bicyclop(at)pacbell.net Guest
Posted: Wed May 02, 2007 8:56 pm Post subject: Oil cooler port location |
I know this has been hashed, but I can’t find the answer in the archives. Which port should be pressure to the oil cooler and which one return on an O-320? The one I think is pressure is to the right of center on the accessory case and the return is higher up on the left side. Is that right? I’m moving our oil cooler to the engine mount behind #4, mounted vertically and I want to make sure that the pressurized oil is going in the bottom.
Pax,
Ed Holyoke
Vanremog(at)aol.com Guest
Posted: Wed May 02, 2007 9:10 pm Post subject: Oil cooler port location |
In a message dated 5/2/2007 10:05:00 P.M. Pacific Daylight Time, bicyclop(at)pacbell.net writes:
| Quote: | | Which port should be pressure to the oil cooler and which one return on an O-320? The one I think is pressure is to the right of center on the accessory case and the return is higher up on the left side. Is that right? |
Correctamundo! Bottom (pressure) port plumbs to bottom port on cooler.
GV (RV-6A N1GV O-360-A1A, C/S, Flying 844hrs, Silicon Valley, CA)
See what's free at AOL.com.
Posted: Thu May 03, 2007 7:51 am Post subject: Oil cooler port location |
Ed
dckoh(at)mindspring.com Guest
Posted: Thu May 03, 2007 1:25 pm Post subject: Oil cooler port location |
There is also a secondary pressure out port, at least on the 320-E2D I have that came out of a Cardinal. It is right above the oil screen housing next to the breather port. I’m using that one because it already had the hose fittings, but mainly because I couldn’t get the #$%&*(at)# plug out of the center hole.
RV-6A
Slow built, I used to be a Bauxite miner
Marietta, GA
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Vanremog(at)aol.com
Sent: Thursday, May 03, 2007 1:10 AM
To: rv-list(at)matronics.com
Subject: Re: Oil cooler port location
| Quote: | | http://www.matronics.com/Navigator?RV-List | 01234
