M3X incidence & dihedral
pj.ladd(at)btinternet.com
PostPosted: Tue Apr 10, 2007 1:14 am    Post subject: M3X incidence & dihedral Reply with quote
Also is this 1.5deg per wing panel or combined? >>
Hi Scott,
if you change the dihedral angle by 1.5 degrees at each panel you will have
a unique and very eyecatching design.
Cheers
Pat
JetPilot
PostPosted: Tue Apr 10, 2007 3:17 pm    Post subject: Re: M3X incidence & dihedral Reply with quote
Cheers
Pat
You mean something like this ? It would have been funky looking, but it was so unique and eye catching, that it did not stay that way...
Kolb MK-III Xtra, 912-S
JetPilot
Hi Scott,
Cheers
Pat
 Filesize:  330.49 KB
 Viewed:  580 Time(s)
icrashrc
PostPosted: Wed Apr 11, 2007 8:20 pm    Post subject: Re: M3X incidence & dihedral Reply with quote
As near as I can tell from that pic there is at least 6 deg of dihedral on that plane.
I went back thru all the pics I've taken of Kolbs over the years and measured the dihedral angle where possible. I've found anywhere between zero and 5 degrees total over the entire wing. Anything less than 1 degree per wing half tends to look like the wingtips are drooping to me.
Donnie (at) Kolb told me the proper spec for the M3X is 1.5 degrees per wing half. He also told me incidence should be 2.8 degrees.
BTW, Piper Cubs appear to have 1 degree per panel.
Scott
www.ill-EagleAviation.com
PostPosted: Wed Apr 11, 2007 8:36 pm    Post subject: M3X incidence & dihedral Reply with quote
| Scott
Scott:
That is what Homer thought too. So he added a tiny bit of dihedral
for aesthetic reasons only. He preferred a staight wing, but it
looked like they drooped when sitting on the ground.
I have no idea how many degrees dihedral the wings on my Ultrastar,
Firestar, or mkIII have. The instructions said to put a block under
the outboard rib to raise it a certain distance above level. That is
what I did and I am happy.
When he recently rebuilt the 1985 Oshkosh Grand Champion Ultralight,
his Kolb Firestar, he added addtional dihedral to see how it would
fly. I forget how many degrees, but he told me he kinda liked it.
icrashrc
PostPosted: Thu Apr 12, 2007 7:24 am    Post subject: Re: M3X incidence & dihedral Reply with quote
| Scott
John,
I know it's been a while but do you have any idea how big the block of wood was and where exactly you were supposed to place it?
Scott
PostPosted: Thu Apr 12, 2007 7:51 am    Post subject: M3X incidence & dihedral Reply with quote
| Thanks,
| Scott
Scott/Gang:
Just so happens I have a revised copy of the Kolb MKIII Builders
Manual, 7/29/92.
"INSTALLING LIFT STRUTS.
The next step is the installation of the wing struts. Set the wing
dihedral by raising the wing tip 1-1/2 inches (measured at the
outboard rib). Install a shim under the wing at the H-supports to
hold this position. Now the lift struts may be made to fit."
That is verbatem out of the manual, and the distance and procedure I
remember from doing mine in 1991.
IIRC, the Ultrastar and Firestar were set at 1", outboard rib.
Take care,
ul15rhb(at)juno.com
PostPosted: Thu Apr 12, 2007 10:51 am    Post subject: M3X incidence & dihedral Reply with quote
Scott, I went with 2.5 inches measured from the last rib. It looks
better and there still is plenty of maneuverability.
Ralph Burlingame
Original Firestar
20 years flying it
| Scott
under
is
John,
Scott
http://forums.matronics.com/viewtopic.php?p=106503#106503
Interested in getting caught up on today's news?
Click here to checkout USA TODAY Headlines.
http://track.juno.com/s/lc?s=198954&u=http://www.usatoday.com/news/front.htm?csp 4
JRatcli256(at)aol.com
PostPosted: Thu Apr 12, 2007 6:07 pm    Post subject: M3X incidence & dihedral Reply with quote
Hi gang,
Was told by Donnie at TNK - the M3x Dihedral they recommend is .6 degrees. Called today and verified.
Don't know how that relates to the block under end rib method. I'm using a digital level.
John Ratcliffe
See what's free at AOL.com.
by0ung(at)brigham.net
PostPosted: Thu Apr 12, 2007 7:07 pm    Post subject: M3X incidence & dihedral Reply with quote
measured the dihedral angle were possible. I've found anywhere between zero
It seems that when building the mkIIIc the instructions said to rig the
wings as straight as possible while making the forward and rear attach
points. When attaching the lift struts, the wing tips were to be raised 1
1/2 inches measured at the outboard rib. I followed the instructions and
when flying and I put the plane in a 30 deg bank and let go of the stick the
plane wanted to continue to roll...( negative roll stability) when I
rebuilt I doubled the dihedral by raising the end rib 3 inches... now when
in a 30 deg bank the plane wants to stay put ( neutral roll stability). I
could not tell any other differences.
Boyd.
icrashrc
PostPosted: Fri Apr 13, 2007 10:05 am    Post subject: Re: M3X incidence & dihedral Reply with quote
John,
Thanks!
BTW, 1 1/2" is .6 degrees per wing half.
Scott
[quote
Scott/Gang:
Manual, 7/29/92.
Take care,
mkIII[/quote]
Scott
