daviddla(at)juno.com Guest
Posted: Tue Feb 07, 2006 6:28 pm Post subject: total seal piston rings |
Hi all, I may be splitting the cases on my Lycoming 0-320 to repair a oil
leak. Is it worth wild to install total seal rings in my 75 hr Titan
cylinders? I understand that the middle ring is the most common to
replace while replacing the top ring can lead to excessive oil being
drawn through the intake valve guide. Does anyone have more information,
possible first hand experience? Many thanks, Do not Archive, David
Ahrens/RV6-A
Bruce(at)glasair.org Guest
Posted: Tue Feb 07, 2006 7:34 pm Post subject: total seal piston rings |
You should be able to just use a hone to break the cylinder wall glaze and
reuse the old rings.
Bruce
www.glasair.org
