Sligtly damaged QB Fuse
Mike Whisky
PostPosted: Thu Apr 12, 2007 11:38 pm    Post subject: Sligtly damaged QB Fuse Reply with quote
Hello,
I received yesterday my QB fuse and there is a dent in the front of the firewall where you attach the cowling. Do you thing it is ok to just bend it up again and make it straight?
Any suggestions which method would work best?
Michael
www.wellenzohn.net
 Filesize:  23.13 KB
 Viewed:  416 Time(s)
RV-10 builder (flying)
#511
glastar(at)gmx.net
PostPosted: Fri Apr 13, 2007 12:36 am    Post subject: Sligtly damaged QB Fuse Reply with quote
Michael,
a picture 600*400 attached or on your website would help to judge.
CU 2morrow in Bern I hope!
Werner
Michael Wellenzohn wrote:
Hello,
Michael
www.wellenzohn.net
RV-10 builder (wings)
#511
http://forums.matronics.com/viewtopic.php?p=106649#106649
http://forums.matronics.com//files/fuselage11_777.jpg
Mike Whisky
PostPosted: Fri Apr 13, 2007 7:16 am    Post subject: Re: Sligtly damaged QB Fuse Reply with quote
Hello Werner,
yes I'll be in Bern tomorrow with the Cessna 177 HB-CXA.
I actually did add a picture. Thats the link to my website.
http://www.wellenzohn.net/Fuselage/fuselage11.jpg
C U tomorrow
Michael
#511
owl40188(at)yahoo.com
PostPosted: Fri Apr 13, 2007 7:54 am    Post subject: Sligtly damaged QB Fuse Reply with quote
Michael
I would carefully bend it back and check it for tears, gouges or scratches. If you don't have any you should be okay although I would keep an eye on it during inspections. If you have a tear than you would want to clean it up and repair it using a doubler. You might also want to send a picture to Vans to document the damage.
Niko
40188
KiloPapa
PostPosted: Fri Apr 13, 2007 3:43 pm    Post subject: Sligtly damaged QB Fuse Reply with quote
Michael,
I would submit that question to Van's.
Kevin
40494
<rv-10(at)wellenzohn.net>
Hello,
straight? Any suggestions which method would work best?
Michael
www.wellenzohn.net
Kevin
40494
