Oil Pump Internal Leak
Guy Buchanan
PostPosted: Tue May 01, 2007 9:34 pm    Post subject: Oil Pump Internal Leak Reply with quote
All,
My aft carb is filling with oil. (582) It appears the oil
injection system is allowing oil to slowly migrate from the tank to
the oil injection port. Has anyone else had this problem? Can I
rebuild the injection pump? I seem to remember someone telling me
there was a check valve or ball valve in the pump that could get
particulates in it an thereafter allow oil to flow at rest.
Guy Buchanan
San Diego, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
Float Flyr
PostPosted: Wed May 02, 2007 6:36 am    Post subject: Oil Pump Internal Leak Reply with quote
I heard and experienced the same thing. The advice was not to leave the injection bottle full.
[img]cid:442233514(at)02052007-0BBB[/img]
Noel Loveys, RPP, AME intern
Campbellton, Newfoundland,
Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca (noelloveys(at)yahoo.ca)
[quote] --
 Filesize:  19.77 KB
 Viewed:  267 Time(s)
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
Guy Buchanan
PostPosted: Thu May 03, 2007 7:52 pm    Post subject: Oil Pump Internal Leak Reply with quote
At 10:33 PM 5/1/2007, you wrote:
My aft carb is filling with oil. (582) It appears the oil injection
system is allowing oil to slowly migrate from the tank to the oil
injection port.
I spoke with Bob Robertson. It turns out the banjo fittings
connecting the pump to the oil feeds contain check valves. He says
these occasionally leak. Unfortunately he also says he's never had
any luck cleaning them so I'll just have to replace the one that's
passing oil. Parts are on order.
Thanks for all the responses. And support Bob Robertson at
Light Engine Services. He's a hell of a nice guy, knows his stuff,
and is always helpful.
Guy Buchanan
San Diego, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
