HShack(at)aol.com Guest
Posted: Tue May 15, 2007 4:36 pm Post subject: FireFly prop & others |
In a message dated 5/15/2007 11:54:29 AM Eastern Daylight Time, etzim62(at)earthlink.net writes:
| Quote: | But a two blade prop will out perform a three blade every time when
everything is optimized, especially prop diameter and prop speed |
Outperform? What does that mean? I have a FS II, 503DCDI, 3.47:1 C Box, & 68" 3 blade Kiev prop; weight of plane is 470 [wet] & I was 275 when the following results were obtained:
Outclimbed & outran 2 other FS II's; one was grossed same as mine & one 70 lbs lighter. Both had B boxes & with 2 blade props.
The results were the same when I ran a 3 blade Warp, 68" w/ taper tips.
YMMV
Howard Shackleford
FS II
SC
See what's free at AOL.com.
Eugene Zimmerman
Posted: Tue May 15, 2007 7:02 pm Post subject: FireFly prop & others |
Hey, I don’t doubt your experience.
I assume you concluded, based on your experience, that a three-blade
prop will always have the potential to out climb and out run a two
blade?
A prop blade is simply a rotating wing and the reason a two blade
will always have the "potential” for better performance is the same
reason high performance sailplanes never have bi-wings.
Performance is maximized by minimizing performance robbing drag
created by the wing tip vortices. A long high aspect wing has better
performance than a shorter bi-wing because the bi-wing has twice as
many drag creating wing tip vortices.
On May 15, 2007, at 8:27 PM, HShack(at)aol.com wrote:
| Quote: | I have a FS II, 503DCDI, 3.47:1 C Box, & 68" 3 blade Kiev prop;
were obtained:
tips.
ElleryWeld(at)aol.com Guest
Posted: Tue May 15, 2007 7:05 pm Post subject: FireFly prop & others |
You should show the other guys how to set there Prop ?
Ellery
See what's free at http://www.aol.com. [quote][b]
Posted: Tue May 15, 2007 7:39 pm Post subject: FireFly prop & others |
In a message dated 5/15/2007 11:06:03 PM Eastern Daylight Time, ElleryWeld(at)aol.com writes:
| Quote: | You should show the other guys how to set there Prop ?
Ellery |
No, some of them have concluded they need to duplicate my setup; others are quite happy with less than optimal performance.
Howard Shackleford
FS II
SC
d-m-hague(at)comcast.net Guest
Posted: Wed May 16, 2007 2:54 am Post subject: FireFly prop & others |
At 11:01 PM 5/15/2007, Eugene Zimmerman wrote:
Actually it's not the wing tip vortices. A biplane is less efficient
because of interference between the wings; the closer together the more
interference. Similarly, the close together the prop blades are (i.e. 3
blade vs. 2 blade) the more interference.
Wing top vortices are part of induced drag, which depends on aspect
ratio. If you could build a biplane with the same aspect ratio for each
wing as the sailplane, AND get them sufficiently far apart for no
interference, you'd get the same performance... but you CAN'T get them far
enough apart, practically speaking, and then there's the drag of supporting
structure, etc...
-Dana
Okay, who put a "stop payment" on my reality check?
jim
Posted: Wed May 16, 2007 5:52 am Post subject: FireFly prop & others |
Then why is a high-bipass turbofan so efficient? These are found on
747-767 and are just a whole bunch of ducted short propeller blades.
-Dana
_________________ Jim
N. Idaho |
JetPilot
Posted: Wed May 16, 2007 8:24 am Post subject: Re: FireFly prop & others |
| jim wrote: |
-Dana |
A high bybpas turbofan is NOT efficient. If you look at a jet compared to a prop plane, there is no comparison in in efficiency, the prop wins every time. Where did you get the idea that a turbofan is so efficient , by comparing it to a turbojet, which is even less efficient
It is well known that a 2 blade prop is more efficient than a 3 blade. The problem is that there is not always room for a long 2 blade prop, or noise is more of an issue etc. etc. But the 2 blade is more efficient.
If someone outclimbed someone else with a 3 blade prop, making the assumption that it was because of having a 3 bladed prop is just dumb. Ever think it could have been variations in the airplane, pilot technique, or a hundred other possible factors ???
Kolb MK-III Xtra, 912-S |
Posted: Wed May 16, 2007 8:33 am Post subject: FireFly prop & others |
At 09:52 AM 5/16/2007, Jim Dunn wrote:
Well, that's a different situation. You can't really compare that to a
prop on a low speed aircraft; you have to compare it to a conventional
turbofan or a pure jet engine... and it IS larger than those. Also a
ducted fan is very different; the duct eliminates the tip vortices so the
aspect ratio isn't as significant. Ducted fans (and jets for that matter)
aren't very efficient at low airspeeds.
