danny shepherd
Joined: 27 Jan 2006 Posts: 117 Location: north Wales, United Kingdom
Posted: Thu Mar 29, 2007 6:46 am Post subject: alternator |
Hi All,
After refitting the engine (912s) having completed Mod 72, I
find that the alt light didn't come on. I've checked all the wires and
the bulb. I started the engine for a few minutes and it seems that there
is no charge from the alternator. Again I checked all the wires from
the alternator to the regulator fuses etc. As every thing was working
fine before, and I haven't touched or altered anything I'm a little
confused. Could the regulator be duff ? Any advise would be welcome,
but bear in mind I'm no electrician
Cheers Danny ( G-c.e.r.i )
rehn(at)rockisland.com Guest
Posted: Thu Mar 29, 2007 9:06 am Post subject: alternator |
Danny
Since things were working before I would look again at each item you
disconnected and reconnected and others you may have bumped or pulled on.
Check the terminal connections at end of wires and also grip end of terminal
and give slight pull on wire to assure there is not a break inside of the
insulation sheath of wire. Check and recheck. Make sure your grounds are
good. Its probably not your regulator if it was working before but check
your connections there as well.Good luck.
Jerry
topglock(at)cox.net Guest
Posted: Thu Mar 29, 2007 10:26 am Post subject: alternator |
Had a similar experience. Turned out to be a blown main fuse...
Jeff - Baby Blue
268 hours
danny(at)mcwalterscafe.co.uk wrote:
Quote: |
<danny(at)mcwalterscafe.co.uk>
Hi All,
and the bulb. I started the engine for a few minutes and it seems that
there is no charge from the alternator. Again I checked all the wires
from the alternator to the regulator fuses etc. As every thing was
working fine before, and I haven't touched or altered anything I'm a
little confused. Could the regulator be duff ? Any advise would be
welcome, but bear in mind I'm no electrician
danny shepherd
Posted: Fri Mar 30, 2007 3:43 am Post subject: alternator |
Jerry / Jeff.
Thanks for your replies. I'll go back in the hangar
this afternoon, with my wee meter, and check again.
Cheers Danny (G-c.e.r.i)
