Baggage floor
wjones(at)brazoriainet.co
PostPosted: Tue May 22, 2007 4:01 am    Post subject: Baggage floor Reply with quote
Hello group ,question .When riveting the baggage floor onto the side "L" angles the top longerons interfere with the rivet gun .How is this best handled . Thanks   Wade Jones South Texas
601XL plans building
Cont. 0200
rogers_pritchard(at)yahoo
PostPosted: Tue May 22, 2007 5:20 am    Post subject: Baggage floor Reply with quote
Wade,
Rivet the rear most L angels to the floor first and use a hand rivet gun with the nose
piece ground on one side to fit in close where it will fit under the longeron.
Roger, also in NH
wade jones <wjones(at)brazoriainet.com> wrote:
[quote] Hello group ,question .When riveting the baggage floor onto the side "L" angles the top longerons interfere with the rivet gun .How is this best handled . Thanks Wade Jones South Texas
601XL plans [url=http://us.rd.yahoo.com/evt=48226/*http://new.toolbar.yahoo.com/toolbar/features/norton/index.php]Get the free Yahoo! toolbar[/url] and rest assured with the added security of spyware protection. [quote][b]
heatonhe36(at)msn.com
PostPosted: Tue May 22, 2007 5:40 am    Post subject: Baggage floor Reply with quote
Wade,
I riveted the side "L" angles to the baggage floor first, then the assembly
can be folded about the center line and positioned under the longerons.
Herb
Cont. 0200
Jaybannist(at)cs.com
PostPosted: Tue May 22, 2007 7:29 am    Post subject: Baggage floor Reply with quote
I did the same, except that I went one step further. I split the baggage floor down the middle to ease the handling (w/ ZAC approval). I riveted an .025 doubler under the seam. Sure made it easier to manage.
Jay in Dallas
"Herbert Heaton" <heatonhe36(at)msn.com> wrote:
Wade,
Herb
>Cont. 0200
billsewell(at)gmail.com
PostPosted: Tue May 22, 2007 7:40 am    Post subject: Baggage floor Reply with quote
I riveted the L angles to the baggage floor and then installed the baggage floor into the fuselage and riveted the side skins to the angles. Leave the baggage floor traverse L angles off until the floor is installed. This way, you can bow the baggage floor to get it under the top longerons.
Bill Sewell
N601BZ
On 5/22/07, wade jones <wjones(at)brazoriainet.com (wjones(at)brazoriainet.com)> wrote: [quote] Hello group ,question .When riveting the baggage floor onto the side "L" angles the top longerons interfere with the rivet gun .How is this best handled . Thanks Wade Jones South Texas
Cont. 0200
DaveG601XL
PostPosted: Tue May 22, 2007 7:45 am    Post subject: Re: Baggage floor Reply with quote
I did what Jay did and split the floor down the middle. If my attached picture worked, you can see the double row of cleco's where I substituted a u-channel for the L-angle. The aft floor will have the side L-angles riveted to it before placing the floor in the fuselage due to the longeron proximity. The forward baggage floor will be left un-riveted until close to the end.
Good luck,
 Filesize:  187.38 KB
 Viewed:  515 Time(s)
David Gallagher
Cincinnati, OH area
Gig Giacona
PostPosted: Tue May 22, 2007 8:57 am    Post subject: Re: Baggage floor Reply with quote
Damn, I wish I'd thought of that. Sad
Jay in Dallas
W.R. "Gig" Giacona
601XL Under Construction
PostPosted: Tue May 22, 2007 5:34 pm    Post subject: Baggage floor Reply with quote
Thanks to all that replied to my baggage floor problem .I got some good ideas from you .I have spent too much time in this area , seems more difficult than it should be . Thanks again.
Cont. 0200
