Generator Light
pilot(at)ip6.com
PostPosted: Fri Mar 09, 2007 8:18 pm    Post subject: Generator Light Reply with quote
I have a Pipistrel Sinus 912 that uses a Rotax 912 UL2.
In the last few flights the Generator Light has been intermittent and in
the last flight it has always been on.
The voltage oscillate between 12.2 and 13.5 Volts.
The battery seems to be charged.
The regulator is Rotax 264 870.
Any advices?
Thank You
-- Silvano
Roger Lee
PostPosted: Sat Mar 10, 2007 7:13 am    Post subject: Re: Generator Light Reply with quote
Hi Silvano,
I'm not 100% sure, but I believe the reason the light is coming on is because you are dipping down to 12.2 volts.
You won't charge that low. You need to print the Rotax manual online and see what the values are and test the reg. If that's not an option then you need to replace it with a known good reg. and I think you will see higher charging voltage. I am going to the field today. I will double check and see exactly what mine is and email you back.
Roger Lee
Tucson, Az.
Rotax Instructor & Rotax IRC
Light Sport Repairman
Cell 520-349-7056
pilot(at)ip6.com
PostPosted: Sat Mar 10, 2007 9:07 pm    Post subject: Generator Light Reply with quote
I verified that the regulator is the Ducati 343620.
I am in doubt if replacing it with a similar one or installing a
different one,
like the Key West.
The Key west is easy to find, I don't know where to buy a Ducati.
Any advice is welcomed.
-- Silvano
Roger Lee wrote:
Hi Silvano,
Roger Lee
Tucson, Az.
http://forums.matronics.com/viewtopic.php?p=99778#99778
Thom Riddle
PostPosted: Sun Mar 11, 2007 5:16 am    Post subject: Generator Light Reply with quote
The 912 charging system is known for charging to a relatively low
voltage. Our voltage usually reads about 12.6-12.7 volts before
starting. In the winter when we don't fly as much, we keep a trickle
charger plugged into the system. In the winter, after the trickle
charger has been on overnight or longer, but is then unplugged, the
voltage unusually reads about 13.2-13.3 volts. The 12.6-12.7 volts is
normal for all the 912 engines I've seen. I have no idea why Rotax
builds it that way.
Thom in Buffalo
Thom Riddle
Buffalo, NY (9G0)
- Anonymous
JimT
PostPosted: Sun Mar 11, 2007 8:07 am    Post subject: Generator Light Reply with quote
I have the 40 amp rotax optional alternator. (It counts  even if it's still in it's box on the shelf ,next to the plane right?) In any event the instructions include the option of just putting the tow alternators in parallel. The 18 amp alternator is regulated to 13.5 v. The 40 amp alternator is set to 14.3.
According to the hand out, somewhere around a 30-32 amp load the output drops to 13.6 and the smaller alternator kicks in.
Jim Timoney
Searey kit, doing the panel
AOL now offers free email to everyone. Find out more about what's free from AOL at AOL.com.
ami(at)MCFADYEAN.FREESERV
PostPosted: Sun Mar 11, 2007 8:23 am    Post subject: Generator Light Reply with quote
Mine has run at 13.8 volts for 350 hours (according to the voltmeter built
in to a Garmin GPS).
Duncan Mcf.
pilot(at)ip6.com
PostPosted: Sun Mar 11, 2007 4:29 pm    Post subject: Generator Light Reply with quote
The problem was a wire that was not crimped properly.
Now the voltage is 13.8 Volts and the light is off
Thank You
-- Silvani
Duncan & Ami McFadyean wrote:
<ami(at)mcfadyean.freeserve.co.uk>
built in to a Garmin GPS).
Duncan Mcf.
Roger Lee
PostPosted: Thu Mar 15, 2007 3:32 pm    Post subject: Re: Generator Light Reply with quote
Hi Guys,
I checked my charging today and it was 13.5V.
Roger Lee
Tucson, Az.
Cell 520-349-7056
