richvetterli(at)yahoo.com Guest
Posted: Sat May 26, 2007 7:48 pm Post subject: Lower engine mounts |
Has anybody had trouble fitting the lower engine
mounts? When they are attached to the firewall as per
the plans, but the mounts don't seem to quite center
over the lower longerons. It seems that the front
angle of the brackets are a little too flat and they
don't want to follow the angle of the longerons. With
a little force, I can spread them out a little, but
that doesn't seem right on such a critical part. Any
ideas?
Rich Vetterli
601XL/Corvair
Check out my progress at: www.geocities.com/stixx5a
http://farechase.yahoo.com/
gboothe5(at)comcast.net Guest
Posted: Sun May 27, 2007 5:04 am Post subject: Lower engine mounts |
Rich,
That might be a better question on the Corvair List, but it seems to me that
William has said that that is normal and of little concern....guess it
depends on how far off the holes were.
Gary Boothe
Cool, CA
601 HDSTD, WW Conversion 90% done,
Tail done, wings done, working on c-section
Posted: Sun May 27, 2007 5:49 am Post subject: Lower engine mounts |
Richard,
The conventional thing is to off set the engine angle to compensate for
propeller torque and perhaps this is
what you're looking at. My Subaru is pivoted 2-1/2 degrees from the
front propeller mounting flange swinging
the rear of the engine to keep the prop centered on the completed cowl
nose.
If it's a case of a tensioned fit, you need to specify how much flex is
required for the task. In some cases, where a mount
is not quite right, the part can be flexed to a correct position and
then a torch is used to relieve the pressure at the area
of bend. One has to be careful during this kind of operation though to
not use too much heat and to be sure it's properly
placed. I looked at the mount picture on your site. You might want to
consult with WW on this design specific area.
Very nice site by the way.
Larry McFarland at www.macsmachine.com
Richard Vetterli wrote:
ideas?
Rich Vetterli
601XL/Corvair
Posted: Sun May 27, 2007 6:46 am Post subject: Lower engine mounts |
Coincidentally I was drilling holes in my lower engine mounts last night. I
think the other responders have missed the mark. This has nothing to do with
what is forward of the firewall. On *one* of my mounts if you stick a washer
and nut on the mount bolt (forward of the firewall) and tighten it then the
bracket to the rear of the firewall does not align with the lower longeron.
In other words it is impossible to put the two small AN3 bolts through the
bracket and longeron in a way that respects edge distances. On the other
mount when I do this the bracket aligns with the longeron and I can center
the two AN3s laterally in the bracket and longeron.
The latest lower motor mounts come undrilled and the mount bolt is not
welded on. So I see two places where adjustment can be made. You can adjust
the position of the hole for the mount bolt side-to-side to best align the
bracket with the longeron. And you can bend the bracket a little. I agree,
bending such a critical part makes me uneasy too. I think it is worth a
query to the factory.
One question I have is that since we are dealing with an AN3 bolt through a
piece of 0.050" 4130 steel and not a rivet in a piece of thin 6061-T6
aluminum what is the minimum edge distance?
-- Craig
Posted: Sun May 27, 2007 7:39 am Post subject: Lower engine mounts |
Craig,
The stress tolerated by an edge distance of one bolt diameter is 2 x
.050 times the minimum actual distance from
the .375 hole to the edge of a 70K material. Or in this case, approx
2625 lbs using 70K as an understated base material
strength, given that it's been welded and adjusted, etc. How that is
affected by loading depends on the engine weight and shared loads of
other connections. For steel, these details have to be calculated to
minimize weight versus strength for required loads.
I don't believe there is a rule of thumb here as set out by CH and the
Mfr community for riveted aluminum connections.
Larry McFarland
Craig Payne wrote:
| Quote: | One question I have is that since we are dealing with an AN3 bolt through a
-- Craig
