cowl hinges
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV9-List
mmul6471(at)bigpond.net.a
PostPosted: Fri Mar 30, 2007 6:00 pm    Post subject: cowl hinges Reply with quote
I have been checking on my cowl preparations and installation
instructions for my RV9A. It has an O320E3D engine installed in it. The
finish kit has one aluminium hinge 6ft long for joining the two cowl
halves together, fairly easy to identify. However, the Vans contents lists
says
there is also 9 ft of 1/8 piano hinge. Exactly what dimension does the 1/8
refer to? Is it supposed to be the width of the hinge, the thickness of the
hinge, or the diameter of the pins?(1/8 does not fit any of these
measurements).
I received not one nine foot length, but a six foot length and a three foot
length. I also received thee other three foot lengths of piano hinge which
are of a lighter gauge, (two are 1/16 inch thick, the third piece slightly
thicker) but are not as wide as the six foot and three foot larger ones.
Does anyone know where each bit resides?
I emailed Vans with this question, but after 5 days have received no reply,
perhaps they are busy getting ready for sun'n'fun.
Mick Muller,
Builder 90701
- The Matronics RV9-List Email Forum -
http://www.matronics.com/Navigator?RV9-List
rveighta(at)earthlink.net
PostPosted: Sat Mar 31, 2007 5:11 am    Post subject: cowl hinges Reply with quote
Rick, I built an 8A, but I'm pretty sure the cowl attaches the same way as for a 9A. You have two sizes of piano hinge in your finish kit; the widest (when opened) one attaches around the circumference of the cowl halves at the firewall. This hinge also uses a heavy duty stainless steel pin. The smaller hinge attaches horizontally and uses a carbon steel pin, which in my case was already installed in the hinge. In my case, the wider hinges had regualr carbon steel pins installed and I had to remove these and install the seperately supplied stainless pins.
Of course, when I say the wider hinge installs around the circumference of the cowl, I don't mean all in one piece, but in segments, per the drawing. Don't know what the "1/8" references.
Walt Shipley Flying RV-8A, RV-8 Finishing
DO NOT ARCHIVE
rv9jim(at)juno.com
PostPosted: Sat Mar 31, 2007 10:52 am    Post subject: cowl hinges Reply with quote
Mike,
The hinges are determined by the pin diameter. I had some
similar problems when I put my cowling together. The lower hinges (down
both sides and the two along the bottom) all use "full size 1/8" pins".
The upper cowling uses a smaller diameter pin instead of the full size
pin . The reason for this is you have to use a smaller dia. pin to go
around the curvature of the cowling. The actual dia. of the top cowling
pin is .089" and the lower cowing pin is .117" (1/8"). On the upper
pins, I put a 90 deg.bend of about 1-1/2" at the end that you will have
to hold on to when placing and removing them. I also floxed the hinges
in addition to riveting to keep things neat from shaking about. I did
this to the lower hinges in addition to the upper ones. I think I have
pix of them on my web site if you want to look.
www.websites.expercraft.com/jimn
Jim
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> RV9-List All times are GMT - 8 Hours
