Short and to the point
AV8ORJWC
PostPosted: Thu May 10, 2007 4:40 pm    Post subject: Short and to the point Reply with quote
I am often quoted as being too verbose. Until you understand “Hydrogen Embrittlement”, use no cleaner (especially not Old Simple Green) on any aircraft component until you “the manufacturer” know what you are placing at risk <<Simple Green.pdf>> <<Simple Green MSDS 2006.pdf>> . Period. As manufacturer’s do what you want.
Here are two important documents for the RV 10 University.
Extreme Simple Green is not the same product as Old Simple Green. End of discussion.
John Cox
#600
Simple_Green.pdf
 Filename:  Simple_Green.pdf
 Filesize:  86.12 KB
 Downloaded:  296 Time(s)
Simple_Green_MSDS_2006.pdf
 Filename:  Simple_Green_MSDS_2006.pdf
 Filesize:  23.62 KB
 Downloaded:  543 Time(s)
jesse(at)saintaviation.co
PostPosted: Thu May 10, 2007 5:37 pm    Post subject: Short and to the point Reply with quote
That was beautiful, John. Your input/insight is always great, but brevity is beautiful, especially when you use little words that I can understand.
While we're on this, what about using Orange cleaner for both scuffing and degreasing?
We use some kind of thinner for cleaning before priming, but we scuff and use thinner then alcohol (desengrasante) for exterior paint prep, then go with wash primer, followed by filler primer (the gray stuff), folowed by color and clear.
Jesse
rv10builder(at)verizon.ne
PostPosted: Thu May 10, 2007 6:24 pm    Post subject: Short and to the point Reply with quote
John;
Thanks for caring enough to make your point.
I'll get the Extreme!
Thanks!
Pascal
AV8ORJWC
PostPosted: Thu May 10, 2007 9:17 pm    Post subject: Short and to the point Reply with quote
Scuffing whether with an additive (pumice - Orange stuff) or with
accessories (such as Scotchbrite pads) increases the potential for
Adhesion - a good thing. Just remember that with Alclad 2024 the
surface coating of pure aluminum is Thin 5% of the total on each side.
You do the math on 0.025". When it turns dark, you are already through
the pure aluminum and into the base hybrid metal stock.
I've heard no negatives on the citrus based products. Residue might
require more rinsing. The cleaner the substrate (no residue) the
quicker the time between cleaning and priming the less oxidation which
is happening immediately. More hands, less time is a better thing.
Cessna had a problem with filiform corrosion from cleaning aircraft
overnight (outside) and then priming and painting the next day. Who
said acid rain hasn't reached the "Heartland"?
John
apilot2(at)gmail.com
PostPosted: Fri May 11, 2007 7:41 am    Post subject: Short and to the point Reply with quote
IIRC Cessna also skipped one of the primer steps recommended by the
paint manufacturer.
Whatever happened to the traditional acid etch/alodine process? Too
labor intensive?
John
james.k.hovis(at)gmail.co
PostPosted: Fri May 11, 2007 7:54 am    Post subject: Short and to the point Reply with quote
On ALCLAD, you don't need to etch or alodine, only if you have deep
scratches to blend out deeper than the clad surface. Remember, the
reason for clad is the pure aluminum gets a thin veneer of oxide to
protect the rest of the material when exposed to air. Mild cleaning
and a light scrubbing should be all you need. A citric product is used
in production, not sure what "brand" it is... If there's a material
that may lead to hydrogen embrittlement as John notes, RUN AWAY
SCREAMING please!!!!
Kevin H.
paint manufacturer.
labor intensive?
> John
