nuckollsr(at)cox.net Guest
Posted: Sat Mar 10, 2007 7:17 am Post subject: automatic flap controls? |
| Quote: | Comments/Questions: Hi Bob.
| Quote: | This is Luigi from Rome ,Italy.
| Quote: | I'm looking for a scheme to realize a flap electrical circuit to have two
or three pre-set position. For instance T.O. approach and landing. Is
there any project ? Thank you for any help.
| Quote: | The info discovered on aeroelectric.com are simply fantastic.
Thank you for the kind words. I'm pleased that
you find the work useful.
One needs to approach automatic systems for
moving flight control surfaces with caution.
While relatively easy to do the desired task,
one needs to minimize if not eliminate risk
of inadvertent motion. The system should be
designed such that a failure which causes
motion to occur at the wrong time does not
precipitate a situation the pilot or the
airplane cannot be expected to handle.
So, the answer to your question is, "yes,
it's relatively easy to craft the automatic
flap positioning system." I've considered
offering such a device as a product from
aeroelectric.com
However, given that flaps are operated for
less than 1% of total flight time per flight
cycle, I've not convinced myself that the $time$
needed to craft the suitable system is cost
effective given that manual flap operation
does not represent a significant work load
item for operating an airplane. Therefore, this
is not going to become an offering from
my website and I don't recommend them as
a useful addition to the light aircraft.
( IF one wishes to be "world class" at )
( anything, what ever you do must be )
( exercised EVERY day . . . )
( R. L. Nuckolls III )
