601 Rudder light fairing fit
paulried(at)rogers.com
PostPosted: Sun Apr 15, 2007 10:41 am    Post subject: 601 Rudder light fairing fit Reply with quote
I have fitted the supplied fiberglass fairing for the rudder nav light but it is so poorly made that the surface where the aluminum mounting bracket sits is not flat (about 1/8" height difference on the mold line where the two halves are joined). Also and likely more importantly, the edges of the fairing curl up away from the rudder skin when it is clecoed in place. How do you get the fairing to lay flush with the rudder skin?
I have attached a small photo in case my description above is not clear.
Any help with these two issue would be appreciated! Man I hate fiberglass! My hands are itchy.
Paul Riedlinger
 Filesize:  21.7 KB
 Viewed:  582 Time(s)
dredmoody(at)cox.net
PostPosted: Sun Apr 15, 2007 11:39 am    Post subject: 601 Rudder light fairing fit Reply with quote
Hi Paul,
I haven't worked on your specific problem but in general, if a composite part (fiberglass, plexiglas, Lexan, etc.) is not fitting properly and passively, heat the #%!*%!!# with a paintstripper heat gun. Start at lower temperature and work on it patiently so that you reshape the part using the lowest temperature that will soften it enough to overcome its memory. Let me stress that part about low heat / long heat up time. If you get impatient and ramp up the temp too much to get a quick response, you may screw up the part. Once the part is warm enough to lose its shape memory, bend it just past where you want it to stay and maintain that position while it cools. It takes time, patience, and there is a learning curve, but it will work.
Good luck. Hope that helps,
Dred
jeffrey_davidson(at)earth
PostPosted: Sun Apr 15, 2007 12:22 pm    Post subject: 601 Rudder light fairing fit Reply with quote
Well Paul, your fiberglass fairing looks better than mine! I'm just about to install it too. For mine, I will heat it up and try to get a little better shape out of the fiberglass. The fit as it came really is not acceptable. It is too late for me, but if this fairing is installed as the rudder is built, the fairing can be installed with the fiberglass flange on the inside giving a much cleaner installation.
Jeff Davidson
I
PostPosted: Sun Apr 15, 2007 12:50 pm    Post subject: 601 Rudder light fairing fit Reply with quote
Jeff:
Good idea, but too late for me I think. The one side is still open by a few rivets (per Canadian inspection reg’s). I am going to try using a heat gun later tonight to see if that works.
Paul Riedlinger
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of Jeff
Sent: April-15-07 4:23 PM
Subject: RE: 601 Rudder light fairing fit
Jeff Davidson
I
TxDave
PostPosted: Sun Apr 15, 2007 1:34 pm    Post subject: Re: 601 Rudder light fairing fit Reply with quote
Hey Paul,
Dred's advice works well. I used the same technique on my fiberglass wingtip. I had to adjust the flanges for a good fit with the wing skin. I didn't have access to a paint stripper heat gun, so I borrowed my wife's blow dryer. It worked just fine. She never knew.
Dave Clay
bryanmmartin
PostPosted: Sun Apr 15, 2007 1:53 pm    Post subject: 601 Rudder light fairing fit Reply with quote
That's what I did with mine, looks great.
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
Bryan Martin
do not archive.
PostPosted: Sun Apr 15, 2007 2:03 pm    Post subject: 601 Rudder light fairing fit Reply with quote
Thanks Dave. Now that the Nascar race is over, I am headed back to the
garage... and yes, before you ask, I am likely the only Nascar fan in
Toronto! My excuse is I lived in NC for 11 years and caught the bug.
Paul Riedlinger
www.mykitlog.com/paulried/
planecrazydld(at)yahoo.co
PostPosted: Sun Apr 15, 2007 2:32 pm    Post subject: 601 Rudder light fairing fit Reply with quote
I have seen this come by several times and this is just a thought:
The tail is not mass balanced but the plane flies slowly so the idea of flutter is not very alarming. Notching the rudder trailing edge to achieve a cosmetic effect is not something to do lightly as any "loosening" of the control surface will reduce whatever flutter margin there is to some degree. A nicely faired external fitting is also quite possible.
