Ted French
Joined: 09 Jan 2006 Posts: 54 Location: Kelowna BC Canada
Posted: Sun Apr 01, 2007 12:52 pm Post subject: Weight & Balance and POH |
I have posted my POH and W & B spreadsheet at
http://www3.telus.net/elfrench/RV-10_main.htm
Take a look and tell what you think
Ted French C-FXCS
RV-10 ready to fly. Just need my test pilot.
_________________ Ted French
RV-10 fuselage |
john_rv10(at)yahoo.com Guest
Posted: Sun Apr 01, 2007 11:11 pm Post subject: Weight & Balance and POH |
Ted,
I hope I have transposed your numbers correctly to an excel spreadsheet.
If I have, I comment as follows:-
<![if !supportLists]>1. <![endif]>Your numbers suggest that you can’t carry 4 adults and full baggage because you will be overloaded and outside aft C of G
<![if !supportLists]>2. <![endif]>Your numbers indicate a potential problem with aft C of G at gross take off if you have two adults in the rear seats. This problem gets worse as you burn fuel.
<![if !supportLists]>3. <![endif]>There seems to be an opportunity to move some weight forward and get a better weight and balance spread. With pilot only, you are still well aft of the forward C of G, and at gross you are aft of the aft C of G
John Cleary
Weight_&_Balance_spreadsheet_a.xls |
32 KB |
403 Time(s) |
flysrv10(at)gmail.com Guest
Posted: Mon Apr 02, 2007 3:22 am Post subject: Weight & Balance and POH |
I like your POH. It seems to be very comprehensive. I might steal
it to use as a guide to develop mine (that is the idea? right?).
Do not archive.
On Apr 1, 2007, at 4:49 PM, Ted French wrote:
Ted French
Posted: Mon Apr 02, 2007 5:35 am Post subject: Weight & Balance and POH |
John
Correct on all counts.
I doubt that any of the 10's out there are much different. If you want four adults in the plane, then you need to be careful what you load in the bagg compartment.
There is an opportunity to shift weight forward during construction. I have the 3 blade MT prop which I understand is a bit lighter than the Hartzell. Also, my panel is a bit lighter than some I guess. Its GRT displays. Other than that, I'm not too sure what one could do to shift the CG forward.
Still a very useable aircraft for a family with 2 kids, or one big kid.
Ted French C-FXCS
RV-10
RV-10 fuselage |
sam(at)fr8dog.net Guest
Posted: Mon Apr 02, 2007 5:54 am Post subject: Weight & Balance and POH |
Just curious, what is your battery configuration?
Sam Marlow
Ted French wrote: [quote] st1\:* { BEHAVIOR: url(#default#ieooui) } <![endif]--> (at)page Section1 {size: 612.0pt 792.0pt; margin: 72.0pt 77.95pt 72.0pt 77.95pt; } P.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Times New Roman" } LI.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Times New Roman" } DIV.MsoNormal { FONT-SIZE: 12pt; MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Times New Roman" } A:link { COLOR: blue; TEXT-DECORATION: underline } SPAN.MsoHyperlink { COLOR: blue; TEXT-DECORATION: underline } A:visited { COLOR: purple; TEXT-DECORATION: underline } SPAN.MsoHyperlinkFollowed { COLOR: purple; TEXT-DECORATION: underline } P.MsoPlainText { FONT-SIZE: 10pt; MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Courier New" } LI.MsoPlainText { FONT-SIZE: 10pt; MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Courier New" } DIV.MsoPlainText { FONT-SIZE: 10pt; MARGIN: 0cm 0cm 0pt; FONT-FAMILY: "Courier New" } DIV.Section1 { page: Section1 } OL { MARGIN-BOTTOM: 0cm } UL { MARGIN-BOTTOM: 0cm } John
Ted French C-FXCS
RV-10
Tim Olson
Posted: Mon Apr 02, 2007 6:06 am Post subject: Weight & Balance and POH |
I would like to take the opportunity while we're discussing this
to ask for something. If everyone who has a POH that they're
willing to share would send it to me, just email it to me
directly. I'd like to compile a list in my TIPS area where
people can gather a dozen or more POH versions for them to use
to make their own. I heard from another builder today that
they got one that didn't have "Lean aggressively" after engine
start on it, so they added it, but then they saw that it was
on mine when I sent it...so obviously things change along the way
since mine was used as a foundation for many offshoots.
