WD-657 External Step(s):
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV9-List
mac11hsd(at)earthlink.net
PostPosted: Mon Apr 16, 2007 3:21 pm    Post subject: WD-657 External Step(s): Reply with quote
I am at the point of installing the external steps in my 9-A quick build kit and am very green at this game. The instructions that come with the steps tell me to remove the F-747 baggage compartment floor. These items are pop-riveted in about 14 places. I have never removed an item from the fuselage that is semi-permanently attached. I see no other alternative to the removal of the baggage compartment floor other than removal of the pop-rivets. Would someone please assuage my paranoia and tell me that this is the proper procedure, or if not, just what do I do??
Mac
- The Matronics RV9-List Email Forum -
http://www.matronics.com/Navigator?RV9-List
aurbo(at)ak.net
PostPosted: Mon Apr 16, 2007 3:33 pm    Post subject: WD-657 External Step(s): Reply with quote
Mac,
Drill them out. Get used to it you will do it again.
Mike Ice
RV-9
canopy almost complete, wiring done
retasker(at)optonline.net
PostPosted: Mon Apr 16, 2007 3:42 pm    Post subject: WD-657 External Step(s): Reply with quote
You have to get access to below the floor to install the steps so you
have to remove the pop rivets. One advantage us non-quick builders
have Smile .
Dick Tasker
Mac
steve(at)cleanbrite.com
PostPosted: Mon Apr 16, 2007 4:20 pm    Post subject: WD-657 External Step(s): Reply with quote
Mac,
Why not drill them out and install blind mounting nuts for #8 round head
screws. You'll thank yourself down the road if you ever need to run
additional wiring thru the floor area when the center channel gets filled
up.
Steve
90219 flying 70 hours
bill(at)repucci.com
PostPosted: Mon Apr 16, 2007 5:55 pm    Post subject: WD-657 External Step(s): Reply with quote
Mac,
Before you start drilling out those "pop" rivets, read this tread on the
VAF forum:
http://www.vansairforce.com/community/showthread.php?t=8481&highlight=ri
vet
As for installing plate nuts to hold the floor pans in, this is a great
idea but...
Plate nuts and the resulting screw can add a LOT of weight. If you need
to get in there at some point in the future, you will know how to remove
these rivets and run your extra wires.
As Van's has told me, "Build lightness in."
Bill
RV-9 (and shooting for 1,000 lbs empty weight)
www.repucci.com/bill/baf.html
jc(at)INFONET.COM.BR
PostPosted: Mon Apr 16, 2007 6:17 pm    Post subject: WD-657 External Step(s): Reply with quote
As soon as I removed the blind rivets I cut the upper panel to create a compartment for a
quart of engine oil bottle. I´m so glad now. ´Cause there is no oil in my luggage.
Smile))
Be carefull in removing the blind rivets. Use a new bit and boelub. The inner pin of lind
rivets are harder than the other parts and drill bit hates it.
JC - Aracaju - Brasil
PU-JCI
rv-9a flying 184 hs
building PU-IJC, fuselagem
Citando McCarty <mac11hsd(at)earthlink.net>:
Mac
john(at)morgensen.com
PostPosted: Mon Apr 16, 2007 7:08 pm    Post subject: WD-657 External Step(s): Reply with quote
If I remember right, the instructions call for a 1 1/2" hole for the
torque tube that supports the step. However, you need to enlarge that to
accommodate the weld seem around the 1 1/2" pipe. Save yourself some
grief and use a 1/8" bigger hole saw to begin with. (It might be 1 3/4"
but the principal is the same).
John Morgensen
RV-9A
Mac
bill(at)repucci.com
PostPosted: Thu Apr 19, 2007 6:10 pm    Post subject: WD-657 External Step(s): Reply with quote
JC,
Good point.
In place of an oil locker I used the space under the floors to put my
ELT and strobe power supply. This was done before Van's came out with
those parts to mount them behind the baggage compartment.
Pictures are here:
Strobe: http://www.repucci.com/bill/fuselage/strobe%20power%20pack.jpg
ELT: http://www.repucci.com/bill/fuselage/elt%20with%20door.jpg
Bill
PS. This a -9, not a -9A so I don't have those pesky steps to worry
about.
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV9-List All times are GMT - 8 Hours