Jeff <jeffrey_davidson(at)earthlink.net> wrote:[quote] v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> st1\:*{behavior:url(#default#ieooui) } <![endif]--> <![endif]--> <![endif]--> Well Paul, your fiberglass fairing looks better than mine! I'm just about to install it too. For mine, I will heat it up and try to get a little better shape out of the fiberglass. The fit as it came really is not acceptable. It is too late for me, but if this fairing is installed as the rudder is built, the fairing can be installed with the fiberglass flange on the inside giving a much cleaner installation.
Jeff Davidson
I
[quote][b]Ahhh...imagining that irresistible "new car" smell?
Check out [url=http://us.rd.yahoo.com/evt=48245/*http://autos.yahoo.com/new_cars.html;_ylc=X3oDMTE1YW1jcXJ2BF9TAzk3MTA3MDc2BHNlYwNtYWlsdGFncwRzbGsDbmV3LWNhcnM-]new cars at Yahoo! Autos.[/url] [quote][b]
amyvega2005(at)earthlink.
PostPosted: Sun Apr 15, 2007 6:01 pm    Post subject: 601 Rudder light fairing fit Reply with quote
regarding the rudder light fairng, alittle Superfill will do the trick.
Juan
Tim Juhl
PostPosted: Mon Apr 16, 2007 2:25 pm    Post subject: Re: 601 Rudder light fairing fit Reply with quote
I would use the heat and a flat piece of aluminum to push the edges down that attach to the rudder. As to where the light attaches..... rough up the gel coat and apply a little superfil between the fiberglass and the metal piece. Cover the bottom of the metal piece with duct tape as the superfil will not adhere to that. After it sets up you can sand it conform with the rest of the piece.
You will probably use superfil or a mix of resin and microballoons in other places to fix the fiberglass pieces. DO NOT use polyester resins..... epoxy resin such as the west system works best. Polyester resins will shrink with time.
Tim
______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Almost done! It'll fly in spring!
PostPosted: Mon Apr 16, 2007 3:49 pm    Post subject: 601 Rudder light fairing fit Reply with quote
Thanks for the suggestions Tim.
Paul Riedlinger
PostPosted: Mon Apr 16, 2007 6:41 pm    Post subject: 601 Rudder light fairing fit Reply with quote
Just to finish this thread up, thanks to all of the people who replied.
I used an old heat gun I had from my model airplane days (used to shrink Monocote) and it took me all of 5 minutes to fix the problem. I left the fairing clecoed to the rudder, and in heating the part up, it just naturally fell down to the rudder surface! Nice. It is not perfect, but a whole lot better than before. The rest can be handled with superfil
Cheers
Paul Riedlinger
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of David Downey
Sent: April 15, 2007 6:33 PM
Jeff <jeffrey_davidson(at)earthlink.net> wrote: [quote] v\:* { BEHAVIOR: url(#default#VML) } o\:* { BEHAVIOR: url(#default#VML) } w\:* { BEHAVIOR: url(#default#VML) } .shape { BEHAVIOR: url(#default#VML) } <![endif]--> st1\:* { BEHAVIOR: url(#default#ieooui) } <![endif]--> (at)page Section1 {size: 8.5in 11.0in; margin: 1.0in 1.25in 1.0in 1.25in; } P.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman" } LI.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman" } DIV.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0in 0in 0pt; FONT-FAMILY: "Times New Roman" } A:link { COLOR: blue; TEXT-DECORATION: underline } SPAN.MsoHyperlink { COLOR: blue; TEXT-DECORATION: underline } A:visited { COLOR: purple; TEXT-DECORATION: underline } SPAN.MsoHyperlinkFollowed { COLOR: purple; TEXT-DECORATION: underline } SPAN.EmailStyle17 { COLOR: navy; FONT-FAMILY: Arial; mso-style-type: personal-reply } DIV.Section1 { page: Section1 } <![endif]--> <![endif]--> Well Paul, your fiberglass fairing looks better than mine! I'm just about to install it too. For mine, I will heat it up and try to get a little better shape out of the fiberglass. The fit as it came really is not acceptable. It is too late for me, but if this fairing is installed as the rudder is built, the fairing can be installed with the fiberglass flange on the inside giving a much cleaner installation.
Jeff Davidson
I
Ahhh...imagining that irresistible "new car" smell? Check out
href="http://www.matronics.com/Navigator?Zenith-List">http://www.matronhref="http://forums.matronics.com">http://forums.matronics.com
[/b]
