naumuk(at)alltel.net Guest
Posted: Sun Mar 11, 2007 12:27 pm Post subject: Upper extruded Ls |
All-
Well, here we are. 3 months late (Some might say 3 years late), but the fuse is hooked up to the c-section. Just finished the garanger and still have to be careful of positioning or I'll run out of room!
Anyone have an easy way to bend the upper longerons? I'm not crazy about building the rig Larry Mac used, but will if I have to.
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
30.63 KB |
414 Time(s) |
wjones(at)brazoriainet.co Guest
Posted: Sun Mar 11, 2007 12:49 pm Post subject: Upper extruded Ls |
Hi Bill ,there may be a better way ,however I used the method used by Larry Mac .It takes next to nothing to build the jig if you already have some big "C" clamps
Wade Jones South Texas
601XL plans building
Cont. 0200
Ron Lendon
Joined: 10 Jan 2006 Posts: 685 Location: Clinton Twp., MI
Posted: Sun Mar 11, 2007 3:20 pm Post subject: Re: Upper extruded Ls |
That's the way I plan on doing mine. The whole object is to have some control over the process.
_________________ Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
https://sites.google.com/site/corvairenginedata/ |
rickpitcher
Posted: Sun Mar 11, 2007 3:52 pm Post subject: Upper extruded Ls |
Posted: Sun Mar 11, 2007 5:27 pm Post subject: Upper extruded Ls |
Bill,
Take another look at what it takes. Very little effort to get it right
here and you just use the template to check against.
Bend just a little at a time, and you can unbend as needed to get it.
Just take your time.
http://www.macsmachine.com/images/fuselage/full/longeronbend.gif
Larry McFarland at www.macsmachine.com
Bill Naumuk wrote:
| Quote: | All-
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
Posted: Sun Mar 11, 2007 5:42 pm Post subject: Upper extruded Ls |
Wade-
I guess it's the casters that threw me.
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
Posted: Sun Mar 11, 2007 5:45 pm Post subject: Upper extruded Ls |
Rick-
Definitely the way to go, but I can't justify the expense for two bends.
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
Posted: Sun Mar 11, 2007 5:50 pm Post subject: Upper extruded Ls |
Larry-
I'll probably come up with something similar depending on what I find
laying around the corners of the garage.
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
ter_turn(at)yahoo.com Guest
Posted: Sun Mar 11, 2007 6:33 pm Post subject: Upper extruded Ls |
Check out Scott Laughlin's site. He simplified Larry's bender a little. Couldn't get easier.
Bill Naumuk <naumuk(at)alltel.net> wrote:
[quote]--> Zenith-List message posted by: "Bill Naumuk"
Larry-
Bill Naumuk
HDS Fuse/Corvair
Townville, Pa
david_a_g_johnson(at)btin Guest
Posted: Mon Mar 12, 2007 3:21 am Post subject: Upper extruded Ls |
I used this technique, but using a vice (vise?) for better control.
One problem is that the longeron tries to bend sideways as you bend it. My
solution was to clamp both longerons back to back to form a T section and
bend them both together, they tend to stay flat if you do that, as they are
each trying to bend in oppposite directions, so cancel out. It also has the
advantage that you get both longerons to exactly the same curve - and if you
are REALLY lucky, it might even be the CORRECT curve!!
Dave Johnson
601XL from a kit (in the UK)
Wings, tail and most of the fuselage done, waiting for the instruments
(Dynon D100 & D120) and engine Jab.3300)
