tompkinsl(at)integra.net Guest
Posted: Mon Apr 30, 2007 10:01 am Post subject: Magnetometer Location in RV-7 |
It appears that one item I wasn't smart enough to consider when I selected the position/landing/strobe light system for the RV-7 I am building was magnetometer location for an EFIS.
Looking through the installation manuals for Brand AFS and brand GRT, one recommends 24" clearance and the other 12" clearance to strobe wires.
I installed a CreativAir single power pack strobe sytem in the wings, which means that I have power supply wires and strobe wires running through the wings.
Even using the rib hole locations specified by Van's, the maximum spacing between wire runs is only 6". Does this mean I will have to replace the CreativAir sytem with individual power supplies? Or is there an alternative? I am assuming that I need only concern myself with the magnetometer itself and not the leads to the magnetometer, but I don't want to get into trouble with that assumption either.
Larry Tompkins
dave(at)abrahamson.net Guest
Posted: Tue May 01, 2007 2:36 am Post subject: Magnetometer Location in RV-7 |
Larry,
From your description, it seems to me you can keep the magnetometer
(GRT) and its wiring away from the strobe wiring -- all the way to
behind the panel if you choose to. If you'd like to email me
off-line (dave(at)abrahamson.net), I can send you pictures of where I
mounted the magnetometer and describe to you how I routed my
wires. I can suggest to you a routing of your wires if you determine
that the strobe power wires and magnetometer bundle must be kept
apart from beginning to end.
David, N98DA, RV-7, flying.
nuckollsr(at)cox.net Guest
Posted: Tue May 01, 2007 5:48 am Post subject: Magnetometer Location in RV-7 |
At 06:34 AM 5/1/2007 -0400, you wrote:
<dave(at)abrahamson.net>
Larry,
From your description, it seems to me you can keep the magnetometer (GRT)
and its wiring away from the strobe wiring -- all the way to behind the
panel if you choose to. If you'd like to email me off-line
(dave(at)abrahamson.net), I can send you pictures of where I mounted the
magnetometer and describe to you how I routed my wires. I can suggest to
you a routing of your wires if you determine that the strobe power wires
and magnetometer bundle must be kept apart from beginning to end.
There is no good reason in physics for keeping magnetometer
and strobe wiring separate if the magnetometer is wired with
multiple wires twisted together (and probably under a shield
to boot). This what one does to make said wired impervious to
local magnetic effects. If the strobe POWER wire passes within
2 feet of the magnetometer itself, then consider taking strobe
power and ground past the magnetometer as a twisted pair.
DO-160 has a protocol for investigating and quantifying
magnetic effects . . . we look at these issues all the time.
Wire bundles installed with any understanding and foresight
at all are never a problem. Black boxes themselves are almost
never a problem.
It's easy to test. When everything is all installed, position
your aircraft on 8 headings at 45 degree intervals around the
compass and turn suspect antagonists on and off while observing
displayed heading. Anything under 2 degrees of shift is generally
considered acceptable and it's very seldom that we see ANY observable
shifts.
If we tried to pay homage to every ol' mechanic's tale about
the need for separation of wire bundles for any reason, we'd
never be able to build an airplane with electro-whizzies in it.
Wire bundles have to go where there is room and systems that
use wires in those bundles are expected to be designed with
and installed with common sense about magnetically coupled
noises.
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
Posted: Tue May 01, 2007 7:18 am Post subject: Magnetometer Location in RV-7 |
Larry
In my RV-9A, I also have my (Whelen) strobe units in the wing tips, therefore I decided to install the magnetometer right aft the baggage compartment, below the upper fuselage skin, and it's not my original idea, since I'm aware of some other builders having done it.
I cannot report any results, because I am still not flying.
Carlos Trigo
Posted: Tue May 01, 2007 3:09 pm Post subject: Magnetometer Location in RV-7 |
At 04:14 PM 5/1/2007 +0100, you wrote:
| Quote: | Larry
I hope you'll conduct an "observable effects" test
at your earliest convenience and report back to us!
Thanks.
( EVERY day . . . )
Posted: Wed May 02, 2007 3:10 am Post subject: Magnetometer Location in RV-7 |
I am lucky to be flying my RV7 in phase I and have performed the GRT
magnetometer calibration, as well as the in-flight Trutrak Digiflight
II VSGV magnetometer alignment. The latter uses GPS data to do its
automatic calibration dance, as the anxious pilot looks for traffic,
while the GRT calibration is done on the ground with the aid of a
magnetic compass. I am happy to report that the two magnetometers
are in full agreement.