-Dana
Posted: Wed May 16, 2007 5:06 pm Post subject: FireFly prop & others |
In a message dated 5/16/2007 12:25:46 PM Eastern Daylight Time, orcabonita(at)hotmail.com writes:
| Quote: | If someone outclimbed someone else with a 3 blade prop, making the assumption that it was because of having a 3 bladed prop is just dumb. Ever think it could have been variations in the airplane, pilot technique, or a hundred other possible factors ???
Mike |
It must be me you're calling dumb. I never said it was the 3 bladed prop that allowed me to outclimb them- just that I did, using certain parameters,ie. brand, # blades, & length of prop, & ratio of PSRU.
By the way, I also usually burn less gas than them on a given trip.
Howard Shackleford
FS II
SC
Posted: Sun May 20, 2007 9:50 am Post subject: FireFly prop & others |
Actually, they aren't that efficient; they are just better than turbines
without the bypass. They would be a lot more efficient if you could put
a 2 blade prop on them, but a 2-blade big enough to absorb that much hp
would probably have a larger diameter than the plane & weigh more than
the plane, too.
The entire *system* is efficient, but that's because of extremely low
drag, extreme span-loading of the wings, flying at extreme altitude, etc.
Jim Dunn wrote:
-Dana
captainron1(at)cox.net Guest
Posted: Sun May 20, 2007 12:28 pm Post subject: FireFly prop & others |
I think the point he is trying to make and legitimately so is that; if a two blade prop was so efficient you would have a 2 blade fan section. Obviously a multi fan is more efficient considering the space allocated and the parameters in which it operates. Its an important distinction to make. As someone else pointed out in a perfect world many things would be different.
In an imperfect world you create perfection through adaptation for the task you need to perform. One of those things is a multi blade prop. I can see where theoretically a two blade is superior however in real life it is almost never the case. In real life almost always a 3 blade prop is superior performance wise to a two blade prop and a 4 blade prop is most times superior to 3 blade prop. Its hard to win against a theoretical argument, the only way to "win" is to do a real world comparison when all the real factors that exist including bugs and paint chipped off the leading edge come into play.
I will install a 4 blade prop on my M3X and then I will try a 2 blade prop I will be surprised if I get better performance at *any* flight regime with the 2 blader.
Ron
---- JetPilot <orcabonita(at)hotmail.com> wrote:
--> Kolb-List message posted by: "JetPilot" <orcabonita(at)hotmail.com>
jim wrote:
-Dana
A high bybpas turbofan is NOT efficient. If you look at a jet compared to a prop plane, there is no comparison in in efficiency, the prop wins every time. Where did you get the idea that a turbofan is so efficient , by comparing it to a turbojet, which is even less efficient [Laughing]
jindoguy(at)gmail.com Guest
Posted: Sun May 20, 2007 1:15 pm Post subject: FireFly prop & others |
Consider the original Supermarine Spitfire Mk 1, #5054, had a two blade prop. By the Mk IX it was running a four blade prop and by the Mk XIV, with the RR Griffon engine replacing the Merlin, it was running a five blade. The difference in speed between the Mk I and the Mk XIV was almost 100 MPH. The difference in HP was a bit over 800 between the two and the extra three blades were required to soak it up.
Rick
On 5/20/07, Ron <captainron1(at)cox.net (captainron1(at)cox.net)> wrote:[quote]
Ron
---- JetPilot <orcabonita(at)hotmail.com (orcabonita(at)hotmail.com)> wrote:
--> Kolb-List message posted by: "JetPilot" <orcabonita(at)hotmail.com (orcabonita(at)hotmail.com)>
jim wrote:
-Dana
[quote][b] http://www.matronics.com/Navigator?Kolb-List http://forums.matronics.com
possums(at)bellsouth.net Guest
Posted: Sun May 20, 2007 2:39 pm Post subject: FireFly prop & others |
At 04:27 PM 5/20/2007, you wrote:
| Quote: | I think the point he is trying to make and legitimately so is that;
Ron
We tried a 6 blade - double 3 blade - prop on one of ours that had enough
house power to turn it and it didn't do worth a crap.
flykolb(at)pa.net Guest
Posted: Sun May 20, 2007 2:44 pm Post subject: FireFly prop & others |
Hi Ron and Kolbers,
Over the many years at TOK I experimented with many different 2 and 3 blade propellers on the FF, FS, TS, M2, M3, SS and Laser. It is my recollection that a 2-blade would be faster than a 3-blade every time. The only reason we would run a 3-blade was for their typically smoother operation. I used the same aircraft for speed runs using a stopwatch to measure the speed over our 3,000 ft runway. This was done in zero-to- minimal wind conditions – usually late evenings - and I would average the run in both directions. This gave very repeatable results. This was my experience - I’ll let others debate the theory.
