		LarryRosen
				 Posted: Sun Jan 14, 2007 6:36 pm    Post subject: 8AWG Wire to Fast-On Connection |
				In order to keep the voltage drop down on a long 14 volt 30 amp run I
 want to use 8 AWG wire.  The final device has a male Fast-On terminal.
 The only terminals I can find for 8 AWG wire are ring terminals, how do
 I transition to a Fast-On?
 Larry
 RV-10
  _________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
		nuckollsr(at)cox.net Guest
				 Posted: Sun Jan 14, 2007 10:24 pm    Post subject: 8AWG Wire to Fast-On Connection |
				At 09:28 PM 1/14/2007 -0500, you wrote:
 In order to keep the voltage drop down on a long 14 volt 30 amp run I want
 The only terminals I can find for 8 AWG wire are ring terminals, how do I
    Splice a 6" 10AWG stub on the end of the 8AWG wire
    so that you can crimp a standard yellow (10-12AWG)
    PIDG on the end.
    30A is pushing a Fast-On pretty hard. What's your
    application?
       < the authority which determines whether there can be   >
       < debate or not does not reside in some fraternity of   >
       < scientists; nor is it divine. The authority rests     >
       < with experiment.                                      >
       <                            --Lawrence M. Krauss       >
		LarryRosen
				 Posted: Tue Jan 16, 2007 7:32 pm    Post subject: 8AWG Wire to Fast-On Connection |
				Bob,
 The Fast-On connection is to a mosfet switch solid state relay sold by
 perihelion design <http://www.periheliondesign.com/powerlinkjr.htm>
 rated for 35 amps continuous.  But your statement "30A is pushing a
 Fast-On pretty hard" got me thinking, which generated more questions, so
 now I need some guidance.
 I am using the a Z-13/20 architecture that is modified for a battery in
 the tail cone (RV-10)  The solid state relay is for the endurance bus
 feed.  The circuit goes from the battery to a 30 amp ANL limiter to the
 relay and then to the endurance bus, the run is 17 feet.  The continuous
 e-bus load is just under 10 amps, but the maximum possible load is 30
 amps (no diversity at all, everything running at once, flaps, auto pilot
 servos, com transmit, etc).  The drivers for the high load are pitot
 heat and landing light. [I know it could be debated whether or not these
 deserve to be on the e-bus, but IMHO this design is to allow me to fly
 safely in IMC and land]
 So, if my calculations are correct for a 14 volt system:
 a] 10 amps (at) 17 feet 10AWG has a voltage drop of 0.17 volts
 b] 10 amps (at) 17 feet 8 AWG has a voltage drop of  0.11 volts
 c] 30 amps (at) 17 feet 10 AWG has a voltage drop of 0.51 volts
 d] 30 amps (at) 17 feet 8 AWG has a voltage drop of  0.32 volts
 This is only the voltage drop to the e-bus fuse block and does not
 account for the voltage drop to the final device.
 So, I believe I am justified in using a 30 amp fuse, but am I being way
 to conservative in using 8 AWG wire to account for a very unlikely full
 max load?
 Larry
 RV-10 N205EN (reserved)
  <nuckollsr(at)cox.net>
 > <LarryRosen(at)comcast.net>
 > do I transition to a Fast-On?
    PIDG on the end.
    application?
#40356
N205EN (reserved)
<http> |
				 Posted: Wed Jan 17, 2007 7:08 am    Post subject: 8AWG Wire to Fast-On Connection |
				At 10:30 PM 1/16/2007 -0500, you wrote:
 Bob,
 perihelion design <http://www.periheliondesign.com/powerlinkjr.htm> rated
 for 35 amps continuous.  But your statement "30A is pushing a Fast-On
 pretty hard" got me thinking, which generated more questions, so now I
 need some guidance.
 e-bus load is just under 10 amps, but the maximum possible load is 30 amps
 servos, com transmit, etc).  The drivers for the high load are pitot heat
   I'll suggest that nobody should plan to depend on a battery-feed
   e-bus to extract themselves from an IMC environment. In
   retrospect, I'm not too happy with the 13/20 configuration,
   it's pretty messy. I'm beginning to think that Z-12 is the
   best way to incorporate the SD-20 . . . this is how it's
   done on thousands of TC aircraft that used to fly routinely
   in IMC with NO second alternator and NO e-bus.
