kenbpeck(at)comcast.net Guest
Posted: Wed Jan 04, 2006 3:55 am Post subject: Lights on VS and When to buy options |
I'm sure there is an archive that answers my questions, so if someone will
please point me to it, I'll go read through the archives....
Question #1: As an additional 'classy' touch, I thought I put a couple of
small lights in the HS pointing up at the VS - you know, kind of like they
do on commercial planes. Was thinking probably just a couple of leds. -
anyone done this, thought about it, have reasons why I can't / shouldn't?
Question #2: I'm close to finishing the HS, planning the -10 to do some
minimal IFR in the plane, so night lighting, collision avoidance, and
autopilot will be a necessity. Can anyone offer guidance about when in the
process I need to decide to buy the additional components that don't come in
the kit?
Ken
-10 HS riveting
Central FL
bob.condrey(at)baesystems Guest
Posted: Wed Jan 04, 2006 7:20 am Post subject: Lights on VS and When to buy options |
Ken,
No comment about your first question. In terms of timing for purchasing
items, you can hold off on purchasing the actual lights, etc. until
you're finishing up the plane. Running the wire will potentially make
your life easier down the road. Some have run conduit through the wings
but there is reasonable access to run it through the stock snap bushings
after the wings are complete - it will take more time without conduit
however. I installed my wing wiring before closing them up and just
used the stock snap bushings. Running conduit below the baggage floor
and/or behind the right side baggage wall is a necessity. These panels
are riveted in place and you'll need to run wire for battery power,
contactor control, strobes, strobe power supply, position lights, etc
from the tailcone to the panel and/or wings. I'd also suggest a conduit
in the tailcone from the bay where the battery is to the aft bay.
You will have to install a mount for a heated pitot before closing up
the wing. Also, it's much easier to install the AP roll servo while the
bottom wing skin is off, but it can be done through the access panel
(for TruTrak, can't speak for others). This is really a trade off
between a 30 min job with the skin off and a couple hours (my guess)
with scraped knuckles and cussing if the skin is already on.
Here's a list of specific potential equipment with my thoughts:
Strobes/position lights: these mount on the bottom of the rudder and in
the wingtips - can be done anytime. Power supply is typically being
mounted in the tailcone, same bay as the battery.
Landing lights: Kit from Van's installs in the wingtips and can be done
anytime. Other options (Duckworks) install in the outboard leading edge
of a wing. It is my understanding that these can be installed after
completion but is easier before.
Antennas: typical mounting locations for navs are either in the wingtips
(Archer - I have one in each wingtip) or on the bottom aft end of the
tailcone. MB can also be in a wingtip (my installation) or on the
bottom of the fuselage. Comms on the bottom of the fuselage (mine are
below the rear seats). Transponder on the bottom of the fuselage (mine
is in the aft end of the bay with the battery box). Only areas that are
inaccessible after completion are below the rear seats and baggage
floor. In retrospect I'd probably mount my comms just forward of the
rear seats in the area below the tube that drives the flaps.
AP servos (TruTrak): Roll servo mounts in the wing - very clean install.
A stock bracket for the aileron bellcrank is replaced with one from TT
that includes mounting holes for the servo. As stated earlier - can be
done after wing closeout but is easier before. Pitch servo is attached
to aft part of the battery tray assembly with a bracket supplied by
Van's in the fuselage kit. It is possible to purchase the servos and
defer the actual AP decision since most TT models use the same servos.
This allows you to defer the majority of the expense (and specific model
decision).
Heated Pitot: You'll need a Gretz (or equivalent) mount. This needs to
be put in before the bottom wing skin is attached.
PSS Angle of Attack system: the pressure taps install in the leading
edge of an outboard wing bay. Easily installed after wing completion.
It is possible to purchase the system in two kits to get the pressure
taps and tubing early and defer the majority of the expense (and
specific model decision). I'd recommend this so that you can insure
that the conduit/snap bushing hole size is sufficiently large for the
tubing and various wires.
Hope this helps!
Bob #40105
jjessen(at)rcn.com Guest
Posted: Wed Jan 04, 2006 8:57 am Post subject: Lights on VS and When to buy options |
Nice post, Bob.
don.wentz(at)intel.com Guest
Posted: Wed Jan 04, 2006 2:08 pm Post subject: Lights on VS and When to buy options |
Yes Bob,
Good thorough information.
Just a couple comments:
1 - Whether you use a 'conduit' or 'bushings', install an extra fishing
line or 2 so if you add some wire later you have something to attach to
and just pull it thru.
2 - Since the -10 wings are quite large inside, installing the Duckworks
lights after the wings are closed is only minimally more difficult than
during construction.
3 - We're adding an option to our product list that is the install kits
without the lamps. We have gotten many inquiries for this to either
space-out the costs, and or allow installation of lamps sourced by the
builder. At least they can leverage our installation package.
Dw (Duckworks)
Posted: Thu Jan 05, 2006 4:36 am Post subject: Lights on VS and When to buy options |
Thanks both Don and Bob for your helpful replies.
