cgroote1(at)yahoo.com Guest
Posted: Mon Apr 16, 2007 8:24 am Post subject: avionics cooling fan |
I can't find much on the search engine for avionics
cooling fans. Is there a consensus of opinion whether
it would be wise to install one in an IFR fitted
machine? I understand that some people do and some don't.
stein(at)steinair.com Guest
Posted: Mon Apr 16, 2007 9:06 am Post subject: avionics cooling fan |
It actually has more to do with what you are installing in the stack then
whether it's IFR or not. For example, things like Chelton screens, GNS-480
and some others have cooling fans built into them. Other things do not. If
you only have one radio like an ICOM installed by itself in the stack,
you're unlikely to need a cooling fan. But, if you ahve a full Garmin
stack, then it's a good idea. Some of the Garmin stuff has cooling ports
cast into the racks. The cooling fans are relatively cheap compared to the
cost of your avionics stack (somewhere around $150-250) and it's cheap
insurance for a $20-30K stack of avionics.
Perhaps of equal importance is not to just have a cooling fan, but some sort
of "vent" holes in the glareshield to let the hot air escape from. Do that
and you'll be in pretty good shape. So, in the end my recommendation is
that depending on your stack you may or may not need to install one.
Cheers,
Stein.
[quote]--
rleffler
Posted: Mon Apr 16, 2007 9:38 am Post subject: avionics cooling fan |
Probably wise to install in any aircraft.
Just put a thermometer on your glare shield in the summer. You can assume it's considerably warmer where your radios are. Keeping them cool may prolong their life.
Depending on your region, you may be able to get by with just an outside air vent circulating air to keep the radios cool. Most places, especially in the summer, there should be a dedicated fan for cooling the radio stack.
I'll stay away from the debate on whether or not just to use a standard computer type box fan, or a dedicated TSO'd avionics fan.
Date: 2007/04/16 Mon AM 11:24:10 EST
Subject: avionics cooling fan
_________________ Bob Leffler
N410BL - Phase I
dc71(at)netspace.net.au Guest
Posted: Mon Apr 16, 2007 2:42 pm Post subject: avionics cooling fan |
The Dynons under Australian summer conditions definitely need cooling
fans to prevent overheating!
Indran
On 17/04/2007, at 12:24 AM, curtis groote wrote:
wayne.e(at)grandecom.net Guest
Posted: Tue Apr 17, 2007 2:58 am Post subject: avionics cooling fan |
I installed them and they work great on the ground. Not flying yet.
Wayne Edgerton #40336
Posted: Tue Apr 17, 2007 3:10 am Post subject: avionics cooling fan |
Curtis,
In my haste I just realized, after reading Steins post, that you said Avionics cooling fans and I mistakenly read defrost fans. Stein had told me the same answer for the Avionics cooling.
Got to open my eyes wider when it's so early in the morning :>}