   Given that you have two engine driven power sources, I'll
   recommend that you pare the E-bus down to the minimum endurance loads
   suggested in chapter 17. Likelihood of EVER needing to
   recover from dual alternator failure using the e-bus all the
   way to the ground is exceedingly low and to PLAN for it
   is making your system get a bit messy.
   If you're down to battery only, then the original e-bus
   philosophy is critical to graceful recovery. You can always
   close master contactors during approach to landing
   for recovery. If you're looking at servicing a 30 amp
   load under these conditions, then adding one or two
   contactors at 1A each is insignificant.
  	  | Quote: | 	 		  So, if my calculations are correct for a 14 volt system:
 This is only the voltage drop to the e-bus fuse block and does not account
 So, I believe I am justified in using a 30 amp fuse, but am I being way to
 conservative in using 8 AWG wire to account for a very unlikely full max load?
    Let's re-think this a bit and see if we can take
    some weight and operating complexity out of your proposed
    design. This is an excellent case where MORE is NOT BETTER.
		Eric M. Jones
				 Posted: Wed Jan 17, 2007 7:12 am    Post subject: Re: 8AWG Wire to Fast-On Connection |
				Larry,
 Pushing hardware gets everybody into trouble. Please recalculate this based on my Super-4-CCA. Also, have you looked at the ground return? Pushing 30A makes me concerned with ground return currents through the control cables or structural parts...an insidious killer.
 As for the Fastons. I puzzled over this for years. Connectors are sold for 10 AWG wires but no larger, and that firmly sets the amp limit. Splicing larger wires to the connectors concerns me and I advise against it.
 Email me offline and we can discuss some options.
 (I will still send a sample of Super-2 and Super-4-CCA to interested parties...see my website).
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
				 Posted: Wed Jan 17, 2007 8:37 am    Post subject: 8AWG Wire to Fast-On Connection |
				At 07:12 AM 1/17/2007 -0800, you wrote:
 Larry,
    Hmmmm . . . I'm not aware of any well considered
    design situation where local grounding was discouraged
    for the protection of control cables or structural
    parts. We ground things ALL OVER the airframes on
    everything from A36 to Hawker 850 and with return
    currents that run a lot more than 30A.
    I've heard a variety of stories but none were supported
    by any critical review of hard data. Until we're
    offered good data supported by simple-ideas, I'll
    suggest that the eroded cables, loose rivets and
    pitted skins are the result of some stresses OTHER
    than ground return currents.
    For example, a few years ago we identified a case where
    drive-end bearings on starter generators were being
    eroded by small voltage drops in structure (tens of
    millivolts) but at hundreds of amps. This was supported
    by good data, repeatable experiments and obvious
    mitigation of a recurring problem by electrically
    insulating one end of the quill shaft. It would have
    been much BETTER to re-arrange some wiring but the
    cost of modifying hundreds of airplanes was reduced by
    building a special drop-in replacement for the
    starter-generator.
  	  | Quote: | 	 		  As for the Fastons. I puzzled over this for years. Connectors are
    My design philosophy for the use of Fastons has more
    to do with longevity than for "ratings". Yes, one might
    safely assume that 'cause AMP supplies a Faston to fit
    a 10AWG wire, that the same Faston and it's mating
    tab are capable of carrying the same current as the
    wire.
    But keep in mind that wire current "ratings" are based
    on temperature rise . . . a 10AWG wire is not in danger
    in a room temperature environment at 50 amps. Should we
    out-of-hand assume that it's okay to load the 10AWG
    Faston to 50A in the same environment?
    Probably okay when new but consider the case of the
    bouncing ammeters in many Cessna and Piper singles.
    This is a case where multitudinous connections in
    the voltage-sense/field-supply lead have increased
    loop resistance by perhaps 100 milliohms. Not enough
    voltage drop to case the system to fail . . . but enough
    to upset the voltage regulator's servo loop stability.
    This takes perhaps 20-30 years in the field. EXCEEDINGLY
    difficult to diagnose if you don't understand the simple-
    ideas behind system functionality.
    This is why I de-rate the fuse blocks to 15A per slot
    while the manufacturer rates them for 30A per slot.
