Jerry Grimmonpre'
Joined: 09 Jan 2006 Posts: 144 Location: Huntley, Illinois 60142
Posted: Mon Feb 06, 2006 8:24 pm Post subject: Bus Load Analysis |
Hi all ...
I humbly ask for input on the following and maybe create new thought ...
Load analysis: Pitot heat load vs. load of AOA (angle of attack) Sport
instrument.
Rob are you here?
When considering the imbalance of the load effects of these two items ... it
seems we squander a lot of amps on pitot heat when the AOA could substitute
while using about .4 amps and include audible warnings, as well, while
landing at any weight.
In my reading of the Lancair list, I've found there has been zero incidents
of moisture problems in the AOA ports in the outer wing D sections. This
included heavy rain with the airplane tied outside. If this port is not
affected by moisture, it seems to follow that icing may be less of a problem
with this delta P port. This applies to the AOA system called AOA Sport,
where the pressure differential is measured at the outboard wing D section.
When considering pitot heat, as a 7.5A continuous load, it would increase
most Continuous Bus loads by near 30-40%. Powering-up an AOA system pales
in comparison at only .4 amps.
Those of you with the AOA Sport ... have you found any moisture or frozen
ports?
How many have found pitot heat cleared up their airspeed indications within
moments of turning on the pitot heat?
What I'm trying to get at here is: do you think pitot heat should be listed
as continuous amps used, considering the availability of AOA and it's low
demand on amps?
Regards ...
Jerry Grimmonpre'
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Mon Feb 06, 2006 10:06 pm Post subject: Bus Load Analysis |
Jerry Grimmonpre wrote:
Quote: | I humbly ask for input on the following and maybe create new thought ...
instrument.
Rob are you here?
I like AoA. It is one of the most useful instruments in an airplane. I
also know that neither AoA nor ASI are going to be much use when the
wing is iced up. Ice changes the airfoil shape and possibly the
effective angle of incidence. The wing will stall at a different
airspeed and probably a different angle of attack as separation of
airflow is likely to occur sooner.
So it doesn't much matter.
Well, there is one thing: if your ASI is working and you experience
stall buffet at some airspeed, at least the ASI will give you some idea
when you are in the ballpark again. In that it might be of some use if
the wing is iced up. And your AoA pressure ports will probably be
covered with the ice anyway.
But I still like that AoA instrument. I had one on my previous CJ6A and
verified its calibration from 1/4G all the way up to 5Gs. It made flying
acro a lot more comfortable because I could always just take the wing to
zero alpha and wait until I had more airspeed to recover. I never had to
deal with the airplane departing if I didn't want to.
Brian Lloyd 361 Catterline Way
brian-yak at lloyd dot com Folsom, CA 95630
- Antoine de Saint-Exupery
_________________ Brian Lloyd
- Antoine de Saint-Exupery |
jschroeder(at)perigee.net Guest
Posted: Tue Feb 07, 2006 5:50 am Post subject: Bus Load Analysis |
Jerry -
I'm not sure what your point is. The AOA Sport relies on pitot and static
pressure inputs. Therefore, in known or suspected icing, I would have the
pitot heat on - to get both airspeed and the AOA. Why would one risk
losing both by trying to save some juice in the weather?
I have installed this AOA in a Lancair ES. The AOA ports are on the right
wing and the pitot tube is on the left wing.
Hope this helps.
John
On Mon, 6 Feb 2006 22:22:13 -0600, Jerry Grimmonpre <jerry(at)mc.net> wrote:
Quote: | What I'm trying to get at here is: do you think pitot heat should be
listed
demand on amps?
Regards ...
Jerry Grimmonpre'
Jerry Grimmonpre'
Posted: Tue Feb 07, 2006 9:22 am Post subject: Bus Load Analysis |
DO NOT ARCHIVE
Hi John ...
Thanks for your note, I was trying to make the point of declaring the
"constant on" of the pitot heat to be an excessive "charge" to the account
of bus demand. Sort of like the "constant on" of a Com radio does not
consider the moments of transmit to be considered demand on the bus because
of the duration of transmit time.
