nuckollsr(at)cox.net Guest
Posted: Fri May 25, 2007 7:22 pm Post subject: Is there a need for a heatsink for the B&C e-buss diode? |
At 10:37 AM 5/24/2007 -0700, you wrote:
| Quote: | Hi Group:
Quick question: Is there a need for a heatsink for the B&C e-buss
diode? I am mounting the diode on .065 aluminum sheet under the glare
shield. Would that suffice? If I need a heat sink, what size?
What's your e-bus loads? For 10A or less, mount to any metal surface.
Also, what is the most economical/elegant way to step down 12.8 volt
ship's power to 5 volts for an "avionics" cooling fan (i.e., a computer
cooling fan from Radio Shack)? Thanks,
Go with a 12v fan.
http://mpja.com/listitems.asp?dept=48&main=46
http://tinyurl.com/ypxuaw
http://dkc3.digikey.com/PDF/T072/2002.pdf
http://dkc3.digikey.com/PDF/T072/2004.pdf
Three pages of stuff here:
http://dkc3.digikey.com/PDF/T072/2006-2009.pdf
http://tinyurl.com/2u3db7
( "Physics is like sex: sure, it may )
( give some practical results, but )
( that's not why we do it." )
( Richard P. Feynman )
