Lycoming Cylinder question
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Engines-List
drogers(at)maf.org
PostPosted: Sun Mar 18, 2007 9:59 am    Post subject: Lycoming Cylinder question Reply with quote
I have some questions about Lycoming Cylinders. I understand that all
their 360 and 540 engines use the same size cylinders. Also that there
are 2 types of cylinders: Straight valve and Angle valve. I know what
the cylinders look like and can easily tell the difference but what are
the differences in engine application? How can you know whether a IO540
L (for example, if there is such a thing) has one or the other type of
cyl? Do the high HP engines have one type and the Lower hp the other
type? Is one type of cylinder newer than the other?
Dan
- The Matronics Engines-List Email Forum -
http://www.matronics.com/Navigator?Engines-List
wbecker(at)centurytel.net
PostPosted: Sun Mar 18, 2007 3:40 pm    Post subject: Lycoming Cylinder question Reply with quote
I'm no expert but, The angle valve engines make more HP due to better
flow. They are both manufactured currently. Bill B
glcasey(at)adelphia.net
PostPosted: Mon Mar 19, 2007 5:00 am    Post subject: Lycoming Cylinder question Reply with quote
I'm not "the" Lycoming expert, but as far as I can tell everything
with a power rating of 300 or more has the angle-valve cylinders. A
sure-fire way to tell is to look at the Lycoming spec sheet on their
website and the parallel-valve engines are narrower. Other than that
the model numbers don't give much of a clue unless you just know
which is which. As Bill said, the angle-valve heads flow better.
The naturally-aspirated versions have a 8.7 compression ratio vs. the
8.5 of the parallel-valve engine, and that also helps to produce
slightly more power. With more space between the valves the angle-
valve engine requires less pressure drop for cooling, theoretically
reducing cooling drag. But they are heavier, to the tune of 4 or 5
pounds per cylinder and the angle-valve engines don't have the same
reputation for longevity as the parallel-valve engines. An expert
told me that there is nothing to be gained by porting and polishing
the angle-valve cylinder, while the parallel-valve version can be
ported to achieve almost the same airflow as the angle-valve cylinder.
Gary Casey
Parallel-valve IO-540 with 10:1 compression dyno tested at 305 hp
Subject: Lycoming Cylinder question
there
are
IO540
Dan
drogers(at)maf.org
PostPosted: Tue Mar 20, 2007 1:03 pm    Post subject: Lycoming Cylinder question Reply with quote
Thank you, Gary and Bill,
I have now studied the Lycoming website engine lists and can see a clear
relationship between comp ratio, engine width and weight. There is also
power corelation, but because of turbo and various RPM combinations, it
is not as clear cut.
Thanks again,
Dan
Gary Casey wrote:
I'm not "the" Lycoming expert, but as far as I can tell everything with
the model numbers don't give much of a clue unless you just know which
is which. As Bill said, the angle-valve heads flow better. The
naturally-aspirated versions have a 8.7 compression ratio vs. the 8.5 of
the parallel-valve engine, and that also helps to produce slightly more
power. With more space between the valves the angle-valve engine
requires less pressure drop for cooling, theoretically reducing cooling
drag. But they are heavier, to the tune of 4 or 5 pounds per cylinder
and the angle-valve engines don't have the same reputation for longevity
as the parallel-valve engines. An expert told me that there is nothing
to be gained by porting and polishing the angle-valve cylinder, while
the parallel-valve version can be ported to achieve almost the same
Gary Casey
apilot2(at)gmail.com
PostPosted: Tue Mar 20, 2007 1:57 pm    Post subject: Lycoming Cylinder question Reply with quote
Probably just as important, the angle valve engines are designed for
more cooling, both in the cylinder head design, and with oil squirt
nozzles spraying oil on the bottom side of the pistons. The weight
increase is unfortunate, as it somewhat degrades the performance
increase. I would think that the angle valve cylinders would be more
desirable for turbocharging, with the better heat dissipation
capability. The one factory TIO540 with parallel valve cylinders that
I am familiar with, had to be retrofitted with oil cooled valve guides
to make the valve stems and guides last.
