Air Brakes
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> L29-List
ncam(at)wave.co.nz
PostPosted: Tue Mar 27, 2007 1:04 am    Post subject: Air Brakes Reply with quote
I am puzzled about use of airbrakes? my instructor doesn't like them at all.
What is the appropiate use of them in the circuit, my handling notes only mentions to
retract them after landing, but doesn't mention them at all apart from this.
Yours in anticipation
Neville Cameron
(very Newbie)
- The Matronics L29-List Email Forum -
http://www.matronics.com/Navigator?L29-List
jorgen.nielsen(at)mweb.co
PostPosted: Tue Mar 27, 2007 10:17 am    Post subject: Air Brakes Reply with quote
I use them – but they not very effective in the circuit or at lowish speeds. Have always felt that the tiny green indicator should be a big bright red one though.
From: owner-l29-list-server(at)matronics.com [mailto:owner-l29-list-server(at)matronics.com] On Behalf Of Neville Cameron
Sent: 27 March 2007 11:04 AM
To: l29-list(at)matronics.com
Subject: Air Brakes
Neville Cameron
(very Newbie)
Bcolombo(at)twcny.rr.com
PostPosted: Tue Mar 27, 2007 11:00 am    Post subject: Air Brakes Reply with quote
I use them as well. it allows me to keep the turbine spooled up just a little bit more in case I have to go around while still maintaining the proper final approach speed. I am sure everyone is a little different but i just feel better that way.
PostPosted: Tue Mar 27, 2007 11:42 am    Post subject: Air Brakes Reply with quote
BTW, my instructor taught me that WHENEVER I increase throttle to check the button on throttle forward. I.e., throttle forward, brake button forward. A good habit to have.
From: owner-l29-list-server(at)matronics.com [mailto:owner-l29-list-server(at)matronics.com] On Behalf Of Brian Colombo
Sent: 27 March 2007 08:59 PM
Subject: Re: Air Brakes
[b]I use them as well. it allows me to keep the turbine spooled up just a little bit more in case I have to go around while still maintaining the proper final approach speed. I am sure everyone is a little different but i just feel better that way.[/b]
Colyergreg(at)aol.com
PostPosted: Tue Mar 27, 2007 8:15 pm    Post subject: Air Brakes Reply with quote
They can be used on final so you can have a higher engine RPM thus you don't have the spool up time lag incase of go around. Also they deploy automaticly at 440 knots VNE speed. They also work good to help slow down quicker for gear extention and such....
Greg
AOL now offers free emap://www.aol.com?ncid=AOLAOF00020000000339" href="http://www.aol.com?ncid=AOLAOF00020000000339" target="_blank">AOL.com.
SD737(at)aol.com
PostPosted: Tue Mar 27, 2007 8:35 pm    Post subject: Air Brakes Reply with quote
L-29 Speedbrakes? LOL..... Do whatever makes you feel good.
It's a switch that doesn't do much, so if you put them out and forget you flipped the switch it's no big deal.
How about a new topic.
AOL now offersle="http://www.aol.com?ncid=AOLAOF00020000000339" href="http://www.aol.com?ncid=AOLAOF00020000000339" target="_blank">AOL.com.
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> L29-List All times are GMT - 8 Hours
