RV9A and why
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV9-List
rv9jim(at)juno.com
PostPosted: Sun May 13, 2007 6:07 am    Post subject: RV9A and why Reply with quote
Rafeal,
I went thru the same decisions. I went for the 9A beacuse of the
better handling as slow speeds. I however went with the IO-360 (ala -
RV7 fwf). I did this because with the IO 360 and LOW COMPRESSION
pistons you still have 167 hp. More than enough for the 9A. The big
reason again is: First, the low compression version is 7.2 : 1 which
allows for (need i say) auto gas. I refer to it as garbage gas. This
can give you the lowest cost in fuel as the years go by. Good HP but
with the lowest cost. Second: The injected engine can be run at
maximum efficiency ie: lean of peak. The carb engine can not. So I
traded about 30# extra in the 360 engine for lower operating cost. Next,
I bought the engine with a solid crank so I could not add a constant
speed prop. My project is at the prop spinner stage. As I finish this up
in the next few days, I will be doing the wings next. I bought the QB
kit and I have about 1250 hours in it now. You can look over my build at
www.websites.expercraft.com/jimn where I have been documenting the
build. I have my comments about the build both + & - . So far it has
been a good build. I expect to have it flying in 3 to 4 months. Of
course depending on the hurrican season here in florida (St. Petersburg).
Then again, using the IO 320 is a very good option. I would do
it with the 150 hp engine and a constant speed prop to get the whole 150
hp. Then again, the cost of upkeep on the constant speed prop has to be
figured in the equasion. So I went for the simpler fixed sensenich prop
and the low comp. IO 360 with a fixed prop. Gives me the HP with the
simplicity and few controls. Does this all make sense? Its the way I
figured it and went.
Jim Nelson
N15JN
RV9-A
- The Matronics RV9-List Email Forum -
http://www.matronics.com/Navigator?RV9-List
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV9-List All times are GMT - 8 Hours