Thanks again,
Dan
> Gary Casey
Jon A. Delamarter
PostPosted: Wed Mar 21, 2007 5:46 am    Post subject: Re: Lycoming Cylinder question Reply with quote
Dan:
Here's a brief overview I wrote for the new Lycoming website. Let me know if I can help with more details.
Parallel Valve Cylinder – The intake and exhaust valves of a parallel valve cylinder are mounted in parallel to one another in the cylinder head and share a common rocker shaft which is retained by the rocker cover. This arrangement gives the parallel valve cylinder’s rocker cover its distinctive “parallel” or square shape; parallel valve rocker covers are also distinguished from angle valve rocker covers by their greater thickness. Parallel valve cylinders are utilized on carbureted and some lower output, lightweight fuel injected engines. Most parallel valve 4 cylinder engines do not incorporate a counterweighted crankshaft which further contributes to their relative lightweight.
Angle Valve Cylinder – The intake and exhaust valves of an angle valve cylinder are mounted at angles to one another in the cylinder head. Angle valve cylinders utilize separate rocker shafts for intake and exhaust rockers; the rocker shafts are held in the cylinder head by separate retaining plates. This arrangement gives the angle valve cylinder’s rocker cover its distinctive “angle” shape; angle valve rocker covers are also distinguished from parallel valve rocker covers by their lesser thickness. Utilized on high output engines. Angle valve engines are heavier and slightly wider than their parallel valve counterparts but are capable of safely and efficiently producing more horsepower due to increased head density and improved head design. Angle valve engines incorporate counterweighted crankshafts which reduce torsional vibration.
Jon A. Delamarter
Thunderbolt Manager
Lycoming Engines
PostPosted: Wed Mar 21, 2007 6:13 am    Post subject: Lycoming Cylinder question Reply with quote
That last sentence needs a bit of qualification. A large number of
angle valve engines do NOT have counterweighted crankshafts. In
particular, the IO-360-A1A, used extensively from 1964-1976.
Jon A. Delamarter
PostPosted: Wed Mar 21, 2007 6:50 am    Post subject: Re: Lycoming Cylinder question Reply with quote
Touche'!
You are absolutely correct. See what over-generalization gets me? I should have said "most" angle valve engines incorporate counter-weighted crankshafts. Hmm, I see I already have to edit my new website.
Thanks for keeping me straight!
Jon A. Delamarter
Thunderbolt Manager
Lycoming Engines
drogers(at)maf.org
PostPosted: Wed Mar 21, 2007 11:18 am    Post subject: Lycoming Cylinder question Reply with quote
Is this already on the Lycoming website?? If so I didn't find it when I
went looking for this info!
Dan R
Jon A. Delamarter wrote:
Dan:
Jon A. Delamarter
PostPosted: Wed Mar 21, 2007 12:29 pm    Post subject: Re: Lycoming Cylinder question Reply with quote
Dan:
Yes it is, but you're not going to see it unless you go through the engine configurator on the Thunderbolt microsite. Go to www.lycoming.com/thunderbolt or direct link at http://www.lycoming.com/thunderbolt_configurator/initializePowerplantConfiguratorFlow.do?methodToCall=initializePowerPlantConfigurationPageFlow
If you go through and configure a Thunderbolt engine, there is an option on the final page to view a printable version of the estimate. The bottom of the estimate has a ton of data. The info I posted is only a small portion.
You always have the option of emailing me directly at jdelamarter(at)lycoming.textron.com. I don't have all the answers, but I work with the folks that have most of them!
Kind regards,
[quote="drogers(at)maf.org"]Is this already on the Lycoming website?? If so I didn't find it when I
Jon A. Delamarter
Thunderbolt Manager
Lycoming Engines
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Engines-List All times are GMT - 8 Hours