Having a variety of them available would give builders some good
food for thought as they put their own together...especially in
situations like Dan Lloyd...his would be the first Subie one
available. I won't have time this a.m. to put them out on the
website, but if you email them to me within the next day or so,
I can have a page ready tonight/tomorrow. If you send me
your W&B, I can put that in the same area. There are a lot
of creative people out there, so it's bound to generate some
good information for others. Also, if you update it, just
send me the latest and it's easy to swap in your new version.
Rob Kermanj wrote:
I like your POH. It seems to be very comprehensive. I might steal it
Do not archive.
> Thanks
> Ted French C-FXCS
Posted: Mon Apr 02, 2007 6:37 am Post subject: Weight & Balance and POH |
Good idea Tim!
Sam Marlow
Do not archive.
Tim Olson wrote: [quote]--> RV10-List message posted by: Tim Olson <Tim(at)MyRV10.com> (Tim(at)MyRV10.com)
Rob Kermanj wrote:
| Quote: | --> RV10-List message posted by: Rob Kermanj <flysrv10(at)gmail.com> (flysrv10(at)gmail.com)
I like your POH. It seems to be very comprehensive. I might steal it to use as a guide to develop mine (that is the idea? right?).
Do not archive.
rv10builder(at)verizon.ne Guest
Posted: Mon Apr 02, 2007 9:29 am Post subject: Weight & Balance and POH |
I wonder what we would do without you, Tim!
Thanks!
Pascal
Do not Archive
Posted: Mon Apr 02, 2007 9:53 am Post subject: Weight & Balance and POH |
We just flew a 4-hour flight with 4 big guys and baggage with no problem. It gets close to the aft CG, especially when you burn the tanks down, but doesn’t really go aft of it unless you start putting extra weight in the tail to offset the “nose-heavy-ness” of the plane. That’s why I won’t be putting any extra batteries back there. This plane can carry 4 adults with bags and full fuel with no problem if you build it right. How may others can claim that? Cirrus have 650 lbs full-fuel useful load if you are lucky. A new Saratoga next door to us has 450 lbs full-fuel useful load. They sure are lucky to have those extra 4 seats in the back, because it looks a lot like a 6-place on the ground.
Jesse Saint
Saint Aviation, Inc.
www.saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Ted French
Sent: Monday, April 02, 2007 9:33 AM
Subject: RE: Weight & Balance and POH
John
Ted French C-FXCS
RV-10
jjessen
Posted: Mon Apr 02, 2007 10:10 am Post subject: Weight & Balance and POH |
Yeah, a person at my airfield just bought an older Bonanza 35 (not sure the year or model) and found that no matter how he tries, he cannot get both kids and his wife, full fuel and baggage for a long cross country. He'd be okay on take off, but be seriously out of CG to the rear by the time he was wanting to land. Van's did a nice job getting this to be a real four person plane.
John J
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint
Sent: Monday, April 02, 2007 10:53 AM
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
John
Ted French C-FXCS
RV-10
-----Original Message-----
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com]On Behalf Of RV_10
Sent: April 1, 2007 11:58 PM
Ted,
1. Your numbers suggest that you can’t carry 4 adults and full baggage because you will be overloaded and outside aft C of G
2. Your numbers indicate a potential problem with aft C of G at gross take off if you have two adults in the rear seats. This problem gets worse as you burn fuel.
3. There seems to be an opportunity to move some weight forward and get a better weight and balance spread. With pilot only, you are still well aft of the forward C of G, and at gross you are aft of the aft C of G
John Cleary