Dennis
From: owner-kolb-list-server(at)matronics.com [mailto:owner-kolb-list-server(at)matronics.com] On Behalf Of Ron
Sent: Sunday, May 20, 2007 4:28 PM
Subject: Re: Re: FireFly prop & others
Ron
> -Dana
| Quote: | | http://www.matronics.com/Navigator?Kolb-List | 01234
Posted: Sun May 20, 2007 4:56 pm Post subject: FireFly prop & others |
| Quote: | >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
Over the many years at TOK I experimented with many different 2 and 3 blade propellers on the FF, FS, TS, M2, M3, SS and Laser. It is my recollection that a 2-blade would be faster than a 3-blade every time. The only reason we would run a 3-blade was for their typically smoother operation. I used the same aircraft for speed runs using a stopwatch to measure the speed over our 3,000 ft runway. This was done in zero-to- minimal wind conditions usually late evenings - and I would average the run in both directions. This gave very repeatable results. This was my experience - Ill let others debate the theory.
Kolbers,
If you keep the same propeller diameter and switch from a two to three blades and set the engine to top out at the same rpm, the two blade will cruise faster due to greater pitch. The three blade will climb better.
Jack B. Hart FF004
Winchester, IN
Posted: Sun May 20, 2007 5:18 pm Post subject: FireFly prop & others |
Yes we will get to a point of diminishing returns, however with more blades you will need to optimize the diameter of the blades (smaller) etc.. The only drag increase that I can off hand think of is parasitic drag etc... However its of minor significance and the multi blade better radial efficiency during flight should more than compensate for it.
Ron (Arizona)
---- possums <possums(at)bellsouth.net> wrote:
--> Kolb-List message posted by: possums <possums(at)bellsouth.net>
Ron
house
Posted: Sun May 20, 2007 7:14 pm Post subject: FireFly prop & others |
At 05:15 PM 5/20/2007, Richard Girard wrote:
| Quote: | | Consider the original Supermarine Spitfire Mk 1, #5054, had a two blade prop. By the Mk IX it was running a four blade prop and by the Mk XIV, with the RR Griffon engine replacing the Merlin, it was running a five blade. The difference in speed between the Mk I and the Mk XIV was almost 100 MPH. The difference in HP was a bit over 800 between the two and the extra three blades were required to soak it up. |
True, but consider the reason... it wasn't practical to make the landing gear long enough to put on a sufficiently large prop of less blades to absorb all the available power. Even the early Spitfires had very limited prop ground clearance, so that pilots had to be very careful not to let the tail get too high while on the ground.
-Dana
Okay, who put a "stop payment" on my reality check? [quote][b]
tnt1(at)rangebroadband.co Guest
Posted: Tue May 22, 2007 6:56 pm Post subject: FireFly prop & others |
Howard, What made you go with the 3.47 box? I went with I think 2.62 on an e-box wwith a two blade taper -tip on a 503 DCDI. What is your rpm WOT straight and level? What would I gain with 3.47 gears on my Firestar II? Your advice always appreciated. Thanks Tim D.
Posted: Tue May 22, 2007 7:42 pm Post subject: FireFly prop & others |
In a message dated 5/22/2007 10:57:13 PM Eastern Daylight Time, tnt1(at)rangebroadband.com writes:
| Quote: | Howard, What made you go with the 3.47 box? I went with I think 2.62 on an e-box wwith a two blade taper -tip on a 503 DCDI. What is your rpm WOT straight and level? What would I gain with 3.47 gears on my Firestar II? Your advice always appreciated. Thanks Tim D.
When I bought my kit, I asked Dennis Souder what set-up he would recommend for best climb considering my weight [270 at the time]. The 3.47 box w/ Warp 3 blade, 68" taper tip is what he recommended.
My WOT is 6500. I don't know that you would gain anything by changing your setup; my setup works for me, may not work for you. Is your plane heavy? What is your personal weight? Are you seeking more climb? Probably not worth the expense to change.
I think most FSII's fly great no matter what the set-up.
Howard Shackleford
FS II
SC
DAquaNut(at)aol.com Guest
Posted: Tue May 22, 2007 8:02 pm Post subject: FireFly prop & others |
In a message dated 5/22/2007 10:43:13 PM Central Standard Time, HShack(at)aol.com writes:
| Quote: | My WOT is 6500. I don't know that you would gain anything by changing your setup; my setup works for me, may not work for you. Is your plane heavy? What is your personal weight? Are you seeking more climb? Probably not worth the expense to change.
Howard Shackleford
FS II
SC
Ive not seen anything mentioned about economy during this lengthy prop discussion. Has anyone done a comparison on which prop gets the best distance or mileage. Seems it is accepted that the 3 blade is smoother than the 2 blade, but which would be best if you were going for a distance record on a set amount of fuel? |
Ed Diebel FF # 62
