billsewell(at)gmail.com Guest
Posted: Tue May 29, 2007 8:03 am Post subject: Flap Motor switch Warning |
I just ran into the problem described below. After doing some research, I discovered that Honeywell has replaced the discontinued micro switch V3L-3 with micro switch V3-1 and roller leaf assembly JV-5. I purchased them online at www.gopherelectronics.com for $18.41 each plus shipping ($8.31 for V3-1 and $10.10 for JV-5).
Here is a link to the data sheet: http://www.n601bz.com/ch601xl/Introduction/v3.pdf
Bill Sewell
N601BZ
Match: #9 Message: #32297 From: Sigmo(at)aol.com Date: Mar 04, 2005 Subject: Flap Motor switch Warning | Quote: |
Caution: If you are using a Commercial Aircraft products Flap motor DO NOT
break one of the up or down roller limit switches.
The V3L-3 Honeywell/Micro switch has been discontinued and after trying
extensively to locate another switch that will fit the D145 flap motor I am
unable
to find one of the right dimensions that will work on this design.
Commercial Aircraft will not sell you one of their stock. Honeywell will not
sell you one of their stock. The authorized suppliers will sell you one of
these $5 switches for $50 to $70 dollars which will be shipped from Honeywell.
An expensive lesson learned about using loctite and trying to remove the
screw.....
P.S. I bought the only two I could find on the Honeywell dealers inventory
list that were less than $50 and they were $28 each.
Mike Sigman
Zodiac 601XL N7092N
| End Msg: #9
