shipping.
We also have our wheel and hub conversion package
without brakes. This packaged was developed for use
with the King Fox 21x12x8 inch tires and can be run
tubeless. The model number is DWE8B-300.It hub uses 2
SFL roller bearing size either 3/4" or 5/8" to be
specified at time of ordering. The cost is $300.00
plus shipping. Please remember we are the
manufacturers of the King Fox tire.
Thanks for your inquiry
Kevin R.
MiPPi Ultralights
734-377-2670
--- eskflyer <eskflyer(at)yahoo.com> wrote:
these .
John Perry
580-695-8778
http://forums.matronics.com/viewtopic.php?p=114681#114681
akflyer
Posted: Sat May 26, 2007 3:38 pm Post subject: Re: WANTED 8 inch WHEELS and HUBS |
do the wheels and hubs come with the brake disk? Are these a two piece hub like a Matco or conventional aircraft wheel, or a ATV wheel on a hub adapter. The pic did not come through so you may try posting it again..or my computer may be dumb/blind and not seeing it..
_________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