    Recall that heating effects are an I-squared effect.
    Limiting the design loads on any one fuse by 50%
    reduces heating stresses on the fuses connections by
    75%.  This is a element of an overall design philosophy
    that has nothing to do with things you read in the
    manufacturer's data sheets.
    As I write these words, I'm in conversation with some
    poor tech in Europe trying to fix a paralleling stability
    problem on a 30 year old Hawker. This beast uses
    MAGNETIC AMPLIFIERS in the generator control units.
    The paralleling system has 30-50 joints in the loop . . .
    ANY or ALL of which can be contributing to the malfunction.
    The sad part is that we may find that LOTS of joints need
    to be renewed to bring this airplane back to designed
    performance. This is a case were the joints are carrying
    perhaps less than 3A.
    Just one of many examples of a situation where loading
    decisions and architectures are fine-tuned NOT to
    accommodate out-of-the-box ratings but to reduce
    probability of disappointing performance 10-20 years from now.
    The question that started this thread had to do with
    running an 30A e-bus feeder through a Faston . . .
    all the bells went off and red flags went up. Assume
    this system checks out just fine for first flight
    and then sits quietly waiting for the a some years
    hence when its called upon to perform its intended
    purpose. How much are we willing to bet that it's
    going to take this 30A load for long enough to get
    down? If you're betting your life on it, would
    it not be more prudent to design this potential weakness
    out from square one? This seems especially smart when
    that one joint becomes single point of failure for
    the e-bus alternate feed.
  	  | Quote: | 	 		    Splicing larger wires to the connectors concerns me and I advise against it.
    Keep in mind that the wire was up-sized to meet a voltage
    drop requirement, not to increase max current in the
    line. Splicing "too-big" wires in for the purpose
    of mitigating voltage drop is a sound principal (See
    chapter 8 in 'Connection) but maybe not practical after
    we consider the big picture for system architecture and
    the failure modes we're proposing to handle.
    I'm about 80% convinced that Z-13/20 is going to come out
    of Rev 12 in favor of recommending Z-12 as the most
    practical way to incorporate the SD-20 into a light
    aircraft.
		LarryRosen
				 Posted: Wed Jan 17, 2007 9:55 am    Post subject: 8AWG Wire to Fast-On Connection |
				Thanks Bob and Eric for your guidance.    I will need to rethink my load analysis once again.
 Bob,
 You said " I'm about 80% convinced that Z-13/20 is going to come out
    aircraft."
 But, doesn't this defeat the elegance of the e-bus concept.  The main alternator fails and with 3 switches (Aux Alternator on, e-bus feed on and master off) you would have an electrical design that would out last the fuel on board.  With Z-12 you would have to manually shed the load.
 Larry
  -------------- Original message ----------------------
 From: "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
  >Bob,
  >need some guidance.
#40356
N205EN (reserved)
<http> |
				 Posted: Wed Jan 17, 2007 11:27 am    Post subject: 8AWG Wire to Fast-On Connection |
				At 05:53 PM 1/17/2007 +0000, you wrote:
 Bob,
     aircraft."
 fuel on board.
    Absolutely . . .
  	  | Quote: | 	 		     With Z-12 you would have to manually shed the load.
    . . . and there are features in the SB-1 regulator that assists
    the pilot in the load reduction task.
    I'm going to catch a lot of flack when I pull the drawing. No doubt
    many folks have installed it . . . and I'll have to explain that
    there's nothing functionally BAD about Z-13/20. Nonetheless, after
    working with builders over the time the drawing has been published,
    I've determined that it doesn't conform to my personal standards
    of "the best we know how to do."  It's simply too complex.
		ryan42
				 Posted: Fri Mar 16, 2007 4:10 pm    Post subject: Re: 8AWG Wire to Fast-On Connection |
				Out of curiosity Bob, would you then mainly advocate z-14 for new designs with a 20A alternator.  In the past it seems you have suggested z-14 over z-12 for people in the planning stages (correct me if I'm wrong).  Maybe a z-14 that uses the second bus as a smaller main alt. out e-bus, not used for starting...smaller battery...
 In what instance would you use z-12 over z-14 with a 20A alternator? Save a little $ and #?
 -Ryan (In the pondering stage)
