		| Author | Message |
		| rvfltd(at)televar.com Guest
				|  Posted: Sun Feb 05, 2006 5:48 pm    Post subject: CJ Parts just in |   |
				|       PART        NUMBER     PART        NAME     IN      STOCK        2     ZCD-2     cockpit lamp     5        4     QSF-6A     Air cock     6        7     QS1-11     spring     40        10     QS1-08     spring     100        11     QS1-06     spring     100        12     QDF-1     start valve     12        15     KY2-013     spring     100        16     KY2-011     washer     100        17     KY2-009     washer     100        18     JH2-6900-00     engine cowling Late model  sets     3        19     HB-403G-M8     nut     50        22     H2-9850-100     headed jack     10        23     H2-9820-200     mid wing jack     10        24     H2-9820-100     footrest     10        25     H2-9810-200     tail jack     10        26     H2-9250-1000     cowl cover for winter     10        27     H2-6400-04     mt rubbers     300        32     H2-6300-00/A     control system of gill     1        33     H2-5721-01     indicator     6        34     H2-5710-00     flap actuator     4        35     H2-5545-03     ring     100        36     H2-5533-00     hose     12        37     H2-5532-00/5     hose     24        38     H2-5532-00/3     hose     12        39     H2-5531-00     hose     12        40     H2-5529-00     hose     12        41     H2-5528-00/3     hose  ( 00/3        is same as 00/2 )     12        42     H2-5528-00/1     hose     12        43     H2-5526-00     hose     24        44     H2-5524-00     hose     24        47     H2-5408-61     fork joint     12        52     H2-4130-53         leather cup     50        53     H2-4230-10        Hook      10              H2-4230-20     Lock menber     10              HB3-4-A1×10×55III     Spring     10        54     H2-4220-14     axle bushing     4        55     H2-4220-01     nose strut bolt     6        56     H2-4200-02     bolt, nose pivot     4        57     H2-4220-10     lower bracing strut     7        58     HB1-106-8X22X3.5     bolt     25        59     H2-4200-03     bolt     25        60     HB1-106-6X3X3.5     bolt     25        63     H2-4110-52     sphrical bushing     20        65     H2-4110-03     washer     50        66     H2-3700-00     flap                                 overhauled     4        67     H2-0100-308     nut     200        68     GY-15     oil pressure sensor    overhauled     12        69     GY-1      fuel pressure sensor  overhauled     12        70     G1-K04     spanner       10        71     G1-K02     spanner     10        82     CD400-300     high pressure rod     6        83     64700/001A     grease gun     5        85     604.07.06     push rod hose     360        86     604.04.13     cylinder gasket     100        88     15.02.112     oil sump gasket, rear     25        90     14.36.581     gasket     200        91     14.36.580     gasket     200        97     H2-6341-100     Gill     35        98     WD-1-1     tail light cover     7        99     H2-3204-100     elevator        tab   right       2                                               left     2        100     H2-6901-00-15     shape material     2        101     H2-6902-00-25     shape material     2        102     H2-6906-00     prop rod     3        103     H6.G.806     intake pipe spanner     4        104     QS-1     pressure reducer     3        106     QSF-2A     langing gear control, front     3        111     QL-17     deposit filter        serviceable     2        118     CD-5     magneto     2        119     H2-3100-00     horizontal stabilizer   serviceable     1        122     J-9     blade          2        set        1     CD400-300     high pressure rod     6        2     CD-450-00     mag coil     1        3     WD-1-1      tail light cover     3        5     QS-1     pressure reducer           2        8     QSF-6A     air cock     4
 Always Yakin,
 Doug Sapp
 | |  |  | - The Matronics Yak-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Yak-List
		| Back to top |  |
		| BitterlichMG(at)cherrypoi Guest
				|  Posted: Tue Feb 07, 2006 4:15 pm    Post subject: CJ Parts just in |   |
				| Doug, have  you got a cylinder head bolt removal tool?
 Mark
 [quote]   --
		| Back to top |  |
				|  Posted: Tue Feb 07, 2006 4:52 pm    Post subject: CJ Parts just in |   |
				| Mark,
No, just take  two nuts and screw them on the stud, one on top of the other, make sure that the  top one is tightened down VERY tightly against the lower one, then using a  wrench on the bottom one unscrew the stud out of the case.  Your local  parts dealer normally carries a stud removal tool that is much easier to use but  everyone that I have seen destroy the stud in the process of removing it.   The lock nut method allows you to reuse the stud.
 Call me if  you need: 509-826-4610
 Always Yakin,
 Doug Sapp  [quote]   --
		| Back to top |  |
		| mbeach(at)hartwigs.com.au Guest
				|  Posted: Tue Feb 07, 2006 5:11 pm    Post subject: CJ Parts just in |   |
				| Doug what are the cock pit laps worth.
 Rgs  Michael
 From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of doug sapp
 Sent: Wednesday, February 08, 2006 11:51 AM
 To: yak-list(at)matronics.com
 Subject: RE: CJ Parts just in
 Mark,
 Always Yakin,
 Doug Sapp   [quote]
		| Back to top |  |
				|  Posted: Tue Feb 07, 2006 5:41 pm    Post subject: CJ Parts just in |   |
				| What  the hell are cockpit laps?....sir
 Always Yakin,
		| Back to top |  |
				|  Posted: Tue Feb 07, 2006 5:56 pm    Post subject: CJ Parts just in |   |
				| COCK PIT LAMPS, SORRY DOUG HAVING A BAD DAY.
 Sent: Wednesday, February 08, 2006 12:39 PM
 Always Yakin,
 Doug Sapp   [quote]
		| Back to top |  |
