go-fly-away(at)juno.com Guest
Posted: Sat Mar 17, 2007 3:51 pm Post subject: Rheostat Diagrams |
Hi Bob,
I have your book but am looking for proper use of a rheostat to dim the annuciators on a KLN 90-B. I have ground plus the annunciator light wires. I am having a brain dump on this one. Any suggestions??
Thanks, Mark [quote][b]
nuckollsr(at)cox.net Guest
Posted: Sun Mar 18, 2007 6:27 am Post subject: Rheostat Diagrams |
At 11:44 PM 3/17/2007 +0000, you wrote:
| Quote: | Hi Bob,
Thanks, Mark
A simple series rheostat may not be what you want. Do
you know if the lighting is incandescent lamps or LEDs?
How much current does the lighting input draw? The pinout
data I have for the KLN90 reads like there are two 14v
lamp strings that are hooked in series for 28v and parallel
for 14v systems. A voltage regulating dimmer like
http://www.aeroelectric.com/articles//DimmerFabrication.pdf
will always work.
A rheostat's resistance and wattage needs to be sized to
the total load while the voltage regulating dimmer's control
functionality is relatively independent of total load and
needs only sizing for total load. Is the KLN90 the ONLY circuit
you plan to tie onto your dimmer control?
( IF one aspires to be "world class", )
( what ever you do must be exercised )
( EVERY day . . . )
( R. L. Nuckolls III )
