shempdowling2(at)earthlin Guest
Posted: Tue Mar 13, 2007 5:05 am Post subject: Signature block in Thunderbird |
Help. Im tired of typing my info at the end of my posts but cant figure
out how to add a signature block using Thunderbird. Anyone.....??
Shemp
N915JD
Dana Overall wrote:
Just as a quick note, my experience with registering my DO-7 took
about three weeks. I had already reserved my N number and filled out
the paperwork matching, as I was told by a rep. in OK, two of the
three items, Manufacturer, serial number, model number as per the bill
of sale from Van's. I listed myself as manufacturer (as usual) and
used my Van's serial number with the model changed to DO-7.
Total time from mailing to receiving my
registration........................2 weeks, 6 days. Pretty nice!!!
Dana Overall
Richmond, KY i39
RV-7 slider, Imron black, "Black Magic"
O 360 A1A, C/S C2YK-1BF/F7666A4
http://rvflying.tripod.com/blackwing1.jpg
Play Flexicon: the crossword game that feeds your brain. PLAY now for
FREE.
http://zone.msn.com/en/flexicon/default.htm?icid=flexicon_hmtagline
Posted: Tue Mar 13, 2007 6:48 am Post subject: Signature block in Thunderbird |
Wont this signature block be added to all of my emails, not just rv list
Shemp
Tim Olson wrote:
TOOLS - ACCOUNT SETTINGS. Check the "Attach this signature" checkbox.
Then select the signature text file. Just use Notepad to create
a quick signature text file and select it. You're all set. If you
use multiple accounts, each can have it's own sig.
Jeff Dowling wrote:
> <shempdowling2(at)earthlink.net>
> Do not archive
> figure out how to add a signature block using Thunderbird.
> Anyone.....??
> Shemp
> N915JD
stevea(at)svpal.org Guest
Posted: Tue Mar 13, 2007 6:51 am Post subject: Signature block in Thunderbird |
Tools / Account Settings / check the "Attach this signature box" and the
signature of your choice.
Jeff Dowling wrote:
figure out how to add a signature block using Thunderbird. Anyone.....??
Shemp
N915JD
castolon(at)gmail.com Guest
Jeff Dowling wrote:
| Quote: | Help. Im tired of typing my info at the end of my posts but cant
Very easy to do.
First, create a text/ascii file with your preferred information.
Next, in Thunderbird, click...
Tools
Account Settings
On the right side, down below your name and email check 'Attach this
signature', then navigate to and select the text file you created. It
will appear in every message you send, but can be deleted from the
composition window if there's times you'd rather it not be attached (no
need to disable it in the settings).
Want a different message? Create a new text file and insert it as above.
Want to choose among multiple messages? Use a macro generator, like PC
Magazine's robotype or RoboForm, and create as many signatures as you
want. If you go this route you'll have to remember to manually insert
them at the bottom of your messages but, with a couple of keystrokes,
you could put in anything you wanted rather than repetitively typing it in.
pgroell
Posted: Tue Mar 13, 2007 7:25 am Post subject: Signature block in Thunderbird |
Hello,
I find the best tool for this is the following Add-on
https://addons.mozilla.org/thunderbird/578/
After install, you create as many signature you want.
While editing your post, you access to all the signature via a simple
right-click.
Pascal
| Quote: | -----Message d'origine-----
De : owner-rv-list-server(at)matronics.com
[mailto:owner-rv-list-server(at)matronics.com] De la part de Steve Allison
Envoyé : mardi 13 mars 2007 15:49
À : rv-list(at)matronics.com
Objet : Re: Signature block in Thunderbird
box" and the signature of your choice.
Jeff Dowling wrote:
> --> <shempdowling2(at)earthlink.net>
> Do not archive
Anyone.....??
> Shemp
> N915JD
Photoshare, and much much more:
