frank.phyllis(at)mindspri Guest
Posted: Mon Mar 12, 2007 4:47 am Post subject: Popped CB |
I started my 912ULS for the first time. Ran like a charm. However, at
both starts the alt cb popped. I used the Z16 diagram. Obviously I
have "crossed wires" some place--any ideas?
Frank McD
nuckollsr(at)cox.net Guest
Posted: Mon Mar 12, 2007 9:18 am Post subject: Popped CB |
At 08:45 AM 3/12/2007 -0400, you wrote:
When did the breaker pop? As soon as you pushed the starter button?
When you released the starter button? Do you have a diode across the
coil of your starter contactor? Did you have the alternator
turned ON while cranking or did you turn it on after the engine was
running?
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
rdunhamtn(at)hotmail.com Guest
Posted: Tue Mar 13, 2007 3:16 am Post subject: Popped CB |
Frank,
I wired my SkyRanger/912UL via Z-16 also. It does the same thing. I just
start the engine with the MASTER in the BAT position and then go to BAT/ALT
after the engine is running, then turn on all loads. Shut-down is opposite
sequence.*
I didn't install a diode across the starter contactor coil but plan to.
Will check next time I crank her up to see exactly when it happens and give
you another data point.
Rodney in Tennessee
* I use the "5-M's" mnoemonic to remember shut-down sequence.
...Music - turn off all loads.
...Mags - check.
...Mixture - full lean (for the 912UL I just pull throttle to the idle
stop).
...Mags - off.
...Master - off.
Mortgage rates as low as 4.625% - Refinance $150,000 loan for $579 a month.
Intro*Terms
https://www2.nextag.com/goto.jsp?product=100000035&url=%2fst.jsp&tm=y&search=mortgage_text_links_88_h27f6&disc=y&vers=743&s=4056&p=5117
Posted: Wed Mar 14, 2007 7:22 am Post subject: Popped CB |
The CB popped when I released the starter contactor (switch with key).
Master was on BAT & ALT. I tried starting with just BAT & it did not
pop. It did not pop when I switched to Alt after starting with Bat
only.
I noticed this time I'm not getting a charge from Alt (verified master
switch on Alt) at 2400RPM.
I overlooked the diode on the starter contactor so, no, I do not have
one. Maybe that's the problem???
Frank
Posted: Wed Mar 14, 2007 7:46 am Post subject: Popped CB |
At 11:20 AM 3/14/2007 -0400, you wrote:
only.
Hmmm . . . this needs troubleshooting. Has it worked
in the past?
| Quote: | I overlooked the diode on the starter contactor so, no, I do not have
I'll bet on it. But in any case, starting with the alternator
off is a reasonable procedure too. However, your starter
switch will appreciate having the diode added.
Posted: Wed Mar 14, 2007 6:58 pm Post subject: Popped CB |
I'll add the diode.
Re the alternator not charging. This is a new engine with first starts
so there's no history--hasn't worked from the beginning.
Frank
Posted: Sat Mar 17, 2007 6:36 pm Post subject: Popped CB |
It looks (in the wiring diagram) like the starter contactor diode is
internal. Do I need to purchase another contactor with the diode across
the coil or is there a way to add it externally?
so there's no history--hasn't worked from the beginning. I've
re-checked the wiring and it seems to be connected properly but . . .
still not showing a charge.
Frank
Posted: Sun Mar 18, 2007 6:50 am Post subject: Popped CB |
At 10:33 PM 3/17/2007 -0400, you wrote:
The diode can be inside or outside . . . some of my drawings
show it inside because the starter contactor I used to sell
had it built in . . . but you can put one on the outside.
| Quote: | Re the alternator not charging. This is a new engine with first starts
How do you deduce whether or not it's charging? What
kind of instrumentation do you have?
Posted: Sun Mar 18, 2007 3:50 pm Post subject: Popped CB |
across
| Quote: | the coil or is there a way to add it externally?
Is it possible to put a diode on the outside of a three connector relay?
I'm using the Grand Rapids Tech EIS. The window where "Voltage" is
displayed showed ~ 10.8 volts. Rotax manual indicates a permanent
output of 13.5 v.
Additionally, the Dynon EFIS would not come on with the Master, but it
did come on with the EBus switched on (with the master also on). (When
testing during installation I noted previously the Dynon will come on
with the master if the battery is fully charged. When battery is not
fully charged the Master does not bring it on line but the EBus will.)
Frank
Posted: Mon Mar 19, 2007 6:16 am Post subject: Popped CB |
output of 13.5 v.
Okay, you need to put a voltmeter on the AC input wires to the
regulator with the engine running (yellow) and see what voltage
you get there at moderate RPMs (don't need to run up to full
throttle . . . just see that here's a substantial voltage there
- 20 volts or more).
Do I presume correctly that you're wired per the latest verstion
of Z-16? Is the relay closing (hear it 'click') when you move
the master switch to full up position? You can do this while the
engine is not running so you can listen.
If the regulator is still the same version I looked at some years
ago, it depends on a GOOD ground between regulator case and
your firewall ground bolt.
bob(at)bob-white.com Guest
Posted: Mon Mar 19, 2007 9:33 am Post subject: Popped CB |
On Sun, 18 Mar 2007 19:49:39 -0400
<frank.phyllis(at)mindspring.com> wrote:
<snip>
<snip>
Hi Frank,
As best I can tell, this question wasn't addressed so I will take the
liberty of replying.
Yes. One side of the coil is connected internally to the contact that
goes to the battery, and the other side of the coil is grounded by a
switch on the panel. To put the diode across the coil, connect the
cathode to the battery contact and the anode on the coil terminal.
small sketch attached.
Bob W.
N93BD - Rotary Powered BD-4 - http://www.bob-white.com
First Flight: 11/23/2006 7:50AM - 3.8 Hours Total Time
Cables for your rotary installation - http://www.roblinphoto.com/shop/
19.12 KB |
312 Time(s) |
Posted: Mon Mar 19, 2007 6:55 pm Post subject: Popped CB |
Thanks Bob
Posted: Wed Mar 21, 2007 5:03 am Post subject: Popped CB |
output of 13.5 v.
I was able to get 20 v at 2600 RPM
I have Revision 11, May 05. Yes, the battery relay closes (I can hear
it click and the EIS, radio, etc comes on).
Regulator is well grounded--bolted directly on firewall and check with
Ohm meter = 0.
Frank
