582 Exhaust Ball Joints
Guy Buchanan
PostPosted: Tue Apr 24, 2007 4:20 pm    Post subject: 582 Exhaust Ball Joints Reply with quote
All,
I'm looking for good ideas on how to seal the 582 exhaust
ball joints. I've used copper anti-seize in the past but it just
blows out. (My joints don't fit very well for some reason.) Today I
re-worked the joints to fit better but I thought there might be some
good ideas out there as to how to seal them while leaving them
flexible. (I had an idea of brazing them together, then knocking out
the male piece, leaving a perfect fitting bronze bushing, but I
haven't tried it yet.)
Guy Buchanan
San Diego, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
dosmythe(at)cox.net
PostPosted: Tue Apr 24, 2007 4:55 pm    Post subject: 582 Exhaust Ball Joints Reply with quote
Guy,
Just out of curiosity, what makes you think they are not sealing good
enough?
Don Smythe
Classic IV w/582
Newport News, Va.
Guy Buchanan
PostPosted: Tue Apr 24, 2007 6:52 pm    Post subject: 582 Exhaust Ball Joints Reply with quote
good enough?
I tore the exhaust system apart today to have it re-coated and found
the manifold / elbow joint had two areas that were clearly blowing.
They had yellow deposits, (the same as inside the manifold,) running
through the joint. I did a lot of work today and improved the mating
significantly, but would like it to seal, if possible.
Guy Buchanan
San Diego, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
Fox5flyer
PostPosted: Wed Apr 25, 2007 3:13 am    Post subject: 582 Exhaust Ball Joints Reply with quote
Guy, back when I had my 582 I had a similar problem. Using anti seize just
made a big mess as the stuff blew all over everything. I finally got fed up
with it, pulled the two units off, and worked the two parts together with
valve grinding compound for about 30 minutes. I kept at it until I was sure
I was getting full contact on the two parts. Then I applied a thin coat of
anti seize. After that it was much better but not perfect, something I'm
not sure you'll ever achieve with that sort of setup.
Deke Morisse
K5/Soob/CAP
NE Michigan
davef(at)cfisher.com
PostPosted: Wed Apr 25, 2007 5:51 am    Post subject: 582 Exhaust Ball Joints Reply with quote
Deke and Guy ,
That sounds like a good solution. I must be lucky as I use never-seize and
really once it sets -sort of- it is fine. I know if the ball and socket do
not seat properly they will leak. I have fixed them before on sleds with a
75% success rate but if they do not fit perfect you might be better to get
new parts That being said, perhaps a new elbow would help -they run about
150$ from Rotax. Y pipe and muffler each are more.
Is it possible that the mating surfaces are dented, out of round not seating
Also is there exhaust leakage or oil drips ? I find that the Exhaust
Manifold Gaskets will make more of a mess if your cylinders were not aligned
or manifold it not true to cylinders.
Dave
Float Flyr
PostPosted: Wed Apr 25, 2007 8:29 am    Post subject: 582 Exhaust Ball Joints Reply with quote
Just as an idea... I haven't had to do this.
When you put your joint together use the "Never-Sieze" and then pack the
joint with fibre glass chord that they use for sealing the doors on wood
stoves. This stuff looks like woven rope but is mad of fibre glass if
nothing else it should keep the "Never-Sieze" from making too much of a mess
on your engine. Ships for hundreds of years used a similar device called
oakum to keep the ocean out... Think of the chord as oakum for your exhaust.
It might just work for you and the stuff is CHEAP, which is why I would give
it a try.
Noel Loveys, RPP
Campbellton, Newfoundland, Canada
Kitfox Mod III-A, 582, B box, Ivo IFA
Aerocet 1100s
noelloveys(at)yahoo.ca
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
olendorf
PostPosted: Fri Apr 27, 2007 6:44 am    Post subject: Re: 582 Exhaust Ball Joints Reply with quote
I coat the ball joints with the high temp silicone sealant that is used on the exhaust springs. It makes the joint air tight and stays flexible. It keeps the parts from grinding together too.
Scott Olendorf
Original Firestar, Rotax 447, Powerfin prop
Schenectady, NY
http://sites.google.com/site/kolbfirestar/
Guy Buchanan
PostPosted: Fri Apr 27, 2007 7:38 am    Post subject: 582 Exhaust Ball Joints Reply with quote
Hi Scott,
What sealant are you using? I didn't think any of them were
good to 1200F. Then again, maybe I don't need 1200F protection there.
Guy Buchanan
San Diego, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
olendorf
PostPosted: Fri Apr 27, 2007 7:47 am    Post subject: Re: 582 Exhaust Ball Joints Reply with quote
here it is:
ULTRA COPPER Hi-Temp RTV Silicone Gasket Maker
PERMATEX 81878
Temperature range -75F to 700F intermittent; resists auto and shop fluids and vibration.
Suggested Applications:
Exhaust manifolds/headers, valve covers, oil pans, timing covers, water pumps, thermostat housings
I know it says 700F but it works fine. I've been doing this for many years and probably 350 hours.
 Filesize:  19.68 KB
 Viewed:  526 Time(s)
Scott Olendorf
Schenectady, NY
Guy Buchanan
PostPosted: Fri Apr 27, 2007 8:23 am    Post subject: 582 Exhaust Ball Joints Reply with quote
Very cool. I'll try it. Thanks.
Guy Buchanan
San Diego, CA
Guy Buchanan
Deceased K-IV 1200
A glider pilot too.
Lynn Matteson
PostPosted: Fri Apr 27, 2007 11:31 am    Post subject: 582 Exhaust Ball Joints Reply with quote
I use a muffler cement to help slide my Jabiru's exhaust pipes into
the muffler. It acts like a lubricant, then when dried, as a sealer.
These are straight pipes into straight pipe stubs in the muffler. The
stuff I got from Performance Automotive is made by Yale Automotive in
Hampshire, Illinois. 847-683-3388 (this info from the tube)
Lynn Matteson
Grass Lake, Michigan
flying w/250+ hrs
Guy Buchanan
San Diego, CA
Lynn
Kitfox IV-Jabiru 2200
N369LM
Float Flyr
PostPosted: Fri Apr 27, 2007 5:10 pm    Post subject: 582 Exhaust Ball Joints Reply with quote
I used to use furnace cement, looks the same, smells the same and gets just
as hard but is a lot cheaper. Sorry guys there seems to be a theme emerging
to my latest posts. I used the furnace cement when I was a poor student.
Still poor, just temporarily gave up the study thingy.
The thing is both the muffler cement and the furnace first cousin get very
hard and won't allow any flex in the joints.... You may as well just weld
the parts together.
Packing the joints the hi-temp RTV or "Modified Oakum" Glass or asbestos
chord will allow the joints to flex as they have to. I was just thinking,
if you gave the inside of the elbow/pipes a thin coat of muffler cement it
could act the same as ceramic shielding on the inside of the pipes and
actually keep heat away from various parts.
Noel Loveys, RPP, AME intern
Aerocet 1100s
[quote] --
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
