Horizontal Support Braces
GrummanDude
PostPosted: Fri May 04, 2007 11:19 am    Post subject: Horizontal Support Braces Reply with quote
I'm doing an annual on a Tiger that had the braces for the horizontal
replaced last year. The shop that did it is one of the best. However,
the cable tension to the elevator was over 90 lbs (off the scale on my
tensioner).
Should I sue the last guy to work on this plane? Or, do you think it
would be more contructive to correct the problem and let the shop know
what I found so that can correct the source of the mistake?
Damn it, I'm calling my lawyer . . . .
________________________________________________________________________
from AOL at AOL.com.
Gary
AuCountry Aviation
Home of Team Grumman
flyv35b(at)minetfiber.com
PostPosted: Fri May 04, 2007 11:32 am    Post subject: Horizontal Support Braces Reply with quote
I just finished an annual on a Tiger that had the elevator cable tension set
way to high. I think they adjusted it by feel, comparing it to the aileron
cables possibly.
Cliff
Discover
PostPosted: Fri May 04, 2007 11:37 am    Post subject: Horizontal Support Braces Reply with quote
Gary you don't have to have a law degree to be a lawyer in Calefornia
Yes, Calefornia as the governator says it...
Go for it and take over their business!
GrummanDude
PostPosted: Fri May 04, 2007 11:59 pm    Post subject: Horizontal Support Braces Reply with quote
When I was rerigging the cables, I noticed that if I put the center
pulley on the cable tensioner on the pulley's axel, it read about 40
lbs. My guess is whoever did it didn't know how to use the tensioner.
Gary
AuCountry Aviation