I see, from your response, the that the AOA does require pitot/static and,
of course, that can only come from a non iced system. I had it in my mind
that the AOA Sport only required inputs from the two ports on the wing D
section. Thanks for your enlightenment.
Regards ...
Jerry Grimmonpre'
Quote: |
<jschroeder(at)perigee.net>
Jerry -
Hope this helps.
John
> listed
> demand on amps?
> Regards ...
> Jerry Grimmonpre'
mprather(at)spro.net Guest
Posted: Tue Feb 07, 2006 12:46 pm Post subject: Bus Load Analysis |
Hi Jerry,
Interesting question.. Comments embedded.
Quote: |
<jerry(at)mc.net>
Hi all ...
instrument.
Rob are you here?
... it seems we squander a lot of amps on pitot heat when the AOA could
substitute while using about .4 amps and include audible warnings, as
well, while landing at any weight.
incidents of moisture problems in the AOA ports in the outer wing D
sections. This included heavy rain with the airplane tied outside. If
this port is not affected by moisture, it seems to follow that icing
may be less of a problem with this delta P port. This applies to the
AOA system called AOA Sport, where the pressure differential is
I don't know that you could say that being impervious to rain has any
bearing on being impervious to ice. Even if ice doesn't end up covering
either port, it changes the airflow over the wing, and lowers the angle of
attack of stall. I had a fortunate opportunity to ride around in the
right seat of a Pilatus PC-12 last week.. The pilot was explaining to me
that when prop deice, and the engine inertial seperator were enabled, the
stick shaker/pusher would activate at 8deg less AoA(!). The system
assumes that when you have both systems enabled, it's pretty likely you
are in icing conditions.
Quote: | When considering pitot heat, as a 7.5A continuous load, it would
increase most Continuous Bus loads by near 30-40%. Powering-up an AOA
system pales in comparison at only .4 amps.
frozen ports?
within moments of turning on the pitot heat?
Typical use of pitot heat is to power it up whenever you are in visible
moisture - the idea is that you don't want a dead ASI to be the indication
that the pitot heat should be turned on.
listed as continuous amps used, considering the availability of AOA and
it's low demand on amps?
That's a slightly different question.. The pitot heat is a continuous
load - like nav lights. Unlike flap motors and electric landing gear
equipment, which are momentary loads. The real question I would ask is
whether either an AOA or the ASI is required in order to comfortably
complete any flight you intend to use the airplane for.
I don't know that this rationale is backed up by good statistics, but if I
were planning to use an airplane for lots of real IFR work, I'd probably
want a power budget that allowed me to run the pitot heat after the
failure of my primary engine driven electrical power source. Especially
with a naturally aspirated (rather limited service ceiling) engine. If
however, my airplane was going to be used for occasional scud avoidance -
punch through a layer in order to find some sunshine when it's cloudy on
the ground, I wouldn't worry about having pitot heat be supported by the
endurance bus. I figure that the intersection of time when I have an
electrical failure, and when I can't comfortably complete a flight without
the ASI/AoA would be exceedingly low.
Quote: | Regards ...
Jerry Grimmonpre'
Matt-
Jerry Grimmonpre'
Posted: Tue Feb 07, 2006 5:02 pm Post subject: Bus Load Analysis |
DO NOT ARCHIVE
Hi Matt ...
Quote: | Typical use of pitot heat is to power it up whenever you are in visible
There-in lies the problem. AOA Sport will not indicate properly with an
iced pitot/static because AOA Sport relies on those two to feed the computer
creating the progressive decay indications of the AOA LED's. It would seem
great to have an AOA idicator impervious to icing but the reality is the
wing's AOA and it's resultant lift reports the truth ... the wing demands
clean airflow. Therefore an iced pitot/static OR AOA ports will not report
a reliable warning indication so plan to leave the pitot heat on when in
icing conditions and forget the AOA as being ice proof.
I just answered my own question .... yes, leave pitot heat on continuously
in icing conditions and therefore plan the bus load analysis for the 7.5
amps required.
An aviator who knows the airplane will know what power/attitude/descent rate
will result in getting to the end of the runway in a normal landing
configuration.
I agree.
Quote: | >
Matt-
Jerry Grimmonpre'