I mounted my GRT magnetometer in the same location as Carlos, and ran
the wire down the middle of the plane, through the spar bulkhead
where it joins a large bundle that includes the Whelen power supply
and ground wires, on the way to the space behind the panel. The
magnetometer wire bundle consists of several loose 22AWG wires,
neither twisted, nor shielded, whose routing GRT says is unimportant
as long as the magnetometer standoff is as directed. I mounted the
unit on an aluminum shelf, and secured it with two brass screws.
David
Posted: Wed May 02, 2007 5:23 am Post subject: Magnetometer Location in RV-7 |
At 07:08 AM 5/2/2007 -0400, you wrote:
magnetometer calibration, as well as the in-flight Trutrak Digiflight II
VSGV magnetometer alignment. The latter uses GPS data to do its automatic
calibration dance, as the anxious pilot looks for traffic, while the GRT
calibration is done on the ground with the aid of a magnetic compass. I
am happy to report that the two magnetometers are in full agreement.
I mounted my GRT magnetometer in the same location as Carlos, and ran the
wire down the middle of the plane, through the spar bulkhead where it
joins a large bundle that includes the Whelen power supply and ground
wires, on the way to the space behind the panel. The magnetometer wire
bundle consists of several loose 22AWG wires, neither twisted, nor
shielded, whose routing GRT says is unimportant as long as the
magnetometer standoff is as directed. I mounted the unit on an aluminum
David
Good data sir. Thank you.
Posted: Wed May 02, 2007 10:35 am Post subject: Magnetometer Location in RV-7 |
Bob,
Thank you for your reply. I have determined that a tail installation (as suggested by another lister) is less pratical because of accessability than a wing location. I WILL have to take the strobe power cable within two feet of the magnetometer. The cable that was supplied for the high voltage power from the power pack to the flasher is a 3 conductor shielded cable. The wires are supply ground and trigger.
The following information was ink-stamped on the cable jacket:
Manhattan/CDT P/N M13227 E120910 3/C 22 AWG
60C (UL) Typer CM OR AWM 2093 LL 41103 CSA TYPE CMG
It doesn't seem to me that a 3 conductor cable can be a "twisted pair." Is there something else I should be using? Is it possible to shield the strobe cable locally where it is whithin 24" of the magnetometer?
Thank you,
Larry
Posted: Wed May 02, 2007 11:27 am Post subject: Magnetometer Location in RV-7 |
At 11:34 AM 5/2/2007 -0700, you wrote:
| Quote: | Bob,
This is no doubt the grey, twisted trio with
an aluminum foil shield and drain wire. This
is the stuff shipped with strobe kits for about
40 years.
| Quote: | It doesn't seem to me that a 3 conductor cable can be a "twisted
"Twisted pair" is like calling all copy machines
"Xerox". Twisting is a generic process that applies
to ANY number of wires that are either potential victims
for MAGNETICALLY coupled noise pickup or potential
antagonists for noise radiation to other wires.
Adding the "Beldfoil" shield over this grouping of
wires breaks a tiny CAPACITIVELY coupled noise
component from the trigger wire. You can run this
cable right past the magnetometer with zero risk
of interfering with the magnetometer.
The MAGIC that happens when using this cable demands
that no grounds be attached to airframe at the
wing tip. Make connections only to the three wires
at the strobe lamp fixture. Leave the shield ground
open at the lamp. Connect the three wires to the
appropriate three pins at the power supply and connect
the shield ground to the strobe supply case mounting
screw.
( EVERY day . . . )
Posted: Thu May 03, 2007 8:32 am Post subject: Magnetometer Location in RV-7 |
Bob,
Thank you for continuing to educate me once again . Based on your comments as well as David Abrahamson's installation and positive experience with that location, I am satisfied that David's fuselage location is an excellent one.
In case you haven't been following this thread, David fabricated a horizontal shelf high in his RV-7's empennage and just behind the baggage compartment rear bulkhead. His GRT magnetometer is attached to that shelf. While that location does not quite meet the GRT recommendation of 18" away from the baggage compartment, he has positive test data to support the use of that location. Anything heavy or ferrous is probably going to be close to the baggage compartment floor, which IS more than 18" from that location.
David also e-mailed me photos of the installation that are very helpful. He has a nice website documenting his RV-7's construction as well.
Larry Tompkins
