Posted: Sun Apr 08, 2007 7:10 pm Post subject: Damaged Head Screw Removal |
I decided to change the name of the thread to bring it onto the new topic.
I have had good success with "Easy Outs" that can be purchased at ?most?
hardware stores. Just chuck them up in a drill, put it on reverse, and
pull the trigger very slowly (a good cordless drill with great speed
control is a plus here). It works very well and takes almost no time at
all. It beats the socks off drilling IMHO.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
www.saintaviation.com
352-427-0285
MauleDriver wrote:
Well, it looks like I'm going to remove both of them - perhaps the right
for no particular reason. However, the fact that a couple of screws
aren't coming out, I'm glad I'm finding that out now when it's
relatively easy to fix.
These are my first stripped screw heads - looks like it's time to drill
and use a screw extractor of some sort on at least one of them. I've
never done this before. Looking at an extractor in Spruce's catalog.
What are any of you using?
David Maib wrote:
> I had problems with a few of the screws not wanting to come out, too.
> Twisted the head off of one of them. The plans said to remove the
> tanks, so I did. Have installed the senders, repaired a dent that I
> put in one leading edge, leak checked, and they are now ready to go
> back on. However, it is a little easier to finish the stall warning
> system, wiring, pitot system, etc. with the tanks off. I am also
> installing SafeAir1 extended range tanks, so the main tanks have to be
> off for that reason.
> David Maib
> 40559
> wings
> do not archive
> On Apr 7, 2007, at 10:41 PM, MauleDriver wrote:
> I'm starting work on my QB wings and trying to think through whether I
> should remove the tanks to inspect, install the senders, test for
> leaks, ease access for other parts, etc. Any comments?
> I started removing one and immediately ran into some problems with the
> a few screws not coming out easily. That alone may be a good reason
> to remove, inspect, and re-install.
> Thanks for comments.
MauleDriver(at)nc.rr.com Guest
Posted: Wed Apr 11, 2007 1:52 pm Post subject: Damaged Head Screw Removal |
Here is what I learned:
A custom made T-handle screw driver made removal a breeze (photo
attached). With this driver, leverage can easily be applied as needed.
I now have no worries about assembly or disassembly or slightly bunged
up screw heads. This driver makes all conditions easy to handle. Much
better than a brand new Craftsman phillips head driver with a standard
handle.
A little smear of valve lapping compound on the tip increases the grip
significantly
There are various types of screw removal tools that can be applied to
damage screw heads. After trying several types, I had the best
experience with a Sears Craftsman "Drill-out " Micro Power Extractor
Kit - Model 52157. It is a set 7 double ended power driver tips. One
end has a cutter to drill a hole in the head, the other an extractor to
insert into the hole and drive the screw out. Good directions were
included and it worked exactly as described. Smaller sets are available.
Patience is key but the right tools make it very easy to manage.
Thanks all for the help.
Jesse Saint wrote:
Jesse Saint
352-427-0285
>> David Maib
>> 40559
>> wings
>> do not archive
36.43 KB |
261 Time(s) |
